LowNslow '65 Samba Member
Posted: Wed Dec 02, 2009 8:59 pm Post subject: Driver side upper engine mounting bolt |
When I bought my 69 I noticed that only 3 bolts were holding the motor in and they were a little loose letting the motor move around. My case has a threaded insert and the bolt goes in from the transmission side.
Does anybody know what size the upper drivers side bolt is? _________________ LCC Automotive |
desertmedic Samba Member
Joined: October 27, 2009 Posts: 97 Location: Corpus Christ, TX
Posted: Wed Dec 02, 2009 9:32 pm Post subject: |
No worries, mine only has 3 bolts as does most that have ever had an engine pulled for any reason. If it will make you have that warm fuzzy maybe someone will post the size. I would help you out but have no idea. The excess movement could be worn transimission mounts as well. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Wed Dec 02, 2009 9:34 pm Post subject: |
M10x70
If you only needed 3 bolts the factory would not of added a 4th. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Dec 02, 2009 10:33 pm Post subject: |
Cool deal! Thanks Glenn _________________ LCC Automotive |
Posted: Thu Dec 03, 2009 7:43 am Post subject: |
Enough said.... I took care of it. I went and put a zip tie where the bolt was!!!! Sorry I'm out of bailing wire. Say what you want but you will not make me believe that you havent seen/done it before. Is it the lazy way, maybe. Is it right, probably not. Is it detrimental, I don't believe so. I'm not trying to pass on bad habits to the new guy just saying it isnt the end of the world and is quite common. Webwalker, its not really a burn as just that warm fuzzy feeling I spoke of. What does "prick" feel like? |
a.graham52 Samba Member
Joined: December 23, 2008 Posts: 417 Location: the island of missfit toys, Maine
Posted: Thu Dec 03, 2009 8:20 am Post subject: |
i bought a 68 parts car that was parked for the last 8 years. it was last inspected with only two bolts holding the engine, and 7 patches riveted in the floor and lower body |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Dec 03, 2009 8:22 am Post subject: |
That bolt threads in readily, especially if you position yourself more forward than you might think, and reach above the drive shafts. Ise a 3/8 inch drive ratchet with one or two long extensions and a 17mm socket. If you don't have such extensions, buy 'em, they're really handy. Buying/having tools is never a waste. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
gt1953 Samba Member
Posted: Thu Dec 03, 2009 9:45 am Post subject: |
Get the correct bolt and put it in you will be glad you did. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Thu Dec 03, 2009 10:38 am Post subject: |
Prehaps sir. But I will concede. M10-70 belongs there. I am about to leave for work but will install one when I get back. (Work is in Abu Dhabi, UAE) The commute is a bear! I do have a question for you, all be it off subject. In your signature you have 72 1/2 super. I have a 72 vert, according to the door sticker was built in 11/71. What disguinshes a 72 1/2, and what are the differences? |
amazinglarry104 Samba Member
Posted: Thu Dec 03, 2009 10:42 am Post subject: |
I noticed the same thing when I pulled my engine. The top drivers side bolt was missing. When I got the engine out, I noticed there were places inside the transmission ground away from the engine shifting around./ |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Thu Dec 03, 2009 11:12 am Post subject: |
desertmedic wrote: |
The factory often did half year mods, and January of the model year (in my case 72) was the usual time that they would make the change, using up the rest of the old parts (which is why its sometimes tough to pin down a change to a specific VIN) and then beginning to install the new parts. My 1302 was made in February of 1972, placing it in the same model month as the Weltmeister, the Beetle that broke the ModelT production record.
There were a couple of midyear changes for 72-1/2, including retracting seatbelts, a seat belt warning light (causing the light to illuminate and the buzzer to sound any time you were in a gear with the engine running, but with your seatbelt off. )
There were a few other minor changes, too, but they escape me right now. This is what makes the model year user's manual kind of a knee slapper, because often they use photos from the previous year's model to apply to the current year model, which may have changed again by the time you buy it late in the model year.
So it wasn't uncommon for midyear changes to happen. The 1976 bus changed seat rails midyear, but the craziest change I ever saw was the Vanagon, which changed engines and cooling technology from aircooled to watercooled *midyear* in 1983. I can imagine a redesigned head midyear...but the whole freaking engine and cooling system? Yowza.
