DonnieDarko Samba Member
Joined: September 06, 2008 Posts: 884 Location: Monroe, NC
Posted: Tue Sep 29, 2009 7:10 pm Post subject: Typical oil pressure? |
I hooked up a mechanical oil gauge I got, and it's reading ~43psi idle and 45psi or so when given gas (though, in neutral).
Sound about right? _________________ 1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
1972 Volkswagen Bus - Project
1970 Volkswagen Standard Beetle - Baja Project
I pick cheap and reliable. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76946 Location: Sneaking up behind you
Posted: Tue Sep 29, 2009 7:11 pm Post subject: |
43 idle... how thick and how cold is the oil?
What's it at operating temp? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Sep 29, 2009 7:19 pm Post subject: |
Glenn wrote: |
What's it at operating temp? |
43psi is 10w-30 and an ice cold motor in about 60F weather.
I drove about 50 miles and checked it (the gauge is temporarily mounted in the rear until I get long enough hose) and now it's at 20psi and when given juice it climbs to 40psi or so (before I backed off the gas, the neighbors are sleeping) _________________ 1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
Glenn Mr. 010
Posted: Tue Sep 29, 2009 7:26 pm Post subject: |
Glenn wrote: |
That sounds better. |
Is it within specs? What's yours at? _________________ 1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
Glenn Mr. 010
Posted: Tue Sep 29, 2009 7:27 pm Post subject: |
Hot... my oil pressure is like 10psi at idle.
Member #1009
#BlueSquare |
Posted: Tue Sep 29, 2009 7:31 pm Post subject: |
Glenn wrote: |
I wish I would have checked it without shutting it off. I drove 50 miles, went to take a leak, posted my thread, and then started my car back up and got the 20psi reading.
As long as it's not too bad, I'm happy.
Thanks again Glen _________________ 1974 Volkswagen Super Beetle - Daily Driver/Rolling Project Beater - Stock w/ GT Style Exhaust
10 A C N Samba Member
Joined: August 30, 2009 Posts: 110 Location: jackson, tn.
Posted: Tue Sep 29, 2009 7:53 pm Post subject: |
Oil temp 158 F. Oil SAE 30 at 2500 RPM (42 PSI new installation)
(28 PSI wear limit) |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6199 Location: N.W. Phoenix
Posted: Tue Sep 29, 2009 8:25 pm Post subject: |
20 at idle is OK _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
SkrapMetal Samba Hornblaster
Joined: January 18, 2006 Posts: 2558 Location: Dallas, TX
Posted: Tue Sep 29, 2009 8:50 pm Post subject: |
Glenn wrote: |
Hot... my oil pressure is like 10psi at idle. |
But you have a 26mm pump Glenn... don't you? _________________ oo9less since 2007
-72 Ghia- |
fastinradford Samba Member
Joined: June 08, 2008 Posts: 2895 Location: Athens Ohio
Posted: Wed Sep 30, 2009 5:11 am Post subject: |
SkrapMetal wrote: |
Glenn wrote: |
But you have a 26mm pump Glenn... don't you? |
regardless, 5-6 psi is fine at idle, you do not need more than 2-3psi without a load on the motor. |
Smithy Samba Smithy
Joined: May 10, 2004 Posts: 508 Location: under the hill
Posted: Wed Sep 30, 2009 6:48 am Post subject: |
A general rule of thumb is 10psi per 1000 rpm. With that in mind, with the engine warm and at 850 rpm (idle speed), the oil pressure should be about 8.5 psi. These are general guidelines.
The stock oil pressure sender goes off at 6/7psi. Therefore, depending on conditions, the oil light may flicker at idle. This is normal. There is no cause for worry if the oil pressure is 10psi per 1000 rpm at speed and under load.
Less oil pressure than 10psi/1000rpm may indicate internal bearing or case wear and should be addressed before your engine suddenly goes "boom". _________________ Don't take life too seriously- you'll never live thru it....
Dyslexic rebel, I beats to the drum of a different march. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Wed Sep 30, 2009 7:01 am Post subject: |
My idle oil pressure is also 10 psi or lower when hot, even Arizona hot (20-year-old 1835cc).
DonnieDarko wrote: |
I drove 50 miles, went to take a leak... |
Thanks for sharing..... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
