places for Hi-Lift jack
Goto page Previous  1, 2, 3, 4  Next
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
Alaric.H
Alaric.H is offline
PostPosted: Thu Mar 25, 2010 6:25 am    Post subject: Reply with quote
There are many ways to adjust rope. I just pulled a 14000lb 40ft boat off a rocky beach in FL with these and rope plus a come-along. You just need to find one with a high load rating.
http://storrick.cnchost.com/VerticalDevicesPage/Misc/RopeGrabPages/RopeGrab710.html
Jon_slider
Jon_slider is offline
PostPosted: Thu Mar 25, 2010 9:15 am    Post subject: Reply with quote
> The pin should be in the tow hook. This keeps the possibility of the pin unscrewing down. A 3/4 shackle with a higher WLL can be used as well.
thanks! learned something new, and yes, I confirmed the 3/4 shackle fits the way you pin it.. at the rear of the van.
The 3/4 shackle wont work with the pin thru the front tow loop, it will install but rides too far back from the actual loop.. Image may have been reduced in size. Click image to view fullscreen.
the 3/4 shackle will work with the D ring thru the front tow loop.. (and the pin should be half a turn loose to prevent it getting overtightened by the pull)
randywebb
randywebb is offline
PostPosted: Thu Mar 25, 2010 5:24 pm    Post subject: Reply with quote
Alaric.H wrote:
Screw chain use Hi tech rope its lighter and safer plus stronger and it will not stretch.
you mean the stuff that Gator Supply sells for ocean going ships?
or what, exactly?
Alaric.H
Alaric.H is offline
PostPosted: Thu Mar 25, 2010 7:18 pm    Post subject: Reply with quote
or what, exactly?
http://www.okoffroad.com/stuff-winchrope-atv.htm
squeegee_boy
squeegee_boy is offline
PostPosted: Thu Mar 25, 2010 9:25 pm    Post subject: Reply with quote
The synthetic stuff is amazing and waaaay safer than chain/cable, but it's not UV safe, so keep it stored out of the sun. A heavy bag is fine for this, or any cabinet inside the van.
Robyn
1984 FrankenSyncro Westy. Now with a Bostig Turbo!
1990 GL, still with a 2.1L. For now.
DRZ-400SM
Jon_slider
PostPosted: Thu Mar 25, 2010 10:17 pm    Post subject: Reply with quote
> what exactly
from page 1:
http://tinyurl.com/yelwh6x Image may have been reduced in size. Click image to view fullscreen.
read page 2 for a link to 3/4" D rings rated for the same load as the winch line extension, strong enough to hold two of Alaric's Syncro Beasties
SyncroGhia
SyncroGhia is offline
PostPosted: Fri Mar 26, 2010 4:20 am    Post subject: Reply with quote
I had the wheel carrier design modified (when it was built) so I could make up my own brackets and add my high lift jack to that.
http://www.brick-yard.co.uk/forum/limey-the-syncro-16-25tdi-westy-330mm-brakes_topic8602_page1.html
MG
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Orbitald
Orbitald is offline
PostPosted: Fri Mar 26, 2010 12:55 pm    Post subject: Reply with quote
>SyncroGhia: One of the nicer mounts I have seen.
Thx!
'87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing
sc-surfer
sc-surfer is offline
PostPosted: Fri Mar 26, 2010 1:39 pm    Post subject: Reply with quote
Just out of curiosity...What role did the breaker bar rack play in a winching operation? That's a breaking device, not a pulling device.
'89 Syncro Westy
Catalog of Vans at SDM 2010
Westfalia, Syncro & Tristar Reproduction decals here.
* * * Coming Soon: Washable seat covers for westy bench seat...keep the pets off the upholstery! * * *
chimivee
chimivee is offline
PostPosted: Mon Mar 29, 2010 4:48 pm    Post subject: Reply with quote
Regarding using the Hi-Lift as a winch: The Hi-Lift videos state that either chain or tow strap can be used on both ends. How does it work with a strap on the side that winches? How would the strap be shortened after each winch "cycle?"
-James
86 Syncro Westy, etc
Jon_slider
PostPosted: Tue Mar 30, 2010 9:43 am    Post subject: Reply with quote
You can use a Hi lift Jack with a strap at EITHER end, but NOT BOTH ends at the same time. You are correct, if you dont use chain at one of the ends, you would have no way to adjust the length of the pull.
here is an alternative to the hilift as a lifting tool
titan air jack, cost about $129
http://www.northerntool.com/shop/tools/product_200335091_200335091
Xjack (cost about $239) video
http://www.youtube.com/watch?v=CqBQ8q2mxuY
and an old post about the magnum hand winch and building a recovery kit, with links to parts suppliers
http://www.thesamba.com/vw/forum/viewtopic.php?t=343910
chimivee
chimivee is offline
PostPosted: Tue Mar 30, 2010 11:32 am    Post subject: Reply with quote
SyncroGhia wrote:
Very cool. Like the chimney-snorkel too!
-James
chimivee
chimivee is offline
PostPosted: Tue Mar 30, 2010 12:16 pm    Post subject: Reply with quote
Ok, gotcha.
