zaidigonzo Samba Member
Joined: July 30, 2006 Posts: 305 Location: Punta Gorda, FL
Posted: Sun Feb 28, 2010 7:53 pm Post subject: does a type 1 dual carb 2300+cc engine fit in a 914?? |
looking to get a 914 soon,
I have a 65 kombi and have had a ghia and a 64 bug. I have a spare 2300 cc bug engine and if I get the 914, I was thinking I could swap for more power. This 914 has a stock 1.7liter type 4 with dual 40 webers
Been trying to check out raby's site to see how much a strong type 4 long block costs but web site is not working..
Any suggestions??
Thank you
also have a euro 930 turbo, lsd, k27hfs, headers, rarly muffler, B&B intercooler and fabspeed airbox filter/eliminator, 1 bar spring and digital WUR with innovative afr 16/1gauge |
Posted: Sun Feb 28, 2010 8:01 pm Post subject: |
71 914 stock engine and tranny. converted to "side shift" |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Mon Mar 01, 2010 4:47 am Post subject: |
Flywheel, clutch and starter will be issue! I'll swap you a '75 1.8L 914 core for that 2300cc though! _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
TC/TeamEvil Samba Member
Posted: Mon Mar 01, 2010 7:22 am Post subject: |
It'll fit, depending upon the year of the 914 that you get. The earlier 914's have the same diameter flywheel as the VW.
If the VW engine has a universal case or is one from a VW Bus, you can use the '68 to '71 bus engine mount/crossmember as a base for securing it in the 914 engine bay, otherwise you'll either have to drill and tap the case or use one of those adapter plates that bolt over the oil pump cover. Sometimes these can cause a leak, if you use a torque strap to limit the engine movement it will help.
You' need to make up some aluminum filler sections to seal the engine compartment, but that's a snap, as is the exhaust.
Otherwise, it's no big deal. Just fabrication. Not entirely sure how the transaxle gearing is going to work with the engine, but so what, just get on with it you'll find out later.
Luck,
TC |
Posted: Mon Mar 01, 2010 7:44 am Post subject: |
Checkout great info at tunacan.net
"The 914/912E flywheel had a 215mm diameter face and used a unique pressure plate and disc to mate it to the Porsche transaxle. This flywheel differs from the VW flywheel in that the starter ring gear is offset differently and will cause a VW starter not to engage properly"
Issue is not the flywheel diameter but the offset of the external starter gear and the depth of the contact surface and diameter/height of clutch/pressure plated and throw out bearing. I've not tried it but if attempting it I'd surely mock it up on the ground before expending countless hours under car on your back. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Posted: Mon Mar 01, 2010 8:42 am Post subject: |
. I guess Il wait til the 1.7 dies before doing anything. Il just put that vw engine on the 65 bus after I do the long axle/gear redux delete conversion.
Thank you very much! |
Posted: Mon Mar 01, 2010 11:18 am Post subject: |
I don't imagine that the off set is TOO great since I used a VW semi automatic starter in my 914 and it worked wonderfully.
Not important anyway, sounds like the original poster is going to the fall back position. Too bad, this one seems like one worth pursuing since I bet a whole bunch of folks have considered this idea as an option. I know that I have . . . |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Thu Apr 08, 2010 7:46 am Post subject: |
TC/TeamEvil wrote: |
Starter isn't the problem; it the location of the flywheel ring gear on the 914 flywheel vs the location of flywheel ring gear on T1 flywheel...
... regardless, the OP is going another route.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