Stay safe in the UAE. I'll bet A/C would be a welcome upgrade! _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Posted: Sat Dec 05, 2009 10:22 am Post subject: |
I dont understand why you have to be a smart ass there is a time and place for that.... I asked a simple question and it got answered, what you choose to do with your car is up to you nobody is stopping you. As far as a new guy Im not. Ive been here longer than you have, and when I answer somebodys question I try to help them because it is a problem to them and not a joke! I didnt come on here amused that my engine was being held in by 3 bolts. Just as stated before if it came from the factory with 4 bolts I will put 4 bolts back in. Also somthing for you to consider thinking about, If the other 3 bolts works themselfs loose you will be putting a lot of stress on the input shaft, clutch disc and pilot bearing....
This is the car that Iam finishing up that is missing that bolt. I was planning on getting a bolt while the motor was out but I didnt remember until I was installing it at 2am. Now that I got everything in there its a PIA to try to figure out the right bolt size.
http://www.thesamba.com/vw/forum/viewtopic.php?t=383693
Have a nice day
Dan _________________ LCC Automotive |
Posted: Sat Dec 05, 2009 12:56 pm Post subject: |
thats a great looking car. after doign all that work i dont blame you for not wanting to do temp. fixes. do right the first time! |
Posted: Sat Dec 05, 2009 1:51 pm Post subject: |
Thanks! _________________ LCC Automotive |
Posted: Sat Dec 05, 2009 3:18 pm Post subject: |
Dan,
Don't take too much offense at desertmedic; I flamed him (bad enough to get my OP in the thread deleted ) and he and sorted it out. You don't have to take offense; I already did that for you.
Hope the rest of the work went well.
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
stevearnold Samba Member
Joined: March 11, 2012 Posts: 2 Location: Southern Utah
Posted: Thu Nov 22, 2012 11:55 am Post subject: The dreaded bolt |
I have a 67 bus and the drivers side upper bolt was always giving me reason to shout profanities...as my bolt was loose and had nuts on each side...the transmission side was easy to reach but the engine side was behind the air shroud with little room to maneuver...if I could just weld that engine side bolt into place I would solve my problems...but I had a brainstorm and sliced an access panel between the support beams above and had easy access..found the three nuts I had dropped and now am grateful that my engine is properly mounted with all four bolts. |
Chris Vellat Samba Member
Joined: April 09, 2004 Posts: 1590 Location: Seattle, WA
Posted: Thu Nov 22, 2012 7:53 pm Post subject: |
Marc wrote: |
AutoSticks use longer hardware, the following applies to 4-speeds.
The LH bolt is 70mm long, the RH is 110mm. Thread is m10x1.5
Depending upon the year of the car/transaxle/starter/engine either bolt may be hex- or D-headed. You can always use a hex-head bolt, but most starters have "nibs" to hold a D-head from spinning which makes it easier to tighten the nut. Mid`60 thru 1970 trans cases have nibs for the LH bolt as well (they were dropped in `71 with the introduction of the DP engine that has a threaded steel insert in the case for the LH bolt).
P/N for the 110mm D-head is 111 199 101
The 70mm D-head is N 010 470 7 (AKA N104707) |
http://www.shoptalkforums.com/viewtopic.php?f=34&t=140119&p=1127152 _________________ (3) '69's
'67 Baja
'74 Super
'73 Bay
(2) '77's |
stevensj13 Samba Member
Joined: October 03, 2011 Posts: 715 Location: Willow Spring, NC and Saugerties, NY
Posted: Thu Nov 22, 2012 10:43 pm Post subject: |
Now thinking about it, neither my 71 Super, 70 Baja, or 71 Bus had the upper drives side bolt when I got them - and still don't . I'm unsure about my 73 Super because thats the only one I haven't had to pull the motor out of yet |
Willhelm Samba Member
Posted: Fri Nov 23, 2012 12:50 am Post subject: |
miss·ing/ˈmisiNG/
Adjective: (of a thing) Not able to be found because it is not in its expected place. Not present or included when expected or supposed to be.
I bought a replacement and put it in. Having it in place hasn't caused any problems. |
Fleisch Samba Member
Joined: February 20, 2013 Posts: 10 Location: Sonoma County, CA
Posted: Fri Dec 27, 2013 11:24 am Post subject: Re: Driver side upper engine mounting bolt |
Very helpful posts. Thanks to all for the info. Just found that mine is missing (1776 in a '67 bus) and I am pulling the engine this afternoon. I'll head down to the imports shop and pick up that bolt and nut. Very thankful for this site!
P |
