Dual Ignition Heads
curtis52285
curtis52285 is offline
PostPosted: Thu Aug 27, 2009 8:34 am    Post subject: Dual Ignition Heads Reply with quote
I have heard that you can get dual ignition heads for the VW air-cooled engine (2 spark plugs per cylinder). Do these exist and where can you get these? Are the benefits worth the added cost?
krusher
krusher is offline
PostPosted: Thu Aug 27, 2009 10:08 am    Post subject: Reply with quote
You can for the 356 http://www.precisionmatters.biz/twin-plug-ignition.php
dont know of anything for a type 1 that isnt an aircraft application.
(06:31:07) RoachGhia: "i drink dick way too fast"
thewreckingsoul
thewreckingsoul is online now
PostPosted: Thu Aug 27, 2009 10:40 am    Post subject: Reply with quote
i've seen scat split port heads with dual plugs per cylinder but it was on a vw powered aircraft.
i would like to see them on a street vw though... Ford had dual plug flat heads back in the day... two plugs per cylinder. would unique i think for a vw to run it.
Ad
In action
In action again
bj
bj is offline
PostPosted: Thu Aug 27, 2009 11:58 am    Post subject: Reply with quote
do a search for bugpatch
they have some for about $750 or so....
bj
ShadetreeVEE
ShadetreeVEE is offline
the only dual plug heads i know of are out of australia, the guy (stan p?) builds the motors for hill climb races, and uses them on the street. theyre pretty insane.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Aug 27, 2009 12:40 pm    Post subject: Reply with quote
Jake does twin plug type 4 heads...
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
bj
bj is offline
PostPosted: Thu Aug 27, 2009 1:00 pm    Post subject: Reply with quote
actually, len does the heads for jake. but i think the OP is asking for type 1 heads.
bj
Jake Raby
Jake Raby is offline
PostPosted: Thu Aug 27, 2009 2:16 pm    Post subject: Reply with quote
I also build twin plug T1 engines and have head and ignition combos for them....
Find a copy of the July 2000 VW Trends for an article called "Two sparks are better than one" which featured my twin plug arrangement...
I have built a few dozen twin plug T1 and TIV engines dating back to 1999.. When the engine combination is optimized the results are amazing.. I made 250HP on pump gas last year with a 2.9 Twin Plug engine in my Wife's GL Vert and it still averaged 30 MPG.
Here is av ideo of the build of the car, the dyno sessions are in the video, the throttle response of the engine is incredible for such a large engine.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
Mr. Electric Wizard
Mr. Electric Wizard is offline
PostPosted: Thu Aug 27, 2009 2:21 pm    Post subject: Reply with quote
Good God Jake!!! Shocked
"Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper
Jake Raby
PostPosted: Thu Aug 27, 2009 2:23 pm    Post subject: Reply with quote
Then I drove it 6,000 miles in two months Smile
Didn't touch it.. Now its in California and replaced with a roller cammed 2270 Smile
Jake Raby
Mr. Electric Wizard
PostPosted: Thu Aug 27, 2009 2:35 pm    Post subject: Reply with quote
Was this a T4 engine?
Had to be right?
~ Cullen Hightower
sturgeongeneral
sturgeongeneral is offline
PostPosted: Thu Aug 27, 2009 7:21 pm    Post subject: Reply with quote
I have seen them on some Harleys but hadn't thought about vw aplication before.
Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her
Jake Raby
PostPosted: Thu Aug 27, 2009 7:43 pm    Post subject: Reply with quote
Had to be right?
Yes it was..
BUT I built a twin plug 1915 T1 last year for Herbie Blash, Chief Tech Inspector for the FIA (F1) that made 165HP with 155 TQ on pump gas (89 octane) at 11.5:1
He loves the car, it went into a Beck Spyder.
Jake Raby
nikita
nikita is offline
PostPosted: Mon Aug 31, 2009 11:47 am    Post subject: Reply with quote
These folks do the dual plug work for aircraft conversions.
http://www.greatplainsas.com/sccylheads.html
Scroll down to the bottom of the page for labor prices sending in your heads.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Aug 31, 2009 12:30 pm    Post subject: Reply with quote
it is done in aircraft for redundacy. Twin magnetos twin plugs. They can't just pull over when it comes to problems and fix a wire.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
dawie
dawie is offline
PostPosted: Tue Sep 01, 2009 1:11 am    Post subject: Reply with quote
Does anyone have long-term experience with 10mm plugs? Heard that they get fouled easily. Would a 12mm size plug be a good compromise for second-plug application?
Jake Raby
PostPosted: Tue Sep 01, 2009 4:43 am    Post subject: Reply with quote
I've been using them since 1999 with no issues.. My experience is they resist fouling better than a larger plug.
Twin plug heads run so clean that you'll be hard pressed to ever foul them.
Jake Raby
nikita
nikita is offline
PostPosted: Tue Sep 01, 2009 7:10 am    Post subject: Reply with quote
And to reduce the risk of detonation. Two flame fronts from opposite sides of the combustion chamber help a lot.
Jake Raby
PostPosted: Tue Sep 01, 2009 7:40 am    Post subject: Reply with quote
Absolutely!
I have proven that with 2.9 liters, 11.75:1 and a 105.7mm bore.. On pump gas it made 250HP. optimized at 24 degrees of timing and ran head temps less than 300F at 80 MPH.
Jake Raby
Mr. Electric Wizard
PostPosted: Tue Sep 01, 2009 7:44 am    Post subject: Reply with quote
How does the wiring run for twin plugs?
Only 4 posts on a dizzy.
~ Cullen Hightower
Page 1 of 7
