mcgyver06 Samba Member
Posted: Thu Jan 14, 2010 10:21 am Post subject: Help from some vanagon gurus. I'm perpelexed. |
Last week I started the van and drove it a few miles to the grocery store to pick up supplies for the weekend. When i came out it wouldn't start. It was cranking but very very slow. I tried to jump it. Same thing. I figured it was the started bushings. I changed the starter. Now it just makes that chunking noise. I can hear the starter kick in but it is not turning the engine. Maybe the cables? So I jumped past them to the starter. Same thing. I did all of the suggested tests to the starter and system with my multimeter. It is getting 12.9 volts to the starter which drops to about 9.9 while the switch is engaged and it is trying to turn the flywheel.
I also pulled the new starter back but left the wires connected, hit the switch and it cranks like crazy. I reinstalled the old starter, same thing, it cranks like crazy. I reinstalled it and even went so far as to connect my truck with jumper cables directly to the starter and ground, bypassing all of the other wiring. The voltage increased to 13.7 while connected to the running truck but still nothing. Occasionally it will turn the engine about a half turn or so and then nothing but that chunking noise.
I feel like I have eliminated, or bypassed, everything in the electrical system that could be wrong and the fact that it was running until I switched it off and the engine still occasionally turns a small amount (like it would if the battery were low) would indicate that it isn't seized up. So what gives? Has anyone had this kind of problem before? Am I completely missing something? Stupid?
Any help would be greatly appreciated. Thanks in advance! |
Posted: Thu Jan 14, 2010 10:26 am Post subject: |
The starter bushing is pressed into the bellhousing. Did you actually replace it, it is separate from the starter. They don't tend to suddenly disappear that I know of and the wear is slow not sudden. I guess they could fall apart though.
Have you tried turning the engine over by hand? Does it feel normal? What is the condition of your ground straps between the tranny and the frame and between the frame and the battery?
Bruskyvw Samba Member
Joined: May 30, 2009 Posts: 682 Location: Poulsbo, Washington
Welcome to the club. maybe my thread will be of some help to you.... I don't know how but I feel like I am having the same problem. and welcome to the samba
http://www.thesamba.com/vw/forum/viewtopic.php?t=393686&start=0 _________________ Current VWs: 2001 2.0 New Beetle 250k
1974 Super Beetle
Past vws: 1977 Champagne Edition I Bus (Cedar)1991 Capri Green Wolfsburg Jetta 1978 Sage Green(Taiga) Transporter 2.0 FI (Paddy) 1980 Inca Brown Rabbit Diesel LS 1969 Karmann (funky weird blue that wasn't original) Ghia Autostick 1991 Bordeaux Red Vanagon GL 1992 Tornado Red GTI 8V |
Posted: Thu Jan 14, 2010 10:33 am Post subject: |
Not to be jumping to the end conclusion before addressing the things that Wildthings suggested, but it is not uncommon at all for a rebuilt starter to be faulty. It may spin just fine outside of the vehicle, but any kind of load causes it to fail. Just something to keep in mind once you eliminate the other possibilities. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Thu Jan 14, 2010 10:35 am Post subject: |
Pull the spark plugs and see how easily the engine turns over with the starter without the plugs in place. I'm still thinking weak electrical at this point. The voltage drop should not be that large at the starter. Measure the voltage during cranking at the starter and at the battery. My voltage only drops to about 11.5 at the battery while cranking. If the difference at the two points is large, you have a bad cable. _________________ 89 Westy 2.1 Auto |
camerahunter Samba Member
Posted: Thu Jan 14, 2010 10:58 am Post subject: |
I've had this same problem with a 91 2.1 GL that I'm still fooling around with. Now it has an overheating problem. But, back to the starting problem. This happened to me early on. The water jacket seal began leaking, a bit of white smoke was coming out for the first few minutes of running, then go away.
On top of that the water pump totally died, wobbling, leaking, totally bad. I replaced that but the white smoke continued, got worse and the van would rung but on a short trip like you took I would come out and it would not start.
Once in a while just holding the key in the start position would get it to go over past the sticking point, fire up and go.
I tried revving it up good before shutting it off to blow everything out, reduce the pressure, and it would help it start again. If that didn't work I took a tire iron and moved the engine past the stuck point via the fins on the transmission, then start it. Eventually the smoke got so bad that I just parked it until this week. I now have the Subaru coolant conditioner in there, smoke is going away but I think the radiator is plugged up.
So, that's my experience and it's worth just what you paid for it.
David _________________ 1984 - Daily driver |
Vanagon Nut Samba Member
Posted: Thu Jan 14, 2010 11:02 am Post subject: |
Was there any difference in how the engine was starting and running prior to this?
Oil level ok? _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
Franklinstower Samba Member
Posted: Thu Jan 14, 2010 11:18 am Post subject: |
I second the idea of pulling your spark plugs and seeing if it spins faster. I had a hydraulic lock once from leaky injectors that had created similar starting symptons. removing the plugs and cranking it revealed the issue when gas was shot out the spark plug hole.
