Taffy Samba Member
Joined: August 05, 2007 Posts: 48 Location: South Wales UK
Posted: Sat Apr 03, 2010 8:48 am Post subject: Rear axle nut R/H or L/H thread? |
Hi,
I know I'm not the first to ask, but are the 46mm rear axle castellated nuts Right hand or Left hand thread? There are conflicting answers on the forum, and I haven't been able to find anything in the Bentley Manual.
(1972 Westfalia) I've just spent a few hours using a 4 feet cheater bar and my 210lbs trying to loosen them off but to no avail. (Tried both directions!)
Cheers |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 03, 2010 8:49 am Post subject: |
RH thread, keep beating. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Mountain Minstrel Samba Member
Joined: September 03, 2009 Posts: 979 Location: Sonora, CA
Posted: Sat Apr 03, 2010 10:18 am Post subject: |
Keep trying...it took my whole family of four (the two kids probably only weighed 80 between them) bouncing in unison on a 4' cheater bar. The driver’s side was easier as we could hold on to the bus for balance. I am sure that the neighbors got a great laugh out of it. _________________ Ken
69 Westy
99 S-10
04 Miata (Sold)
Desertbusman wrote: |
Maintenance doesn't mean repairing it when it breaks. That's called repair. |
miniman82 wrote: |
Don't listen to him, people from Fresno are retarded. |
wampe Samba Member
Posted: Sat Apr 03, 2010 11:46 am Post subject: |
I will send my 600 pound gorilla!.......I was lucky, was able to get them off by myself. The brake drums came right off also. Someone had been careful to grease everything when it was last apart. |
Justin Samba Member
Posted: Sat Apr 03, 2010 3:32 pm Post subject: |
I use the Empi axle nut tool and a maul. Works great but you have to watch out for the paint on the wheel and the fender. _________________ "I am convinced that [nothing] in all creation will be able to separate us from the love of God that is in Christ Jesus our Lord."
-Romans 8:38-39 |
SGKent Samba Member
Posted: Sat Apr 03, 2010 3:54 pm Post subject: |
Empi style tool. We broke a 1" breakerbar without one trying to get one of ours off. The problem is that you need a shear force spike to start it and only something that you can keep pressure on and at the same time put a good blow from a hammer into works. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
wampe Samba Member
Posted: Sat Apr 03, 2010 3:57 pm Post subject: |
I used an iron 24" pipe wrench with a 2 1/2" by 36" sch. 80 pipe on the end for a cheater bar. Nothing even came close to bending. It popped the nuts right off. |
Posted: Sat Apr 03, 2010 4:26 pm Post subject: |
wampe wrote: |
In my case the drum on the driver's side came off real easy as it had spun. The passenger side still wasn't that difficult to get off (a true piece of cake compared to four people trying to balance and jumb on that cheater bar in unison). It is twenty years later and both of my daughters remeber that event. don't ever say that buses don't provide lasting memories, _________________ Ken
69 Westy
99 S-10
04 Miata (Sold)
miniman82 wrote: |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3579 Location: viroqua wi.
Posted: Sat Apr 03, 2010 4:51 pm Post subject: |
If the bus is a roller, put your breaker bar with 4 foot cheater 30 degrees or so above horizontal and push,forward for RH and backwards for LH. Better yet if it's a driver let the engine do the work. |
GusC2it Samba Member
Joined: June 23, 2005 Posts: 1376 Location: Orlando, Florida, USA
SGKent Samba Member
Posted: Sat Apr 03, 2010 8:04 pm Post subject: |
If you could do that with plastic pipe the nuts weren't torqued last time or they were done recently.
Quote: |
At my shop we used a 6' pipe and stood on it and bounced a little. If that didn't work a helper whacked on the socket bar at the same time. |
I weigh 275. Standing 3' out and bouncing that is about 1200 pounds on the breaker. Cathy wacked the 1" breaker bar as I bounced and that is how we broke it. I figure it probably saw closed to 1400 pounds on the nut that wouldn't budge. Fortunately I was also hanging onto the gutter rail so I caught myself when it snapped.
That Empi tool or one like it is the only way I know to get a really strong whack into the nut. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
greenbus pilot Samba Member
Joined: March 14, 2008 Posts: 1285 Location: Wisconsin: Rustbelt, USA baby!!
Posted: Sat Apr 03, 2010 9:40 pm Post subject: |
SGKent wrote: |
If you could do that with plastic pipe the nuts weren't torqued last time or they were done recently. |
Schedule 80 pipe comes in steel or plastic. I would imagine steel is a little stronger.... _________________ Sent from a white van down the street. |
Sawsalesman Samba Member
Joined: May 27, 2009 Posts: 796 Location: Ashland, NH
ScottK Samba Member
Joined: August 28, 2004 Posts: 1748 Location: Avilla America
Posted: Sun Apr 04, 2010 5:57 am Post subject: |
The axle nut on the bus is 46mm. That tool works on 36mm nuts only. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Taffy Samba Member
Posted: Sun Apr 04, 2010 1:29 pm Post subject: |
Thanks guys , once you had confirmed it was a right hand thread, I borrowed a 46mm "slogger" spanner from a mate, then with the help of a 7lb hammer and a bit of sweat, I managed to crack those nuts! Job done!
Posted: Sun Apr 04, 2010 1:35 pm Post subject: |
Taffy wrote: |
I have been looking for one of those for quite a while. Gone through many piles of old tools hoping to find one. So far no luck over here in the land of archaic fasteners. |
greenevilleVW Samba Member
Joined: September 03, 2012 Posts: 22 Location: Tennessee, United States
Posted: Sat Jan 19, 2013 10:10 pm Post subject: |
I am having a hard time with my passengers side rear axle nut as well. Is heat not recommended?
Also, is there an aftermarket axle nut that would make this easier in the future. Perhaps with a locking allen or something? |
