Gabriel Hijacker Shocks in Rear
Page: 1, 2, 3, 4  Next
Jteerlink
Jteerlink is offline
PostPosted: Fri Apr 02, 2010 4:53 pm    Post subject: Gabriel Hijacker Shocks in Rear Reply with quote
My '87 Wolfsburg is in need of rear shocks and I found a pair of air adjustable Gabriel Hijackers at Autozone for a fair price. I am trying to avoid the Vanagon rear end sag that eventually will be even more pronounced one she is fully loaded with gear and a bike rack on the hatch.
I have seached the Samba with no luck but I seem to find dozens of 4x4 owners who are happy with their setup in both front and back.
What say you? Yea or nay on the air adjust shocks to level the Vanagon under load?
itzdshtz
itzdshtz is offline
PostPosted: Fri Apr 02, 2010 7:04 pm    Post subject: Reply with quote
I have a set in the back of my Syncro and am happy with it, you will have to press the old bushings out of your old schock absorbers and press them into the Hyjackers.
They will give you a bit of lift in the back, I have about 60 PSI in them.
Cheers Herman
1989 Westy
1987 Westy Syncro 2.5 M- TDI
1991 Syncro, future 1.9 M- TDI
2005 Audi allroad 4.2
2005 S4
http://vanagonsyncroproject-herman.blogspot.com/
http://picasaweb.google.com/itzdshtz/VanagonSyncroProject02
Jteerlink
PostPosted: Fri Apr 02, 2010 7:14 pm    Post subject: Reply with quote
Excellent! Thanks Herman!
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Apr 02, 2010 7:39 pm    Post subject: Reply with quote
Look at the "Sagging rear" threads in the Best Threads sticky. See link in my below signature.
Jteerlink
PostPosted: Wed Apr 21, 2010 4:35 pm    Post subject: Reply with quote
**UPDATE**
For anyone interested (as I cant find any discussion on this particular setup) I Installed the Gabriel Hijacker air adjustable shocks in the rear. Air lines were installed along the bumper, through the "vents" in the sheet metal behind the bumper and along the frame to each shock. This is really the only route to take that doesn't involve drilling holes.The Gabriel kits comes with clips to keep the lines away from the muffler and other danger areas.
Also, instead of drilling any holes near or behind the license plate door for air valve access (only logical mounting location I could think of) I was able to fit the valve and cap through one of the lower license plate mounting holes. Its a clean, trick look that already has had some taking a second glance, with a "Hey, what is that?"
I am now running 60 - 65 psi. (thanks "itzdshtz") and the shocks have perfectly leveled off the rear. Now, even if I am loaded down with gear in the hatch and on the roof rack, I just pump a bit more psi and it doesn't look like my butt is draggin!
Up front, I plan on replacing the tired and old shocks with Bilsteins.
r39o
Samba Polizei
r39o is offline
PostPosted: Wed Apr 21, 2010 4:42 pm    Post subject: Reply with quote
Got a part number?????
chimivee
chimivee is offline
PostPosted: Wed Apr 21, 2010 6:00 pm    Post subject: Reply with quote
Looks like 49215:
-James
86 Syncro Westy, etc
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
chimivee
chimivee is offline
PostPosted: Wed Apr 21, 2010 6:02 pm    Post subject: Reply with quote
Pardon my ignorance on these, but they look like a great option. Any pics of your install? More info on ride quality etc? I take it they are independently adjustable?
-James
manton58
manton58 is offline
PostPosted: Wed Apr 21, 2010 6:57 pm    Post subject: Reply with quote
I'd also be interested in hearing how they ride....gotta be an improvement over old warn out shocks but how are the compared to OEM's in good condition?
240Gordy
240Gordy is offline
PostPosted: Wed Apr 21, 2010 8:17 pm    Post subject: Reply with quote
Jteerlink wrote:
**UPDATE**
awesome.
Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR
PDXWesty
PDXWesty is offline
PostPosted: Wed Apr 21, 2010 9:08 pm    Post subject: Reply with quote
$78 a pair???
http://www.amazon.com/Gabriel-49215-Air-Shock-Absorber/dp/B001AMA96W
89 Westy 2.1 Auto
chimivee
chimivee is offline
PostPosted: Wed Apr 21, 2010 9:57 pm    Post subject: Reply with quote
PDXWesty wrote:
$78 a pair???
I KNOW!
-James
Jteerlink
PostPosted: Thu Apr 22, 2010 12:06 pm    Post subject: Reply with quote
Yeah cheap, cheap!!! The part number is 49215 from Autozone at $63.99 to complete the entire job. You have to tell the dude you have a Syncro or they will tell you they don't fit. Don't believe him, they fit just fine. The kit I was sold already had the bushings pressed in and ready to mount. From start to finish, it took me about 4hrs. Max upgrade with minimal effort/cost.
No, they are not independently adjustable. The kit comes with one T-valve that pressurizes both sides. However, I am sure you could separate them with some modification.
Handling is a dream over the the old ones (one old one was absolutely shot) with less body roll around turns. I haven't been in the back yet while driving but I can tell they are a bit firm. Since they handle a range of 25 - 200 psi, I am thinking the ride can be adjusted to suit. I don't recommend jacking up the psi to 200, as I doubt the upper shock mounts were meant to handle that high of stress.
I will post pics as soon as possible
Jteerlink
PostPosted: Thu Apr 22, 2010 3:50 pm    Post subject: Reply with quote
never mind the apple sticker, I had it lying around and that big, black, blank shock was asking for it. Very Happy ishock
license plate hole needed to be enlarged by about 3/16 in for the airvalve
this shows a bit of a rake from back to front. Use a pressure gauge with a bleeder valve to get it just right
chimivee
chimivee is offline
PostPosted: Sun Apr 25, 2010 10:21 pm    Post subject: Reply with quote
Very cool! So how is the ride? I'm imagining that if there is enough pressure in them to compensate for spring sag, the ride must be fairly firm?
-James
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sun Apr 25, 2010 11:20 pm    Post subject: Reply with quote
The biggest bonus with the Gabriel air shock is the air chamber is separate from the shock unit.
So, in essence you could crank it all the way up with max air, and still have a functioning shock.
Monroe's or the GM air shocks get stiff--the air bag & shock aren't separate, plus the air bag isn't covered in a steel cover like the Gabriels.
Keep them tied together--they work fine functioning in tandem, working together to keep the ass end kicked up in the air--
T.K.
hiram6
hiram6 is offline
PostPosted: Mon Apr 26, 2010 4:56 am    Post subject: Reply with quote
I've ordered a set of these. Good find!!! Now that I've gone to Carat springs, I was concerned that when I used the Westy to tow, the tongue weight would drop the rear of the van too much. Now I can just boost up the PSI a little. Love the idea!
1985 Westy, 1.9L automatic (Daisy)
1996 Mazda Miata
1998 Jeep Grand Cherokee 5.9 Limited
You can't lie around on the beach and drink rum all day.................unless you start first thing in the morning.
TopBud
TopBud is offline
PostPosted: Mon Apr 26, 2010 8:25 am    Post subject: Reply with quote
I have a syncro that needs shocks all the way around. I can't afford the OME's, but if I get these Gabriel's for the rear, what would you recommend for the fronts?
86 bostig SYNCRO
66 convertible Karmann Ghia
chimivee
chimivee is offline
PostPosted: Mon Apr 26, 2010 9:57 am    Post subject: Reply with quote
Oooh, I see. So it's basically like a built-in air bag. Cool!
Still interested in ride reports/comparisons... Very Happy
-James
Terry Kay
Banned
PostPosted: Mon Apr 26, 2010 10:24 am    Post subject: Reply with quote
Here's something to think about with the air shocks.
Your asking the shock, plus their mounts to do the job of the springs--if your springs are up to snuff and giving you the proper lift, then the air shocks are excellent supplimentary accessory suspension aides.
They shouldn't be used to do what your worn out springs aren't doing.
T.K.
Page 1 of 4
