Bugpack Shift right shifter-Merry Xmas to me
pdub
pdub is offline
PostPosted: Fri Dec 18, 2009 11:36 pm    Post subject: Bugpack Shift right shifter-Merry Xmas to me Reply with quote
I just got my new shifter and put it in about a week ago. I love it. Nice and smooth. Short throw, and solid. Way better than the Drag-Ass by Scat that needed customization just to make it work. Also better than my Hurst knock off from Latest Rage...although once beefed up with a couple minor spot welds it was not bad for a $35.00 unit. The Bugpack Shift Right was about $130.00 and worth the extra $30.00. Made in the USA too.
57streetrodbuggy
57streetrodbuggy is offline
PostPosted: Sat Dec 19, 2009 12:29 am    Post subject: Reply with quote
does anyone have a link to this shifter? i have the scat t-handle and it is causing nothing but problems
Bermoco buggy on 57 pan - under construction
There's no such thing as too much horsepower, there is only a point where the car breaks in two
74 Thing
74 Thing is offline
PostPosted: Sat Dec 19, 2009 12:55 am    Post subject: Reply with quote
Check the classified
http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
Suppose to be a really good product-kind of like a Berg shifter made in the USA but they do not have different lengths, curves or throws available like Berg.
jfats808
jfats808 is offline
PostPosted: Sat Dec 19, 2009 1:23 am    Post subject: Reply with quote
Glad your new shifter is spot on. I just merry christmas' myself a GB 6770LK w/ a nice black handle. Aint Christmas time grand? -Jon
Buy once, cry once.
2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
mynameistory
mynameistory is offline
PostPosted: Sat Dec 19, 2009 9:56 am    Post subject: Reply with quote
If you want to keep your shifter and save some bucks, here's a way to fix it.
http://shoptalkforums.com/viewtopic.php?f=15&t=117964
-tory
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Dec 19, 2009 11:27 am    Post subject: Reply with quote
I can't understand this hate for the drag fast. I have one, it's fine, no issues, no mods. For me, it works fine.
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
rgdedge
rgdedge is offline
PostPosted: Sat Dec 19, 2009 1:34 pm    Post subject: Reply with quote
Me too, I have ran one for 20+ years and not one problem. A few friends have them also without any issues.
Tim
donmurray
donmurray is offline
PostPosted: Sat Dec 19, 2009 1:39 pm    Post subject: Reply with quote
It looks like the one I just installed from Aircooled.net. Nice piece of work.
74 Ghia, with 2110 engine
bugninva
bugninva is offline
PostPosted: Sat Dec 19, 2009 5:23 pm    Post subject: Reply with quote
I don't know man, but i've read several folks say they don't work well... they've always been easy to install and worked flawlessly for me...
[email protected] wrote:
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone?
GEX has. Just sayin
erlawson
erlawson is offline
PostPosted: Sat Dec 19, 2009 7:54 pm    Post subject: Reply with quote
bugninva wrote:
I don't know man, but I've read several folks say they don't work well... they've always been easy to install and worked flawlessly for me...
I've had drag fast in my Baja for closed to 20 years and several other cars (and a bus one in my 61 panel) and they have been great. The only issues I ever had was in my Baja when I put in one of those cheap urethane shift couplers, it didn't line up and I don't think any shifter would have worked well with it. Put in a stock coupler and back to smooth accurate shifts. I also have a couple of the locking Gene Berg shifters which are very nice, but pricey.
Eddie
57 ragtop bug, 59 Country Buggy repop., 61 ranch buggy/bus, 62 baja, 63 dune buggy/baja, '66 dune buggy, '66 & '67 fastbacks, 70 "Mule", 73 Thing, 09 dune/street buggy
TOOB Member #13
BSQUARE wrote:
...When bugs mature, they become type 3s.
Ghostwagens
stealth67vw
stealth67vw is offline
PostPosted: Sat Dec 19, 2009 8:09 pm    Post subject: Reply with quote
I have 2 you can have Eric. I pulled them out my 67 and my ragtop because they both missed 1st to 2nd shifts all the time. It's no fun slamming 2nd gear and having it go in reverse without pulling the lockout.
John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile
hoghead5150
hoghead5150 is offline
PostPosted: Sat Dec 19, 2009 8:37 pm    Post subject: Reply with quote
i have run the scat shifers for years. some do have a problem, but there is no need to weld or drill anything in the shifter. just sometimes you gotta shim it. easy, cheap.
"i got a friend that knows a guy who's best friend has an uncle that used to have a bug just like yours!"
i measured once, cut it three times, and the damn thing is STILL to short!
Banzai KG
Banzai KG is offline
PostPosted: Sat Dec 19, 2009 9:07 pm    Post subject: Reply with quote
I had lousy experiences with SCAT shifters...
Here's what I have to say about the SCAT Drag "Miss Shift" shifters:
I've been using my Gene Berg shifter since I bought it new in 1994.
Before I bought the Berg, I went thru (4) SCAT Drag Fast shifters in 6 years, that was about $50-70 per shifter.
The problem I had with the SCAT shifters was the stupid rivets loosened up and was causing me to miss shifts (sloppy shifting) and many times it goes into REVERSE when I speed shifted from 1st to 2nd. I even tried to tighten the rivets up, but no dice.
That's when I decided to get an 11" curved Berg Shifter w/ 60% throw after going thru those (4) SCAT Drag "Miss Shift" shifters even with new shift rod bushings.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
Hotrodvw
Hotrodvw is offline
PostPosted: Sat Dec 19, 2009 9:18 pm    Post subject: Reply with quote
I guess the question is, why would you buy three more after having trouble with the first one?? To each his own, I'm not having an issue with it.
'67 Sunroof
Eric
lots of money!
Hose & Fittings
mynameistory
PostPosted: Sun Dec 20, 2009 12:41 am    Post subject: Reply with quote
Send 'em to me. I'll fix them up and sell them if you don't want them.
-tory
