Beetle hand start cranks
johnshenry Premium Member
johnshenry is offline
PostPosted: Tue Jan 19, 2010 7:03 pm    Post subject: Beetle hand start cranks Reply with quote
I have 3, and 2 have a handle end that has a bead rolled in the end, as does the rod under it to keep it captive, this is the more common style that I seen. But this one has a simpler design, with just a sleeve and small steel rings welded on either side of it to keep it captive.
Wondering if anyone has seen this style before, has one, or maybe has documentation showing it. It could be a homemade job, but the rod bends look very nice.
Any info would be great...
John Henry
'57 Deluxe
'56 Single Cab
ChrisRheinschild
ChrisRheinschild is offline
PostPosted: Wed Jan 20, 2010 10:13 am    Post subject: Reply with quote
The crank handle that came with my 25hp has the rolled bead. On the pulley end it has a guide pin that fits into the nut. This helps to place the crank to the engine. The engine is November 1952. I don't know if the crank is original to the engine.
79SuperVert
79SuperVert is offline
PostPosted: Wed Jan 20, 2010 10:19 am    Post subject: Reply with quote
I thought I read somewhere that the crank was dropped before 1950.
Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt.
PostPosted: Wed Jan 20, 2010 10:29 am    Post subject: Reply with quote
Cranks were dropped as standard equipment after '49, but offered as an option well after that. My '50 came from Sweden, and I was told that a lot of N European splits were ordered with the hand crank option.
John Henry
'57 Deluxe
'56 Single Cab
79SuperVert
PostPosted: Wed Jan 20, 2010 10:59 am    Post subject: Reply with quote
Thanks! Very Happy
Bengt H
Bengt H is offline
PostPosted: Wed Jan 20, 2010 1:22 pm    Post subject: Reply with quote
Thats correct, many Swedish -50 has the crankhandle but I have not seen many later splits with that.
Bengt H
Bengt H is offline
PostPosted: Thu Jan 21, 2010 7:22 am    Post subject: Reply with quote
I friend of mine has an late -48 with the same hand crank so I think its from that era. If it is for sale I am interested to buy it, I also has a -48 Razz . My june -49 has the normal style of crank.
PostPosted: Thu Jan 21, 2010 7:24 am    Post subject: Reply with quote
By "normal" style Bengt, you mean the kind with the bead rolled in the end of the sleeve/handle??
John Henry
'57 Deluxe
'56 Single Cab
Bengt H
Bengt H is offline
PostPosted: Thu Jan 21, 2010 7:29 am    Post subject: Reply with quote
If I understand your language Embarassed correct, yes. A pic would help.
johan_l
johan_l is offline
PostPosted: Thu Jan 21, 2010 12:50 pm    Post subject: Reply with quote
My early 51 (deluxe that lacks the ichias-vents and has a antenna bump and lever dampers) had a hole in the H-valance that looked factory and holes in bumper indicating a riveted crank bracket... Though the car was in very bad condition... will bring parts of it back to life... Will a industrial engine crank handle fit? The engine will also be a industrial 30 hp one...
Johan, Sweden
1960 Karmann-Ghia coupé
1957 Oval window
Bastard Split window <-- Translate
PostPosted: Thu Jan 21, 2010 1:14 pm    Post subject: Reply with quote
The industrial and bus cranks (far more common) are too short for the Beetles. I do know of someone who will be reproducing the Beetle cranks hopefully in the next month or two.
John Henry
'57 Deluxe
'56 Single Cab
volksartist
volksartist is offline
PostPosted: Thu Feb 03, 2011 11:02 am    Post subject: Reply with quote
Does anyone know when the crank start option was offered until.
A local guy has a 54 oval with a crank start set-up and his father
was the original owner. I did not ask him if it came from the factory
that way?
GüteAndTite
Early Convertible Güru
GüteAndTite is offline
PostPosted: Fri Dec 30, 2011 8:17 pm    Post subject: Reply with quote
bump, x2
Official 58-60 "Early Big Window" Convertible Thread & Registry
http://www.thesamba.com/vw/forum/viewtopic.php?t=426481
F&S Saxomat Automatic Clutch System Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=462533
61-67 Delanair Air conditioning Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=457944&highlight=air+conditioning
PUNCTUATION CHANGES THE WORLD: "I need to help my uncle, Jack, off a horse" is way better than, "I need to help my uncle jack off a horse"
PostPosted: Fri Dec 30, 2011 9:03 pm    Post subject: Reply with quote
I heard that they were offered into the early 60s, but don't know that for certain.
John Henry
'57 Deluxe
'56 Single Cab
GüteAndTite
PostPosted: Fri Dec 30, 2011 9:33 pm    Post subject: Reply with quote
what are the measurements for a beetle crank? is there more than one size of beetle cranks (like for vw going from banana bumpers to blades in 53)?
