BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 757 Location: KANSAS toto's fire hydrant
Posted: Mon Sep 28, 2009 3:36 pm Post subject: |
What is the size of bolt for a 66 type 1 steering stop . This bolts to the welded area on the beam that is adjustable for the steering arm to stop against when you turn the steering to the max. Best I can explain. _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1964 split window bus
1966 VW bug
1969 Dune Buggy
1971 Westfallia camper bus
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1422 Location: J-ville, FL
Posted: Thu Jan 14, 2010 9:20 pm Post subject: |
Maybe not technically appropriate, but I get constantly asked. Hurst shifter knob/shaft thread size= 3/8 X 24. _________________ Looking for aluminum single port Kadron manifolds. |
tirekicker Samba Member
Joined: October 16, 2007 Posts: 757 Location: Orange, CA
Posted: Wed Feb 03, 2010 6:34 pm Post subject: |
 _________________ DhK
Phuckancer
(16:45:42) Russ_Wolfe: TK, you are like a Maytag washer
(16:46:44) tirekicker: and what's a maytag washer?
(16:47:35) Russ_Wolfe: If you are not agitating, you are not working right |
volksheime Samba Member
Joined: October 23, 2005 Posts: 140 Location: Wisconsin
Posted: Tue Feb 23, 2010 2:54 pm Post subject: |
Wide Five early Lugnuts/ Lug bolts are M12 x 1.50
I needed this because the torque meister wont allow for lug nuts to attach it to drums (too short) |
tstracy39 Samba Member
Joined: May 14, 2008 Posts: 3245 Location: West Philadelphia, PA
Posted: Thu Mar 04, 2010 3:34 am Post subject: |
1967-71 VW Beetle/Ghia gear shifter knob: 7mmX1.0
68-79 Beetle/Bus/Ghia/Thing shift knob: 12mmX1.5
Outside diameter of 8mm case savers: 12mmX1.5 _________________ Check my classifieds for kewl gauges:
http://www.thesamba.com/vw/classifieds/search.php?username=tstracy39
| EverettB wrote: |
| I like your fork. |
dsmetanick Samba Member
Posted: Fri Oct 08, 2010 9:15 am Post subject: |
| Please advise: What is the drill bit size needed to change my 12mm break drum lug bolt threads to 14 mm threads? Note I do not want to install press in studs (which is a bigger drill bit, I want to install either lug bolts or screw in studs). What is the pitch of the tap? Is the tap a 14 mm? I appreciate your advice. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25689 Location: Central Iowa
Posted: Fri Oct 08, 2010 10:19 am Post subject: |
The late model lug bolt thread pitch is 14x1.5mm. (considered fine thread) The tap drill is 12.5mm _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Ea$y Money Samba Member
Joined: August 26, 2006 Posts: 133 Location: San Diego, CA
Posted: Sat Apr 30, 2011 3:21 pm Post subject: |
can anyone help find what size bolts/screws i might need. it's the hardware for the steering column support that attaches underneath the dash for a '66 bus. it requires 4 bolts/screws. i think there are 2 different sizes. just to clarify, its the piece you always hit you knee on when getting into your bus. thanks! _________________ 1966 Microbus Deluxe |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 1266 Location: Twin Cities, MN
banditwolf Samba Member
Posted: Tue Nov 08, 2011 4:17 pm Post subject: |
From my 73 Super Beetle
Door hinges: 8 x 1.25 mm (threads approx 10mm), tapered head screw
Door latch: 6 x 1.00 mm (threads approx 8mm), tapered head screw _________________ 1973 Super Beetle l 1981 Trans Am |
vacajar Samba Member
Posted: Wed Mar 07, 2012 6:31 pm Post subject: Engine mount bolt size |
| Im looking for the engine mount stud size for the back of the case and also the the top bolt on the drivers side. If it changes anything it is a Mexico Block From 73. Thanks |
Empicollector  Samba Member
Joined: March 02, 2002 Posts: 320 Location: Seattle, WA
Posted: Sat Apr 28, 2012 2:26 pm Post subject: |
| How about the size of the bolts in the end of the steering box? The ones that will scrape if you are lowered----lol. On a 67 type 2 |
Tucky Samba Member
Joined: April 24, 2012 Posts: 15 Location: Puerto Rico
Posted: Wed May 02, 2012 7:39 pm Post subject: |
Hello.
