mabirec Samba Member
Joined: March 29, 2010 Posts: 5 Location: baker, florida
Posted: Mon Mar 29, 2010 9:01 am Post subject: will 72 super beetle doors fit on a 71 vw beetle? |
i am trying to make a volksrod and i have a rusted out 71 vw bug and a 72 super bug the super bug is in good condition but the 71 is rusted at the doors, can i take the super beetle doors and put them on the 71?
also can i take the super beetle's floor pans and put them in the 71 regular bug? thanks |
letthemusicflow Samba Member
redrum71 Samba Member
Joined: August 07, 2006 Posts: 494 Location: No-wheresville KS
Posted: Mon Mar 29, 2010 9:42 am Post subject: |
As far as I know Every bug 68+ is the same from the door post back, I may be wrong, But i'm pretty sure you can swap them with no hassles _________________ 72 FAT chick
71 baywindow -
67 Baja |
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Mon Mar 29, 2010 12:44 pm Post subject: |
Yes.. 68 & up all fit, But 68-70 have the smaller indent behind the door handle so if you use those years you mite wont to change both doors.. I have 69's on my 72 super. |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
tele68 Samba Member
Joined: September 18, 2009 Posts: 389 Location: New Jersey
Posted: Mon Mar 29, 2010 12:50 pm Post subject: |
A true rod won't have armrests or inner door panels anyway?? _________________ '72 Super Beetle
Central Jersey Volkswagen Society |
Posted: Mon Mar 29, 2010 1:00 pm Post subject: |
19super73 wrote: |
68+ doors fit, the only thing that changed was the arm rest in '73. If you had a '74 door and wanted it on a '70 but wanted to keep the '70 armrest, a little playing around would have to be done. |
Yes your right,, I have the 74 arm rest,, my cars A mutt! 72 super, 69 doors, 74 arm rest.. there not to hard to retro fit.. I like the 74+ arm rest! |
allsidius Samba Member
Joined: February 02, 2010 Posts: 1475 Location: Norway
Posted: Tue Mar 30, 2010 12:23 am Post subject: |
If the super is rustfree, why dont you rebuild that car. A 70s standard that is rusted out will never be a holy grail anyway. Good doors wont help, the rest of the car is probably just as bad. And you dont take pans out of a fresh car, you buy replacements. Its 40 years since the supers debuted, its about time to accept them as true beetles and the ultimate evolution of our favorite car. |
zeroman Samba Member
Joined: February 05, 2010 Posts: 891 Location: Cane field
Posted: Tue Mar 30, 2010 12:55 am Post subject: |
ha ha.. yea.. I guess some don't consider em ..
yea.. the doors fit just fine. The hoods on 71-72 won't fit "real" supers but the back bits are all the same.
I am curious about these floor swap things people talk about.
How the heck do you get them out in one piece worth using? Probably be doable with the body off.. but having just replaced my pans.. I can't imagine trying to get them out in good condition.
The pans are so cheap.. and so repairable... one or the other seems much easier. |
Neil Davies Samba Member
Joined: July 31, 2005 Posts: 393 Location: Kidderminster, West Midlands, UK
Posted: Tue Mar 30, 2010 2:15 am Post subject: |
vw_hank wrote: |
Exterior door handle? AFAIK the outer skins are all the same from '68 up. The inner skins changed as said before to change the arm rest (late has plastic inserts to bolt the arm rest to, early has the rest bolted to the door card which hooks on the door. _________________ '67/'68 Cal Look Beetle, 2007cc, 48IDFs, 14.4 @ 93mph, Oct 2017.
'68/'70 Karmann Beetle, wife's project, progressing slowly.
'80 Devon Moonraker, wife's ratty but cool toy.
'86 Scirocco special project - still measuring up... |
Posted: Tue Mar 30, 2010 2:30 am Post subject: |
Neil Davies wrote: |
vw_hank wrote: |
Exterior door handle? AFAIK the outer skins are all the same from '68 up. The inner skins changed as said before to change the arm rest (late has plastic inserts to bolt the arm rest to, early has the rest bolted to the door card which hooks on the door. |
that is wrong, the outer door skin is not the same.. the door has A smaller indent behind the door handle on 1968-70 |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sat Apr 03, 2010 8:42 pm Post subject: |
Let me get this straight ... 68+ doors will work now will door panels off a 71 standard swap with a 74sb and vise versa , or are the arm rest diferent ........I just don't get it but I'm getting there.! |
Posted: Sun Apr 04, 2010 3:39 am Post subject: |
vw_hank wrote: |
vw_hank wrote: |
I stand corrected! It must be a very small difference, not like the change from '67 to '68, which is huge! After 15 years of pretty much immersing myself in everything VW, I'm still learning! _________________ '67/'68 Cal Look Beetle, 2007cc, 48IDFs, 14.4 @ 93mph, Oct 2017.
Posted: Sun Apr 04, 2010 8:50 am Post subject: |
68IHscout wrote: |
68 and up are the same, most of the aftermarket ones are universal and well fit 65 & up. but the arm rest are different, thy changed in 74. I got them to work in my 72,, i just modified the mount A little.. |
