chambersc Samba Member
Posted: Wed Jan 06, 2010 8:32 am Post subject: Welded and Balanced Fan Question |
Who do I get one from. I've been looking at upgrading mine since it is the original 1974 OEM fan. There are several listed here on The Samba, one os an OEM one that's been welded and balanced. Other's are obviously aftermarket. Anyone have suggestions on who has a good one? _________________ "It's no accident that the word LISTEN and the word SILENT contain the same letters." |
lupin..the..3rd Samba Member
Posted: Wed Jan 06, 2010 9:07 am Post subject: |
I dunno, I have the original '79 fan in mine. I suspect most folks are running original fans. "If it aint broke, don't fix it" is how I look at it. Plus I don't rev the motor up too much. I thought the welded and balanced fans were more for high-rpm operation?
If the fan did start to come apart, it would make quite bit of noise I would think, slapping around against the shroud. |
Marv [UK] Samba Member
Posted: Wed Jan 06, 2010 9:16 am Post subject: |
| lupin..the..3rd wrote: | I dunno, I have the original '79 fan in mine. I suspect most folks are running original fans. "If it aint broke, don't fix it" is how I look at it. Plus I don't rev the motor up too much. I thought the welded and balanced fans were more for high-rpm operation?
er, not quite, they'll make a noise and take half your ancilliary tinware with it. They are effectively 2 circular plates ( i know, i'm doing the simple analogy here) held together by vanes that are peened over only. there is only one bolt holding the lot onto the alternator / generator spindle. Any imbalance from losing a vane will quickly multiply and you'll be left with just the bolt and one plate on the charging aparatus spindle and quite a few rents elsewhere.
Technically, they are good to 5000 or so revs as with the stock fan belt, the belt will slip well before it reaches terminal angular velocity. people do rev them higher safe in the knowledge that their cooling won't get any more than the equivalent of 4000 ish revs but they can be seen as insurance.
If you want the best fan you can get, find a local shop with balancing equipment and get them to TIG your current fan without any wire, then balance it. |
sullydog93 Samba Member
Posted: Wed Jan 06, 2010 10:02 am Post subject: Brazilian fans |
The Brazilian welded/balanced fans are fair.
The metal seems weaker/thinner(?). They will
warp if you look at them wrong. I should have
had someone use the TIG torch on my old German
fan.
My OG fan had some wobble, about .050-.060. The
new Brazilian was worse - .060 - .100 . I used the
manual method to true it up, it still has a little more
wobble than the OG fan.
I suppose the torque generated from inertia will flex
the fan toward the flywheel and minimize the realized
warpage anyway? |
Ragman The Sambinator
RIS Samba Member
Joined: December 18, 2003 Posts: 3039 Location: Youngstown, Ohio
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55651 Location: Long Island, New York, USA
1961bluebug Samba Member
Posted: Wed Jan 06, 2010 2:03 pm Post subject: |
I also went with Jason Eggum´s OEM fan and just for my interest and safety I put the fan to my balancer. It was spot on and straight. _________________
|82x94|
1961 Deluxe sedan, 1971 type 181, 1973 Type 147 "Swiss Fridolin" |
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5219 Location: West Valley City, Utah
Posted: Wed Jan 06, 2010 2:08 pm Post subject: |
That's an incredible deal right there! The welds look fantastic too.
There are two 'brands' of OEM fans avaliable (or at least there was a few years ago when I worked in the industry). One with blue packaging, and what not appears to be bare metal, and one in a cardboard box that is bare metal. It looks like Jason is using the good fans which ROCKS! They're factory balanced and appear to be as nice as the German fans IMHO.
No way about it, that looks to be a great product, at an even better price. I don't really know Jason, but i'd stand behind what he's offering right there. Looks great! _________________ Eric Allred
10.29 @ 131mph
Utah's fastest and quickest VW.
