TheSamba.com Mid America Motorworks
Early tie rod boots
Forum Index -> Beetle - Oval-Window
Nifski
Nifski is offline
PostPosted: Mon Nov 02, 2009 10:53 pm    Post subject: Early tie rod boots Reply with quote
Does anyone know who re manufactures high quality early Oval Tie rod boots? Thanks
bjoy
bjoy is offline
PostPosted: Tue Nov 03, 2009 4:16 am    Post subject: Reply with quote
whats a tie rod boot? clamp?
Volumex
Volumex is offline
PostPosted: Tue Nov 03, 2009 6:40 am    Post subject: Reply with quote
The black rubber bit in this pic pinched from the Wolfsburg West site:
I'd suggest replacing the whole lot rather than just the boot. If the boot has failed, then there might be debris in the ball joint which will accelerate wear.
Sorry it doesn't answer the question. Embarassed
PEPPE
PEPPE is offline
PostPosted: Tue Nov 03, 2009 6:53 am    Post subject: e Reply with quote
the early boots are not like the later pictured. they are thick rubber.
i speak about the tie rods with grease fitting...
the boot is not sealed with a circlip, it allows for excessive grease going out.
see this ADhttp://www.thesamba.com/vw/classifieds/detail.php?id=536702
65 T1, 77 SB Conv, 69 T2 camper
in resto:
55 T1, 63 244, 63 241, 63&64 t34
hazetguy Premium Member
Mr. Negativity
hazetguy is offline
PostPosted: Tue Nov 03, 2009 9:28 am    Post subject: Re: e Reply with quote
Zwitterkafer
Zwitterkafer is offline
PostPosted: Tue Nov 03, 2009 11:14 am    Post subject: Reply with quote
Try CIP1. That's where I found some.
H.
- Zeuxius, 400 BC
djfordmanjack
djfordmanjack is offline
PostPosted: Tue Nov 03, 2009 11:59 am    Post subject: Reply with quote
If you want to drive your car, throw out those old joints or put them on the shelf for a further 100% resto. Those bj's are internally spring loaded, giving the ball the chance to move up and down in the housing- also meaning they tend to have a lot of play with no steering force applied ( going straight).better use replacement or post 59 NOS.
'54 Oval 11, '54 Panel 21, '56 Karmann 15
Nifski
Nifski is offline
PostPosted: Tue Nov 03, 2009 5:48 pm    Post subject: Reply with quote
thanks pepe, that fellow makes them in small batches, and good idea to run the latter ones and save the originals! Thanks, and I will check CIP
jim@zarwerks.com
jim@zarwerks.com is offline
PostPosted: Tue Nov 03, 2009 5:50 pm    Post subject: Reply with quote
I have reproductions of the originals here:
www.zarwerks.com
PEPPE
PEPPE is offline
PostPosted: Wed Nov 04, 2009 12:45 pm    Post subject: e Reply with quote
i believe that them are like modern ones.
i check regurarly also modern ones to check for springing and overall wear.
when they wear start with springing and later starts to have play that can be feeled by hand/eye.
the amount of springing is proportional to wear and it's the same effect on early and late tie rods.
in resto:
Reply to topic    Forum Index -> Beetle - Oval-Window All times are Mountain Standard Time/Pacific Daylight Savings Time
Kaefer-Nostalgie
Copyright © 1996-2009, Everett Barnes. All Rights Reserved.   | Archive