-James
randywebb
PostPosted: Tue Mar 30, 2010 1:15 pm    Post subject: Reply with quote
Jon_slider wrote:
anyway to just buy the black slip-on pieces shown, instead of the entire ORK??
http://www.hi-lift.com/accessories/off-road-kit.html
1986 2.1L Westy 2wd Auto Trans.
tozovr
tozovr is offline
PostPosted: Tue Mar 30, 2010 3:05 pm    Post subject: Reply with quote
Robyn
THANK YOU!
NEVER pull with Chain. NEVER. Never pull or tug with cable from a winch. Chain and cables are not designed for shock loads in a recovery situation.
Mounting a Hi-Lift outside the rig is good if you keep it free of debris and grit. If you live here in New England it MUST be bagged or just kept inside.
It does look pretty beefy to run them on the bumper or rack, but you will pay the price when it comes time to use it down the road.
This is coming from my 20+ years involved in Rovers, Cruisers and Jeeps and the recoveries that are always happening. been to many driving schools and taught many seminars on this stuff.
Be SAFE. PLEASE.
Before you just slap that high lift on the Vanagon, please read the manual. Read Bill Burke's Hi Lift How to stuff. Try the jack out on the van. Find out where you are comfortable.
ALWAYS LEAVE THAT HANDLE UP! We actually use Velcro straps to affix the handle to the Jack when between movements with it. I have seen too many accidents.
Be Safe.
Did I mention chain sketches me out? Smile
...like a young Julie Andrews all whacked out on PCP, kinda fun but kinda scary too
'83 1.6TD
DX 5 Speed
"Whistler"
www.sinisterbikes.com
chimivee
chimivee is offline
PostPosted: Tue Mar 30, 2010 3:20 pm    Post subject: Reply with quote
Here is one DIY method:
Full instructions and pics:
http://www.overland.co.za/Recovery_Gear/Morne_Stevens/index.html
http://www.overland.co.za/Recovery_Gear/Morne.html
-James
chimivee
chimivee is offline
PostPosted: Tue Apr 13, 2010 3:54 pm    Post subject: Reply with quote
So, I decided to mount my hi-lift inside the van. It sure doesn't look as cool as having it on the outside Crying or Very sad , but it stays out of the elements, away from thieves, and off my van's already laden ass-end. Passenger seat can slide/recline all the way back and curtain operates normally.
It's about as simple as I could make it (although it took my feeble mind a lot of Home Depot time, staring blankly in the parts isle to figure it out). Just a couple of basic corner braces, some hardware, and a little cutting/drilling.
The base of the jack is cupped by the braces on the floor, and then a 1/2" bolt/spacer through the standard secures it quite solidly.
It's very unobtrusive. Plus next to it is normally a tool box (or porta-potty if GF is along), so it was otherwise unusable space.
Gave it a nice test run last weekend in the desert and it never moved… inadvertently or purposely Smile.
-James
Jon_slider
PostPosted: Wed Apr 14, 2010 7:33 am    Post subject: Reply with quote
"recovery" can mean yanking, but it can also mean winching
"pull" can mean yanking, but it can also mean towing
When using the HiLift as a Winch I think you will agree, you DO want chain or winch line, that does NOT stretch..
And when towing you also want chain or winch line that does NOT stretch.
The time for a stretchy pull with a snatch or recovery strap is when you are jerking the load, like when one vehicle connects a snatch strap to another, leaving the strap slack, and then takes a running start to yank the stuck vehicle out.. stretch is your friend there..
But stretch is not your friend when using a HiLift to winch or pull.
notice they use Chain, you do NOT want to use a Hi Lift with a recovery strap that stretches.. only with a non stretching Tow strap.. or sometimes you use a tree strap to anchor the HiLift, tree straps do not stretch like recovery straps
tozovr
tozovr is offline
PostPosted: Wed Apr 14, 2010 7:54 am    Post subject: Reply with quote
http://www.youtube.com/watch?v=CPmu7fsqC6w
http://www.youtube.com/watch?v=iQTVO6-LNXc
notice they say "chain or tow strap", a tow strap does not stretch like a snatch strap or "recovery strap" (however in the video they say tow strap one time, and then misuse the term recovery strap later.. you do NOT want to use a Hi Lift with a recovery strap that stretches.. only with a non stretching Tow strap
I would never use a chain to winch...using a Hi-Lift or an actual winch. Use an approved cable or Poly rope.
As an aside, anyone who actually winches using their hi-lift must be in dire straights...or have a TON of time on their hands LOL.
'83 1.6TD
DX 5 Speed
"Whistler"
joseph928
joseph928 is offline
PostPosted: Sun Jan 29, 2012 9:02 pm    Post subject: HI lift Reply with quote
Blue Bay Bus On my syncro I cary the jack in my roof rack hold it down with 2 yakima straps works good! Very Happy
1987 syncro westy tin top sun roof GW2.3 rear locker decoupler custom bumper roof rack Gary Lee tire rack lift south african grill big brakes rhein alloy 15 BFG AT 617 gears ShadyBoy awning 140 watt rear 85 watt front solar mppt truckfridge automatic fire extinguishing system - 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley - Dodge 4500 4x4- 1987 tin top westy Jetta 2.0 ABA 1.8 head, 55 watt solar automatic fire extinguishing system -Just sold my 84 Westy
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 3 of 4