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Thu Jan 14, 2010 12:55 pm Post subject: |
camerahunter wrote: |
David |
David, in your situation, it is possible a cylinder was filling with coolant when the engine was off. The sticking point could have been the piston trying to compress the coolant in the cylinder. With a good starting system, you could probably bend a connecting rod if the cylinder was really filled up. Water can't be compressed, something has to give. Usually the connecting rod.
To the original poster, I would want to also remove the spark plugs and be sure I could turn the engine over by hand. _________________ ☮️ |
Posted: Thu Jan 14, 2010 1:07 pm Post subject: |
rsxr
Yes, that could be what was wrong. I don't think it had much coolant in there but some. The engine runs fine today, just a tad hot, little smoke, but nice and smooth.
For what it's worth all my troubles started with a simple get in, turn key, nothing, turn off, try again and it would go with no hesitation.
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Thu Jan 14, 2010 1:15 pm Post subject: |
Franklinstower wrote: |
Paul |
Voila...
You did the right thing by jump starting the starter directly with your truck.
2 possibilities
-Bad starter (i don't think so because the old has the same problem)
-Hydro lock.
Hydro lock is mostly cause by gas. Faulty injector or fuel pressure sender.
Good luck
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
Posted: Thu Jan 14, 2010 1:18 pm Post subject: |
A word of caution, if you expect the engine is hydralocked with gasoline, be sure to have the coil wire removed from the distributor cap and securely grounded. Cranking the engine, will explel the gasoline, but it also creates a very flamable environment. One spark and you could have a bigger problem. _________________ ☮️ |
Posted: Thu Jan 14, 2010 1:24 pm Post subject: |
If it's hydralock wouldn't the smell of gas be prominent?
Posted: Thu Jan 14, 2010 1:40 pm Post subject: |
Not as strong as you might think. Any engine that cranks but does not start that has a working fuel system would have a similar smell. You could pull the dipstick, most likely if a cylinder is filling with gas, it is washing past the rings and will be mixing with the oil. _________________ ☮️ |
Terry Kay Banned
Posted: Thu Jan 14, 2010 1:46 pm Post subject: |
<<<Hydro lock is mostly cause by gas.>>
Gas could do it Benny---but not as fast or as a hard lock as a coolant lock.
Coolant into a cylinder will lock her up tight as a fat ladies socks --right now _________________ T.K. |
Posted: Thu Jan 14, 2010 1:58 pm Post subject: Thanks for all of the suggestions |
To answer a few questions.
It was running until I shut it off.
I did install the starter bushing.
It has oil and is only about 1500 miles since the last change.
I checked the battery ground when I was trying to diagnose the battery/starter problem but I feel I took all of that out of the mix by trying to jump it from my truck directly to the starter.
I pulled the plugs this morning and, no I could not turn the engine easily. It did turn a bit but it was very difficult. I would imagine with no plugs and in neutral it should be easy to turn.
So I'm guessing this means something in the engine could be dragging or hung up correct?
Any other ideas? I really appreciate all of the help and suggestions. |
Posted: Thu Jan 14, 2010 2:04 pm Post subject: |
Easy is relative. If you could get a socket on the crank pulley with a long ratchet, the engine should turn through freely. If you were grasping the alternator pulley with you hands and trying to turn the engine, it would have some resistance. _________________ ☮️ |
Posted: Thu Jan 14, 2010 3:49 pm Post subject: Re: Thanks for all of the suggestions |
mcgyver06 wrote: |
As a point of reference, with plugs removed, using a 1/2" drive ratchet, it was relatively easy to turn my air cooled engine. Same for my Jetta 2.0 (currently installed).
Ok. So thinking this through "out loud"....
So oil level is ok right? If so, likely no hydrolock due to gas in crankcase.
Since engine is hard to turn by hand, some remote but easy to check possibilities:
engine and transmission bolted together properly?
Try turning engine with clutch pedal depressed. I obviously don't know the inside of the tranny very well, but if there was something hanging inside transmission causing input shaft to bind, (even when in neutral) this might make the engine harder to turn.
I know you swapped starters, but did you try turning engine with starter removed? Thinking that in spite of starter sound, starter pinion might be stuck in place (related to recent bushing install)
VE7TBN |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Thu Jan 14, 2010 10:13 pm Post subject: |
Ok, I'm no mechanic by a long shot, so don't laugh. But...
... your description (slow cranking with clunking noise) is exactly the symptoms I experienced when I cleaned my engine with a high pressure washer. I was in a rush and forgot to cover the distributor before I blasted away. All that occurred back in the summer. Then it happened again for a split second the other week. No problem since then, however. Coincidental with a bad fuel injector? Maybe my description will help you diagnose your problem. |
Dingchowping Samba Member
Joined: March 31, 2009 Posts: 134 Location: Seattle, WA.
Posted: Thu Jan 14, 2010 11:14 pm Post subject: |
Remove the lower cover from your steering column, disconnect the electrical connector from the ignition switch, bridge the red and red/black wires (make sure the van is in park/neutral first!). This triggers the starter. If it sounds normal (the engine won't actually start because there is no power to the ECU), replace your ignition switch. _________________ TTFN,
Adam
"For once you have tasted flight,
You walk the earth with your eyes turned skyward;
For there you have been,
And there you long to return."
-Leonardo da Vinci |
