speedygeorge Samba Member
Joined: November 28, 2009 Posts: 205 Location: Victoria, BC
Posted: Sun Feb 14, 2010 11:35 am Post subject: What sound do rear wheel bearing make when worn out? |
| I was told by my local shop that rear wheel bearings need replacing, what sound will they make when worn out? |
Timwhy Samba Member
levi Samba Member
Joined: February 11, 2005 Posts: 3283 Location: Las Vegas
Posted: Sun Feb 14, 2010 4:30 pm Post subject: |
The noise changes as the damage progresses, and it doesn't have to be a constant noise. You could get a squeak squeak through half the rotation of the tire at slow speed.
If you find a spot to coast at about 30 mph you should notice a change in the noise as you alter your direction. Depending on which side is going out, you could have almost no noise with a slight right turn, changing to the grinding as you make a slight left, etc, but this depends on the stage of bearing failure. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way |
Posted: Sun Feb 14, 2010 7:10 pm Post subject: |
| levi wrote: | The noise changes as the damage progresses, and it doesn't have to be a constant noise. You could get a squeak squeak through half the rotation of the tire at slow speed.
If you find a spot to coast at about 30 mph you should notice a change in the noise as you alter your direction. Depending on which side is going out, you could have almost no noise with a slight right turn, changing to the grinding as you make a slight left, etc, but this depends on the stage of bearing failure. |
The shop says they can something, but I can't hear anything, except perhaps my credit card crying. Would it be OK to wait until I can actually hear something, or would I be doing any damage? |
levi Samba Member
Posted: Sun Feb 14, 2010 7:27 pm Post subject: |
Once it starts making noise, you can let it go for months, it will very gradually get noisier. Your cost then will be the same to fix it. _________________ One of these days I'm gonna settle down,
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 1833 Location: Socorro, Nuevo Mexico
Posted: Sun Feb 14, 2010 8:20 pm Post subject: |
starts as a high pitched whistle. you hear it bouncing off hard vertical surfaces like guardrail posts, or concrete barriers
when it sounds like an old school coffee percolater, you got troubles, Bubba _________________ 73 Beetle, Ghia front brakes, Type 3 rear brakes, 1776, Solex 34 Pict-3, Bosch SVDA, '97 Mustang seats
[77 Westy M plate decoded]
Baja Bugs for Volkswagen Virgins: Index |
randywebb Samba Member
Joined: February 15, 2005 Posts: 3215 Location: Greater Metropolitan Nimrod, Orygun
Posted: Sun Feb 14, 2010 9:12 pm Post subject: |
go to radio shack and get a small cheap microphone - tie it so it is near the wheel bearing & connect to a recorder or amp & listen
see if some other spots produce a louder noise - CV joints; other wheel bearing; or gf |
Timwhy Samba Member
Posted: Mon Feb 15, 2010 2:57 am Post subject: |
Can you jack up one side and move the wheels yourself. Make sure it's not in gear or e-brake on. You may be able to feel some sort of resistance.
I'm pretty sure you would hear them if they were bad, but then maybe not.
Getting back to jacking it up. See if you can move the wheel back and forth while grabbing the left and right sides of the wheel. Is it loose? Is the axle nut tight or alittle slack. Does it have the pin in it?
I had a garage tighten my axle nuts down when mine started making noise. The noise went away for about a week, then I knew they would have to be replaced at some point.
If you can do the work yourself terriffic. If not and you need all barings replaced, this job may very well cost you $400-$500. Once you have them replaced though they will be smooth as silk.
Good Luck! _________________ '09 VW Tiguan
'87 VW Westy
http://www.youtube.com/user/TIMWHY2?feature=mhee |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 722 Location: Anchorage, AK
Posted: Mon Feb 15, 2010 11:09 am Post subject: |
| Never lost one in a VW before, but a few in Subarus. Just sounds like extra road noise, like someone is slowly stealing all the sound insulation from the car. After a few months it will occur to you that there is no insulation to be stealing, and the radio level is giving you a headache, and you will have to figure out which side it is and go to work. If you wait tooooo long it could pound out the hub. |
