vwsb74 Samba Member
Posted: Mon Aug 31, 2009 7:57 pm Post subject: pasenger side mirror? |
| hi, I want to install a passenger side mirror how do you do it?thanks |
mr69 Samba Member
Joined: March 03, 2006 Posts: 176 Location: Long Beach CA
Posted: Mon Aug 31, 2009 8:28 pm Post subject: |
super glue, JB Weld, epoxy pick your poision...  _________________ 1968 blue rocket
Vettes, mustangs, camaros, hondas and nissans all look the same in the rear view mirror. |
seajay96  Samba Member
Joined: February 17, 2009 Posts: 343 Location: Paris, France
Posted: Mon Aug 31, 2009 8:32 pm Post subject: |
it really depends on the style you're installing, most likely, you will need to drill a hole into the door _________________ '73 Super Beetle |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 3876 Location: White Mountains Arizona
Posted: Mon Aug 31, 2009 8:41 pm Post subject: |
It is not easy but you will have to take the door apart and afix a nut on the inside of the hole you drilled to mount the mirror. _________________ Volkswagen: We tune what we drive.
Numbers Matching VW's are getting harder to find. Find one keep it Stock. |
Viande  Samba Member
benCarn Samba Member
Joined: August 05, 2009 Posts: 218 Location: El Paso, Tx
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6192 Location: Northern Illinois
Posted: Tue Sep 01, 2009 9:40 am Post subject: |
When I worked at the dealer we used a Karmann Ghia mirror mount and a beetle convertible mirror to install right outside mirrors on 1968 + bugs. It saves you from havng to do any welding or taking the door apart. _________________ Midwest Vintage |
rdwood Samba Member
Posted: Tue Sep 01, 2009 1:45 pm Post subject: |
| I am restoring a '74 Super and was thinking about doing the same thing while I have the doors apart. Here is what I found with my car. The passenger side door has the mirror mounting bracket already welded inside of the door, just like the driver's side. The catch is for some reason, VW left off welding the mounting nut to the bracket. But it doesn't look like it will be too hard to weld the proper nut to the bracket, once I figure out the correct size. I will then have to drill a hole in the outer skin of course but I can create a template from the driver's side door to guide me to the exact spot to drill on the passenger side. |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 27 Location: Martinez, CA
Posted: Tue Sep 01, 2009 2:01 pm Post subject: |
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-857-517-C
thats the mounting nut.... i just got that and a mirror from cip1, since the door on the bug i picked up had the mirror mounting hole already drilled (cool), and it looks like a stock drill hole, so not sure what year the door came from....
i didn't weld the nut in, just took off the door panel and had a friend hold the mirror in place while i got the nut started from inside the door. once it was started and stiff, i was able to finish tightening it by spinning the mirror clockwise from the outside. its on there pretty good, i'm happy... although i might need to tighten the horizontal placement... _________________ '01 Audi A4 - turbo quattro - 5 spd
'71 VW Std. Beetle - 4 spd |
rdwood Samba Member
Posted: Tue Sep 01, 2009 4:52 pm Post subject: |
| Cool! I didn't know that nut was available from Cip1. |
mr69 Samba Member
Posted: Tue Sep 01, 2009 7:11 pm Post subject: |
| rdwood wrote: | | I am restoring a '74 Super and was thinking about doing the same thing while I have the doors apart. Here is what I found with my car. The passenger side door has the mirror mounting bracket already welded inside of the door, just like the driver's side. The catch is for some reason, VW left off welding the mounting nut to the bracket. But it doesn't look like it will be too hard to weld the proper nut to the bracket, once I figure out the correct size. I will then have to drill a hole in the outer skin of course but I can create a template from the driver's side door to guide me to the exact spot to drill on the passenger side. |
why go to all the trouble, just weld the mirror to the door  _________________ 1968 blue rocket
Posted: Tue Sep 01, 2009 8:10 pm Post subject: |
The Ghia mount saves all the trouble ti simply mounts with two small stainless screws hidden under a stainless cover and no need to take the door apart. I think the job paid 1.5 hours and it was a 5 minute job. _________________ Midwest Vintage |
mondshine Samba Member
Joined: October 27, 2006 Posts: 336 Location: World's Motor Capital
Posted: Sun Sep 06, 2009 7:52 pm Post subject: |
Has anybody here actually installed a pre1968 (hinge mount) mirror on a late sedan?
There is an advertiser here on the samba who will rent the tool to press out the hinge pin, and I would like to hear from somebody who has actually done it.
Thanks, Mondshine |
Gumbercules Samba Member
Joined: October 27, 2008 Posts: 7 Location: Riverside
Posted: Sun Nov 01, 2009 12:57 am Post subject: |
| DrDarby wrote: | | When I worked at the dealer we used a Karmann Ghia mirror mount and a beetle convertible mirror to install right outside mirrors on 1968 + bugs. It saves you from havng to do any welding or taking the door apart. |
It has to be a convertible mirror? What are some of the major differences between vert and standard mirror for a 68? |
dubstar Samba Member
Joined: January 17, 2009 Posts: 366 Location: New York
Posted: Sun Nov 01, 2009 7:55 am Post subject: |
"I think the job paid 1.5 hours and it was a 5 minute job."
that says a lot about dealers... _________________ http://dasvolks.com/
1963 Type II Kombi
1977 Type I Fuel Injection
1990 Vanagon GL
"you could transport really tall things too, like a giraffe" |
Viande  Samba Member
PETETE Samba Member
Joined: May 17, 2007 Posts: 46 Location: Somewhere in Connecticut
Posted: Sun Nov 01, 2009 9:30 am Post subject: |
use THIS ONE if you don't feel like drilling the door. _________________ "If you can't reach it, get a ladder" |
PETETE Samba Member
Posted: Sun Nov 01, 2009 9:42 am Post subject: |
Now I'm curious to see a picture of a bug with fender mirrors....Any one has a link? _________________ "If you can't reach it, get a ladder" |
jhicken  Samba Member
Joined: October 24, 2003 Posts: 5328 Location: Flagtown, NJ
