faster Samba Member
Posted: Tue Jul 07, 2009 3:21 am Post subject: |
Everythings still a go just haven`t had the time with the 4th and out of town family. And this week I maybe going on vac. But the metal pattern is ready to go for casting.  _________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
faster Samba Member
Posted: Fri Jul 17, 2009 10:50 pm Post subject: |
Well just got back from vacation Pa. great time but have to leave monday for Canada for a week. Anyway heres a picture of the shink from the wood pattern to the metal pattern just about one 1/8" of an inch.
Louis Samba Member
Joined: September 26, 2007 Posts: 416 Location: canada BC
Posted: Sun Jul 19, 2009 1:55 am Post subject: |
| where you going in Canada, if you come to Victoria, lets hookup for a couple beer!! |
krusher Samba Member
Joined: September 24, 2002 Posts: 7617 Location: california
Posted: Sun Jul 19, 2009 10:29 am Post subject: |
That's awesome, nothing more fun that being able to say "I made them"  _________________ (06:31:07) RoachGhia: "i drink dick way too fast"
(06:54:29) BoomsVW: "i always feel free down there" |
Simon uk Samba Member
Posted: Thu Jul 30, 2009 2:51 am Post subject: |
| wow those look great, have you put any test miles on them to see how they get on? |
faster Samba Member
Posted: Sat Aug 01, 2009 2:53 pm Post subject: |
Not sure were July went but it sure did go fast. Anyway just about have the valve cover polished inside and out has to be smooth so the sand doesn`t stick to it when used as a pattern. I`m looking at next week to have a finished casting and if the fit`s good I have a second one poured and then have to find someone to test them (my 36 is still on the stand). I`ll post pictures by the end of next week.
Out of the sand
And just about polished
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5819 Location: back to living where hell meets the suface
Posted: Sun Aug 02, 2009 9:55 pm Post subject: |
| faster wrote: | Not sure were July went but it sure did go fast. Anyway just about have the valve cover polished inside and out has to be smooth so the sand doesn`t stick to it when used as a pattern. I`m looking at next week to have a finished casting and if the fit`s good I have a second one poured and then have to find someone to test them (my 36 is still on the stand). I`ll post pictures by the end of next week.
Out of the sand
I'd be happy to test them on my Judson engine or in my 57 oval shagn wagn _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
faster Samba Member
Tom Simon Samba Member
Joined: August 10, 2009 Posts: 405 Location: Napa, CA
Posted: Tue Aug 11, 2009 3:29 pm Post subject: |
| I am not sure where you are at, but if you are close to Long Beach and need a foundry, Mike Demkowski of C&M Foundry does a real nice job with small lot production for a fair price. He does in-house heat treat of his castings, understands manufacturing. He does (at least used to, it's been 8 years since I took a tour) other VW items and used to cast the Wilwood VW hubs. |
faster Samba Member
Posted: Tue Aug 11, 2009 4:53 pm Post subject: |
| Tom Simon wrote: | | I am not sure where you are at, but if you are close to Long Beach and need a foundry, Mike Demkowski of C&M Foundry does a real nice job with small lot production for a fair price. He does in-house heat treat of his castings, understands manufacturing. He does (at least used to, it's been 8 years since I took a tour) other VW items and used to cast the Wilwood VW hubs. |
Thanks, The foundry I`m working with now I`m very please with and it not that far from the shop I work at here in Atlanta.
I did do alittle work on it today getting it ready for the finish casting. The one thing that I wanted to make sure was the gasket surface was flat and true. So today after work I ran the mill over it and glad I did. I guess the wood pattern flexed under the pressure of the sand ended up cut out about 15 ths. to get it straight. I also took some time to spot faced the hole surfaces for a better seal. Anyway I hope to have it ready for the sand first of next week.
not the best pictures.
faster Samba Member
Posted: Thu Nov 26, 2009 8:43 pm Post subject: |
Update: Just to let everyone know that I`m still working on the valve covers and haven`t given up. I got side tracked getting paint on my single cab before winter set in so now with that out of the way it`s back to the covers. Anyway had to make some adjustment a little epoxy filler milled the gasket area flat and added a round surface for the nut to set on. The black plastic was just something I found that was easy to machine and epoxyed in and will be cut off and blended in. The next time I go to the foundry I`ll have two made from this pattern that should be keepers.
The single cab painted at last.
