1621 Samba Member
Posted: Fri Nov 06, 2009 10:12 pm Post subject: Cibie backup light install (w/ Pics) |
Just completed my extra backup light for the Westy. I've seen this done well, and always wanted to add some extra light to the rear for those extra dark locations (boondocking) where you need to see behind you for reversing. I also wanted to add the option of manually flooding the area behind the van with light for times when the flashlight just isn't cutting it.
My requirements were the following:
1. Nothing too bulky hanging off the back of the van.
2. A flood or fog beam to provide adequate area lighting.
3. Nothing too expensive as this is not an everyday use item.
4. Have the ability to use it manually, automatically with the reverse switch, and to keep it off entirely.
In auto mode:
Manual:
The Cibie Airport 35's fit the bill perfectly. They are only 1-3/4" deep, and thus would not protrude very far. They fit the styling of the Vanagon and provide excellent light as well. The only problem is they tend to be expensive (~$100 each). I located this one on eBay for $39, and even though it was amber and not white, I went for it.
The lamp mounted easily, and only has the 12v+ wire to connect as it grounds through the mounting bolt. I did need to grind a small bit off the mounting/positioning bracket to make it swivel down a bit more, but nothing a few minutes with a 4" grinder couldn't handle.
There are two holes drilled in the rear of the van. The upper and larger of the holes is to mount the light itself. It's been primed and painted for the most part, except for the bit on the inside of the engine bay where it grounds. The lower and smaller of the holes has a grommet and allows the wire to pass through. This is connected to a relay mounted in the engine bay.
The switches controlling the light are mounted below the rear heater fan switch. From left to right they are 1.) manual on/off 2.) automatic on/off with the reverse lights, and 3.) a switch for the extra interior lights I mounted in the rear. The backup light switches are wired to an indicator light on the dash that lets me know when I have the auxiliary backup light on. This prevents me from accidentally and unwittingly blinding the guy behind me on the highway.
This project was not difficult by any means, but does reqire some planning beforehand. If you decide to do this definitely consider proper fusing and wiring requirements. I would also highly recommend using a relay.
Even though the light is amber in color, it does provide FAR MORE light than the stock reverse lights - even with the 50w bulbs I tried a while back. I would have taken some photos of the light output, but it's difficult to show in a photo. Suffice it to say it makes a big difference.
With the light cover in place:
 _________________ '85 Westy
"Years from now you will be more disappointed by the things you didn't do than by the ones you did do. So throw off the bow lines. Sail away from the safe harbor. Catch the tradewinds in your sails. Explore. Dream. Discover." —Mark Twain |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 814 Location: Portland, OR
Posted: Fri Nov 06, 2009 10:28 pm Post subject: |
Nice job!
I want a landing light from a 747 so I can blind all the tailgaters at night. What size fuse do you think I'd need for that? _________________ 89 Syncro Westy - GW 2.5
90 Syncro Adventurewagen - RIP |
madspaniard Samba Member
Joined: August 18, 2008 Posts: 987 Location: Berkeley, CA
Posted: Fri Nov 06, 2009 11:11 pm Post subject: |
nice! how did you run wires from backlight to dash switches? _________________ **##**
1991 automatic westy with all power options |
1621 Samba Member
Posted: Fri Nov 06, 2009 11:32 pm Post subject: |
| madspaniard wrote: | | nice! how did you run wires from backlight to dash switches? |
Used a trailer wiring kit available at any FLAPS, and ran it along the driver's side of the vehicle with the bundle of wiring that runs to the front of the van. It enters the van through the large grommet for the front heater core pipes below the stereo and up to the switches. 12v+ power for the #30 pin on the relay is taken directly off the alternator and flows to the relay through an inline 10A fuse.
*Edit - I should note that the trailer wiring is fine for the signal from the switch to the relay, but not for the main power to the relay. I used 12 AWG stranded wire from the alternator to the relay with a heavy duty/weatherproof inline fuse between the two. It's also carefully wrapped, routed and secured to prevent any issues with wires being damaged by an operating engine. _________________ '85 Westy
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 1488 Location: Vancouver B.C.
1621 Samba Member
Posted: Sat Nov 07, 2009 5:09 pm Post subject: |
| Vanagon Nut wrote: | Nice write up Eric!
Did you choose that type of light to take the "edge off" (for other campers) when backing into CG's late at night?
Nice I/O switches. Tres Euro!
Neil. |
Thanks for the compliments Neil, and no I never thought about the amber light and impact on other campers. I really got it because I liked the light, the price was right, and didn't think much about the color.
The switches were chosen for their practicality. Easy to mount, look good, and fit in. The manual light switch was chosen because I could feel the little LED without looking down - it's for letting other drivers know they're a wee bit closer to my bumper than I'd like without taking my eyes off the road.  _________________ '85 Westy
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 162 Location: Golden, CO
Posted: Sat Nov 07, 2009 8:19 pm Post subject: |
Really nicely done, I want to do this!! This would be really nice on a Syncro when you need to back up on the trail at night. Excellent work!
Paul _________________ '87 Syncro 7-Pass.
"Simplicate, then add lightness." Colin Chapman |