I'm looking for the size of the bolts that attach the bumper brackets to the body
Thanks. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 55841 Location: Long Island, New York, USA
Posted: Wed May 02, 2012 7:41 pm Post subject: |
| Tucky wrote: |
Hello.
Thanks. |
What vehicle?
M8x1.25 would be the most common. _________________ Glenn
HBB/RW
www.DasVolks.com
Long Island's Aircooled Club |
19super73 Samba Member
Joined: October 18, 2007 Posts: 3756 Location: Cité Soleil
Posted: Thu May 03, 2012 7:05 am Post subject: |
He's got a '72 SB. _________________ '73 Super Beetle w/ all the Sport Bug extras
'75 La Grande Beetle, 1st in Class, Das Volks 2011
'75 110 Standard Beetle
'71 Doublecab
'73 412 wagon "Nasenbär" 1st in Class, Das Volks 2012
| Glenn wrote: |
| Only a hack would have to take the rear apron off to remove a stock engine. |
| JerryMCarter1 wrote: |
If it is something just stuck eventually it will wear down and go away.
Run it for awhile and see if it gets quieter |
Tucky Samba Member
Posted: Fri May 04, 2012 4:03 pm Post subject: |
| Thanks a lot. Im going to the hardware store tomorrow to buy them |
Pepo Samba Member
Joined: December 22, 2009 Posts: 21 Location: Ketucky and Florida
Posted: Fri May 18, 2012 5:17 am Post subject: Only metric sizes on the origianl VW? |
Well, I just came back from Europe, had a great time and some interesting discussions. Among them was a statement from a friend wo is a long-time mechanic, mostly Mercedes. He maintains that all items on the original VW, i. e. Beetle were always metric. I challenged that by quoting the wheel sizes as 14 inch or 15 inch. He denied it and claimed that they are in metric conversions. I also quoted my experience with the oil pressure sensor connection to the block that I always found to be 1/8" NPT (National Pipe Thread). Can anyone verify my opinions and give me a source to copy?
Thanks, _________________ Take care and have fun..... |
jehugarcia Samba Member
Joined: October 15, 2012 Posts: 241 Location: Rancho cucamonga
Posted: Fri Nov 16, 2012 2:36 am Post subject: Cargo door hinge screws |
Type 2 bus Cargo door hinge screws size is 8 X 1.25mm
you can find the tap at McMastercar part # 8305A19 Metric High-speed Steel Hand Tap, Taper, 8 X 1.25mm, D5 Pitch Dia, 4 Flute
and the Drill bit for the tap is item # 2958A113 Metric Black Oxide Hss Jobbers' Drill Bit, 6.7mm, 101mm Oal, 49.6mm Drill Depth,118 Deg Point
Now does anyone know what size the Engine lid hinge screw thread size is? I need to clean the threads on mine.
campingbox  Samba Member
Joined: November 14, 2000 Posts: 8098 Location: Olympia, Washington
Posted: Fri Nov 23, 2012 11:30 am Post subject: Re: Cargo door hinge screws |
| jehugarcia wrote: |
6mm X 1.0 |
germansupplyscott Samba Member
Posted: Wed Dec 12, 2012 9:34 pm Post subject: Re: Only metric sizes on the origianl VW? |
| Pepo wrote: |
Thanks, |
oil pressure switch threads are m10 x 1.0 straight, not NPT.
the only inch fasteners on a VW are the seat belt hardware which are all 7/16" -20. _________________ scott lyons
http://www.germansupply.com
VW Bus-Centric Online Parts Source |
