lasslo Samba Member
Joined: September 01, 2004 Posts: 72 Location: sweden
Posted: Mon Dec 28, 2009 4:04 pm Post subject: Hazet 2191 |
Brake line tool.
Everything else in the kit is missing  _________________ 65 DD klenbus
57 Karmann Ghia |
Shane6 Samba Member
Posted: Wed Dec 30, 2009 3:32 pm Post subject: |
Pretty much all the specialty Hazet tools I have have already been posted. Here are a few that have not.
Hazet 2579 13mm double box end
I was told that this is to access the nuts around axle of the transmission. Does anyone agree or disagree.
 _________________ '63 Turkis beetle 'vert '64 Turkis Caravelle camper |
Shane6 Samba Member
Posted: Wed Dec 30, 2009 3:34 pm Post subject: |
Here are another couple.
2578 10mm
2578 13mm
I think these maybe for removing the intake manifold nuts on single and dual port engines. Any input?
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2495 Location: San Diego, CA
Posted: Fri Jan 01, 2010 9:28 pm Post subject: |
Bottle opener commemorating the 100th anniversary of Hazet.  |
Posted: Fri Jan 01, 2010 9:36 pm Post subject: |
| Shane6 wrote: |
Yes, and also for the exhaust. |
BeaterBarndoor Samba Member
Joined: December 15, 2000 Posts: 689 Location: North Carolina
Posted: Sat Jan 02, 2010 12:41 pm Post subject: |
Here is a pencil sharpener that i aquired a dozen or so years ago. never really seen anybody else ever post one before.thought some of you may like it even though its not a mechanical tool...more for the Hazet salesman i suppose!
 _________________ www.thebustransfer.com
Whaaaaat? |
Snoop Bob Samba Member
Posted: Sat Jan 02, 2010 12:50 pm Post subject: |
Nice...I am all about the salesman schwag too  _________________
| BarryL wrote: |
| Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
| EverettB wrote: |
| I would be interested in knowing the sizes of the various shafts. |
scvw Samba Member
Joined: September 02, 2006 Posts: 3160 Location: South Carolina
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1660 Location: Clearwater Fl.
Posted: Tue Jan 05, 2010 7:57 pm Post subject: |
funny...i have the bottle opener...the first wrench shane posted and the pencil sharpener and i dont even particularly collect this stuff...
i was under the impression the wrench was for something type3...oil pump...exhaust or something...cant recall... _________________ www.blastserv.com
wanted:unstamped serial number 36hp block |
Shane6 Samba Member
Posted: Tue Jan 05, 2010 8:47 pm Post subject: |
Hazet #2582 brake adjuster
Could the hole possibly be some trick way to extend drum springs over to their hole??? Or just some hillbilly's way to hang it on the wall?? It does look factory though.
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1424 Location: Winter Park
Posted: Wed Jan 06, 2010 4:41 pm Post subject: |
| Shane6 wrote: |
Could the hole possibly be some trick way to extend drum springs over to their hole??? Or just some hillbilly's way to hang it on the wall?? It does look factory though. |
It's factory... I don't know what for though.
 _________________ Jason
1958 Kombi |
vaughn bros.  Samba Member
Joined: October 13, 2003 Posts: 1633 Location: Hickory, NC
Posted: Sun Jan 10, 2010 12:57 pm Post subject: |
Is this a common Hazet wrench. Monster size 36mm Combo #600
Shane6 Samba Member
Posted: Sun Jan 10, 2010 1:30 pm Post subject: |
Hazet 773 lugwrench/ cap puller
The weight is nice, the action on removing the cap is perfect. It is hard to slide back the handle exposing hub cap puller (which often results in broken handles)
Posted: Sun Jan 10, 2010 4:34 pm Post subject: |
These 3 below are some recent flea market finds from a trip with Shane ^^ who graciously allowed me to have the lot from the day. See NP, It really does happen. (I posted this before but I seem to be on The Samba Sensor List.)
Hazet 2582 Brake Star Adjuster (note 2 holes that appear factory as opposed to the one hole above.)
| BarryL wrote: |
| EverettB wrote: |
Posted: Sun Jan 10, 2010 4:36 pm Post subject: |
Hazet 600 19mm
| BarryL wrote: |
| EverettB wrote: |
Hazet 2769 Mercedes Valve Adjusting Wrenches. Not VW based but I can see the application in VW valve adjustment.
| BarryL wrote: |
| EverettB wrote: |
Shane6 Samba Member
Posted: Sun Jan 10, 2010 5:23 pm Post subject: |
| vaughn bros. wrote: |
I found one of these in 36mm at an antique store when I first got into VWs. I knew of Hazet only because of the association with the spare tire tool kit. I purchased it for $15 and Marshal Painter bought it from me in a swap meet. He turned around and sold it to Chris Price from the Jacksonville Florida area.
I wish I had hung on to it now that I'm into Hazet. It is an awsome size too, the same as early bus and beetle rear axles and the glandnut on 1600cc and down motors (of course you know that;) _________________ '63 Turkis beetle 'vert '64 Turkis Caravelle camper |
Posted: Sun Jan 10, 2010 8:52 pm Post subject: |
I have been working to complete a 2500 A2L which is a Hazet assistent with a compliment of tools for a VW mechanic. It has a variety of the 25XX tools along with a bunch of standard hand tools.
Here is my 2500A cart in progress:
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1222 Location: Chicago
Posted: Thu Jan 21, 2010 8:40 pm Post subject: |
Snoops, the Hazet factory in Remscheid is big, take a look at the view I had from the train each morning when I stayed a block away for a week.
There are two other production facilities in the area too, but they don't give factory tours.  _________________
| KWZ wrote: |
| Pressed bumper buses are gay. |
Wanted:
Nice rear cargo mat - long seat mounting holes/no rips or tears |
Posted: Thu Jan 21, 2010 8:53 pm Post subject: |
Nice...Was that a lit up sign that would shine the HAZET logo on your wall when sleeping?  _________________
| BarryL wrote: |
| EverettB wrote: |
