drivnvws Samba Member
Posted: Wed Apr 28, 2010 3:17 am Post subject: Engle fk-8 |
Hi all, Well, close to 2 weeks ago I ordered an Engle fk-8 cam kit (cam and engle lifters) from socal imports. Called them today to find out the status of my order, and come to find out that they grind all of their cams themselves. The guy on the phone said that the delay was because they were waiting on cam blanks to come in, and then they grind them down to engle's specs.
I ordered from socal, not because they were the cheapest (they weren't), but because they sold both engle cam and lifters as a kit.
Is this what most shops do nowadays, grind their own cams and slap a brand name on it. It's been a while since I've bought any engine parts, but when I got my engle 120 years ago, it was in a sealed engle box with engle stamped all over the place.
Does anyone have any input on this, anyone used an engle cam from socal, is the cam going to be identical to a factory engle.
Also wondering if engle still manufactures their cams, or if they just farm out the manufacturing to other companies.
I guess all I am wondering is if the cam from socal is going to as good as a factory one, or should I cancel my order and find someone that sells factory engles. When I asked them today, they said it was identical.
But they have to say that, if they said it was kind of right, they probably wouldn't sell any.
Sorry for rambling, I'm just confused and frustraited.
Thanks, Eric |
Posted: Wed Apr 28, 2010 3:35 am Post subject: Update |
Well, just happened upon a thread where someone said that socal bought out engle. When I asked the guy on the phone at socal today, I wish he would have told me that engle was now owned by socal imports and that was the reason they grind engle cams.
It would have saved me tons of stress over this at work all day and night.
Thanks guys for listening |
nsracing Samba Member
Posted: Wed Apr 28, 2010 6:14 am Post subject: |
Get one that says "Engle" on it.
I hope they are not grinding a stock cam to say "110" on it.
It better have the yellow box and cam card and all-black when you get it. No gear either. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Apr 28, 2010 6:16 am Post subject: |
nsracing wrote: |
It better have the yellow box and cam card. |
_________________ Glenn
Member #1009
#BlueSquare |
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Wed Apr 28, 2010 6:20 am Post subject: Re: Engle fk-8 |
drivnvws wrote: |
I got my engle 120 years ago |
Really?! Wow, what was it like racing in 1890? |
Posted: Wed Apr 28, 2010 6:36 am Post subject: |
I got a bunch of those too, Glenn.
I have still quite a few more new old stock Engles in the stash. When they are gone, maybe I will do Webb exclusively.
Engle are okay. Not the hardest cam out there but plenty strong for the money.
I have used Webb before and have nothing to complain about. |
midtravelmidengine Samba Member
Joined: August 06, 2009 Posts: 861 Location: Riverside, Ca
Posted: Wed Apr 28, 2010 8:35 am Post subject: |
When you call Engle cams every now and then some one will answer the phone "So cal imports..." Confused me the first time i called too. I have a few engle cams in my Big Block Oldsmobile. |
Sigurd Samba Member
Posted: Wed Apr 28, 2010 8:39 am Post subject: |
nsracing wrote: |
Engle are okay. Not the hardest cam out there but plenty strong for the money. |
Could you elaborate on the hardness issue? I hadn't heard of that before. |
Posted: Wed Apr 28, 2010 10:11 am Post subject: |
I have used a lot of Engles. I have seen lots of cams go flat even in short time. Hence I made some additional oiling for extreme applications.
I have noticed over the years that the bigger cams Engle make is hit or miss going flat.
The Webb cams I have installed never seen one go flat. The cost too might give an idea on what product quality you are getting. The Webb cams are more expensive.
FK-8 and up...gotta watch what you are doing. Keep up the adjustment. A small neglect will spell disaster.
I micro-polish them. I have had few that went flat installing them straight out of the box. |
speedyshift74 Samba Member
Posted: Wed Apr 28, 2010 10:54 am Post subject: |
I bought an FK47 cam direct from Engle 2 years ago. Ran it for a total of 50 Passes on the drag strip. When I opened the engine up for inspection I found the cam had pits on the point of the lobe. My lifters looked like new . I'm not bashing Engle in anyway. I have used Every Grind they make for VW. Until this issue, I have never had a problem. I'm sure whoever took over the cam shop will stand by the product if they want to stay in business. |
stoneloco808 Samba Member
Joined: June 15, 2007 Posts: 658 Location: Pakalolo Country, HI
Posted: Wed Apr 28, 2010 2:27 pm Post subject: |
speedyshift74 wrote: |
But at that time do you remember what type of lifters, valve springs and oil you were using at that time? I am not sure when the oil companies went with the low zinc content. |
stealth67vw Samba Member
Joined: January 22, 2004 Posts: 1852 Location: Grass Pants, Orygun
Posted: Wed Apr 28, 2010 4:50 pm Post subject: |
So Cal Imports bought Engle Cams last year and brought over all the grinding equipment and all of Engle's employees. Nothing has changed except the building in which they grind the cams. _________________ John Bates
JB Machining Services
1967 street Bug 2276 w/ 48 IDAs, 2020lbs with driver
7.76 @ 89.55mph 1/8 mile
12.34 and 108.10 mph 1/4 mile |
Posted: Wed Apr 28, 2010 5:24 pm Post subject: |
The lifters were CB light weight. The springs were K-800 and the oil I run in EVERYTHING I own is Rotella 15w40. I am not new to the VW scene. Every one builds and tunes a little differently. Just somthing that suprised me. |
Posted: Thu Apr 29, 2010 2:12 am Post subject: |
John, Talked to them today, and that is exactly what they told me. Makes me feel better knowing that they bought the entire business and not just the name.
Going to try the engle, see how it goes. If it goes flat, I'll try out one from webbcam. |
Arnolds64 Samba Member
Posted: Thu May 27, 2010 4:02 pm Post subject: Rotella? |
By the way, Rotella has dropped allot of the zinc content out their oil in the last few years. It think it is like 900- 1000 ppm or so. It use to be 1200? Anyway I am using Brad Penn now. Less than syns and more than dino. Good compromise. 3.00 a quart at www.craigslist.com and go to Kansas City. Auto parts - BRad Penn. They are great guys less than CB. _________________ 64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels. |