Aircooled.Net
Blackline Racing (Formerly ACE) |
Bruce Samba Member
Posted: Wed Jan 06, 2010 10:10 pm Post subject: Re: Brazilian fans |
| sullydog93 wrote: |
warpage anyway? |
Did you smoke something before you posted this? _________________
| Glenn wrote: | | ..... and like them better than Bosch. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 5998 Location: Ocean Beach, California
Posted: Thu Mar 18, 2010 9:19 am Post subject: |
I'm building a 2007 engine and decided to go with a welded and balanced fan. I read this thread and took Glenns recommendation and purchased the Gene Berg fan. To be honest I think I'm sorry I did. It looks just like other welded and balanced fans sold here on Thesamba classifieds for less than $100. It even came in the same box that's pictured in those ads. The problem isn't the quality, it's the cost. The price was $120 but by the time I paid the $5 handling fee, tax, and shipping the total came out to be $147. I think that's pretty steep. Now, I don't know if Berg actually modifies these fans in house but I suspect they buy them and just resell them apparently making a huge profit. Please correct me if I'm wrong. _________________ Licensed Airframe and Powerplant Mechanic
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Type 2 1971 (2 ea.) 1978
VW Jetta
VW Passat
craigman Samba Member
Posted: Thu Mar 18, 2010 2:41 pm Post subject: |
| Only fan i have personally seen that has exploded was a welded one. |
J DUB Samba Member
Joined: February 15, 2004 Posts: 227 Location: HILO, HAWAII
Posted: Thu Mar 18, 2010 5:13 pm Post subject: |
| My unwelded OEM fan lasted 2 months before it let go. I picked up a welded Berg locally for $70 new. Should have grabbed 2 at that price. Its still holding with quite a few 7500 rpm shifts. |
junior55 Samba Member
Posted: Thu Mar 18, 2010 6:57 pm Post subject: |
| craigman wrote: | | Only fan i have personally seen that has exploded was a welded one. |
I not impressed with the weldeds that I have seen either...
Most of the welded fans that I have looked at have the little tabs that protruded through the side plates, burned down FLAT leaving a butt weld.
Now relying strictly on the somewhat carbonized welds to hold everything and not the mechanical interlocking of the metal.
All it takes is one bad weld and its all gone.
I would think that some precision brazing would be better because of the
lower heat and a non-destructive flow AROUND the crimped structure
to be much stronger.
Welded fans are scarry looking to me personally and I have just relied on
the "loose belt slip" to keep the revs from getting to the destruction point.
There is nothing to be gained by a fan that CAN spin at 10 grand anyway. |
Posted: Thu Mar 18, 2010 7:11 pm Post subject: |
yep, prob is when they weld it, it gets to hot. When metal gets that hot, it becomes brittle.
Dam'd if you do, dam'd of you don't kinda deals... |
pupjoint Samba Member
Posted: Thu Mar 18, 2010 7:32 pm Post subject: |
i have a Berg fan. but to be honest welded balanced fans aint rocket science, i am sure there are many good ones out there. Berg is good for many other parts, but welded fan is just a welded fan.
personally i prefer to use a german fan and get work done on it instead of brazilian ones.
then again quality may have changed now. |
jamestwo Samba Member
Posted: Thu Mar 18, 2010 7:41 pm Post subject: |
I think I have a scat 0r bugpack fan that only has every other tab welded.
It was 65 or 70 bucks.
BTW, it's been to 6500.
My Berg has hit 7200 rpm several times. I bought it in 2000 and it's been on 4 or 5 motors. _________________ hEY, lOOK, i'M WRONG HALF THE TIME, AND THE OTHER HALF i'M NOT SURE WHAT THE HECK i'M TALKING ABOUT. MY POST ARE FOR MY OWN ENTERTAINMENT VALUE ONLY. |
neil68 Samba Member
Posted: Thu Mar 18, 2010 10:22 pm Post subject: welded fan |
I've been running a Berg welded fan, based on an OEM German fan. A buddy of mine is a very experienced mechanic, hot rodder and welder, and he was impressed with the Berg welding quality.
Having had to re-weld some other VW parts over the years (that came apart due to suspect welds), I think we all realize that there are varying degrees of workmanship... _________________ Neil.
"Real men run drums."
Der Kleiner Rennwagens
68 Beetle 2332 cc
12.8 seconds @ 104 mph
http://www.youtube.com/watch?v=FF2gCti3dro |
MAYHEM Samba Member
Joined: January 30, 2006 Posts: 1869 Location: Warm and sunny coastal CT
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2515 Location: Rockford, IL
Posted: Fri Mar 19, 2010 10:21 am Post subject: |
| Is it possible to have a balanced fan that still has some wobble to it? |