Posted: Thu Nov 26, 2009 9:19 pm Post subject: |
| faster wrote: | Update: Just to let everyone know that I`m still working on the valve covers and haven`t given up. I got side tracked getting paint on my single cab before winter set in so now with that out of the way it`s back to the covers. Anyway had to make some adjustment a little epoxy filler milled the gasket area flat and added a round surface for the nut to set on. The black plastic was just something I found that was easy to machine and epoxyed in and will be cut off and blended in. The next time I go to the foundry I`ll have two made from this pattern that should be keepers.
Nice to see you're back on it, I'd still be happy to test and/or buy a set for the LSC engine, even rejects, as we need to weld a boss's in for breathers _________________ Stocking distributor of "The Funky Green Panels"
faster Samba Member
Posted: Sat Dec 12, 2009 6:31 am Post subject: |
Well came close to having two good keepers. Only problem the aluminum was poured alittle to cold and didn`t fill the mold completely. When they pour the metal at the end of each day the first to get poured get the hottest metal and the last in line get the cooler metal still very very hot. This happen before and it was repoured hotter without any problem it just comes out rougher. The good is the fit is right on everything shrinked down just where it needed to be and there going to repour two more next week but hotter. Have a look almost there.
The pattern
The bad pour
Gasket fit
vaughn bros.  Samba Member
Joined: October 13, 2003 Posts: 1611 Location: Hickory, NC
Posted: Wed Dec 30, 2009 4:37 pm Post subject: |
| faster wrote: |
Thanks, The foundry I`m working with now I`m very please with and it not that far from the shop I work at here in Atlanta. |
Man this is a wild thread. Those covers kinda remind me of NICSON. Beautiful beautiful coarse fins. I read that you work in Atlanta and was wondering if "close by" meant Columbus Foundry? I know for a while they did turbos and brake calipers. You make me proud to be from the south. I hope you dont stop at just valve covers. I would love to see a matching belt guard centerpiece with matching fins. It is so damn neat that they say "faster ga." inside.  |
faster Samba Member
Posted: Thu Apr 08, 2010 6:05 pm Post subject: |
Update : I know this is getting old but it`s not dead yet. Cleaned up the pattern by blasting now have to add alittle thickest (epoxy)to make the foundry happy. After stricking out 3 or 4 times some would give up but I will have at less two before I retirer from thesamba.
Posted: Thu Apr 08, 2010 8:00 pm Post subject: |
| faster wrote: | Update : I know this is getting old but it`s not dead yet. Cleaned up the pattern by blasting now have to add alittle thickest (epoxy)to make the foundry happy. After stricking out 3 or 4 times some would give up but I will have at less two before I retirer from thesamba.
The Judson engine is now a WW Okrassa kit motor, made 53 hp on the dyno, got some stacks for it, my custom A1 merged exhuast will be here next week, some aluminum valve covers would look good on it, secially with some vents  _________________ Stocking distributor of "The Funky Green Panels"
Eric Outland Samba Member
Posted: Fri Apr 09, 2010 9:14 am Post subject: Eric (VMR) |
Wow!! those wooden Valve Covers are simply Amazing, not to mention the wood work and grain are simply Beautiful!! Throw a Clock in the center of One and I will buy it.  |
Unkl Ian Samba Member
Joined: September 11, 2008 Posts: 279 Location: Near Toronto
Posted: Tue Apr 13, 2010 7:46 am Post subject: |
VERY nice work.
One question, how did you do the lettering on the inside ?
| faster wrote: | ]
Gasket fit
faster Samba Member
Posted: Tue Apr 13, 2010 5:14 pm Post subject: |
| Unkl Ian wrote: | VERY nice work.
| faster wrote: | ]
Gasket fit
Unkl Ian,
The letters are plastic that i bought from a craft store and glued in place. I`m thinking about removing them and naming the covers after my 14 year old dog Zues he`s just about at the end of the road and should be remembered for something. I`m also hoping to get some good pours in a couple of weeks and if they come out good or bad I will post the pictures just for the hell of it..
So far it`s costing me $20.00 a pour but I think the shop foreman of the foundry would like to see me move on and not toy with my project. Anyway if I make the changes that (Jack the foreman wants) and thicken it up in a few places all should be good.  _________________ My 59 panel plus 36hp valve covers http://s122.photobucket.com/albums/o265/faster50/59%20panel/ |
Posted: Wed Apr 14, 2010 7:40 pm Post subject: |
Cool.
Naming them Zeus would be a nice touch.
He can live on in spirit.
What is the minimum thickness for sand casting Aluminum?
2.5mm (.100") ?
$20 each is very reasonable. |
