Kel Dub Samba Member
Joined: February 04, 2004 Posts: 809 Location: Long Beach, CA
Posted: Thu Aug 26, 2004 8:25 pm Post subject: I need some shine! help me! |
OK, i just had my 55 rag delivered to my house 3 weeks ago today. it had just had the deck lid resprayed before being shipped out. (NOTE: I was told before i bought the car that the paint was not perfect, and i was/am totally fine with that. I was told it had shine but had the normal chips from driving and scratches here and there.) So his logic (the seller) was that when he had it resprayed, to not have a perfctly glossy shine to it because then the deck lid would shout out over the rest of the car... so i said alright. I figured that it would just be an "ok" paint job. Well little did i know that it was goign to be one of the worst jobs ive ever seen. It is orange peeled pretty bad and there are imperfections where the lid wasnt prepped properly. When i got it, it didnt even seem like the paint had cured yet so i didnt try to wax/polish it for awhile.
After some time has passed i hand waxed it a little bit and it looked a little bit better but still shitty. From that point on i just kind of kept it clean not knowing exactly what to do.
Today i tried waxing it again with a waxer/buffer and it is almost as if when i went to buff the wax out the paint absorbed it and wouldnt let it polish out. The lid actually has less shine and had became more dull.
If i want to try to eliminate the dullness and orange peel what is the best way to go about doing it? Wet sanding? Any tips would be great.
E-boyz67 Samba Member
Posted: Thu Aug 26, 2004 9:39 pm Post subject: |
Did you pay to get it painted or did you buy it and the seller said that he would get it painted and deliver it to you? First, you never wax a fresh paint job until after 90 days. What you have done is to seal the pours of the paint and the solvents will not be able to evaporate and thats why it becomes dull. Try to get some mild wax and grease remover and wipe the surface. My question is,is the paint a single stage or a basecoat/clearcoat? Is it a solid or metallic? If its a solid single stage then you can wet sand with 2000 grit and buff. Same if its a base/clear. But if its a metallic single stage then you can't sand and buff because the sanding will distrub the metallic flakes and you will have dull flakes and see the discoloration. _________________ 2-67
1-67vert |
Posted: Thu Aug 26, 2004 10:11 pm Post subject: |
metallic. Am i screwed? |
nobrakes Samba Member
Posted: Fri Aug 27, 2004 6:41 am Post subject: |
You can try some white rubbing compound, might help. _________________ If your not workin or cleanin your not looking hard enough. |
Posted: Fri Aug 27, 2004 5:44 pm Post subject: |
White rubbing compound? |
Posted: Sat Aug 28, 2004 3:01 am Post subject: |
[quote="Kel Dub"]metallic. Am i screwed?[/quote]
Yea pertty much if you try to use some compound it won't do much to get the shine, you must repaint. _________________ 2-67
1-67vert |
Posted: Sat Aug 28, 2004 2:57 pm Post subject: |
well at least it was a shit job to start with. |
Posted: Sun Aug 29, 2004 3:16 am Post subject: |
Well now you can get it done right which is the best part. _________________ 2-67
1-67vert |
Posted: Sun Aug 29, 2004 3:22 pm Post subject: |
For a true show paint, the whole car needs to be shot so i might just wait... |
