Salt flat discs for stock rims
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
vwfan5
vwfan5 is offline
PostPosted: Wed Apr 21, 2010 6:34 am    Post subject: Salt flat discs for stock rims Reply with quote
Are salt flat discs available to fit stock vw bug 15" 4 lug rims? I have a set of 4 lug hub cap style rims, and 4 lug Sun Bug rims that I can use. Both rims center sections bow out past the rims edge, so I feel the universal flat discs may not work. I prefer the screw on type, but the snap on type is okay also. Names of any distributors would be appreciated. Thanks.
69 Jim
69 Jim is offline
PostPosted: Wed Apr 21, 2010 8:24 am    Post subject: Reply with quote
http://www.mooneyesusa.com/
vaughn bros.
vaughn bros. is offline
PostPosted: Wed Apr 21, 2010 1:07 pm    Post subject: Reply with quote
vwfan5
vwfan5 is offline
PostPosted: Thu Apr 22, 2010 6:54 pm    Post subject: Reply with quote
I still am looking for an answer without buying and trying to see which ones will have the clearance and fit. Anyone else running them?
69 Jim
69 Jim is offline
PostPosted: Thu Apr 22, 2010 7:43 pm    Post subject: Reply with quote
Call Mooneyes. Rolling Eyes
'64cal lookdub
1200 Deluxe
'64cal lookdub is offline
PostPosted: Thu Apr 22, 2010 10:51 pm    Post subject: Reply with quote
The snap on discs from mooneyes don't look right...if you must run the snap on, get the generic ones from speedway motors, they don't have a funny looking lip like the ones from moon and they're a lot cheaper.
madoski
madoski is offline
PostPosted: Wed Sep 14, 2011 4:20 pm    Post subject: Reply with quote
Did you ever get a set to work and look right? I got some of the screw on ones on an ebay auction only to find that they don't clear the rear axle nuts (fronts have adequate clearance)...this is on a four lug.
chickengeorge
chickengeorge is offline
PostPosted: Thu Sep 15, 2011 7:23 am    Post subject: Reply with quote
You can only lead the horse to the water, grasshopper....
andk5591
andk5591 is offline
PostPosted: Fri Sep 16, 2011 3:57 am    Post subject: Reply with quote
When I was going to use them on my 69, I had seen where some folks used spacers to clear the axle nuts - another thing you can do it find wheels with a little less backspacing (there are about a dozen different 4 bolt wheels out there. My car originally had 3 different wheels on it.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
