63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Thu May 20, 2010 6:06 pm Post subject: remote oil filter location |
OK, just got my new engine in. first go round. she has remote oil cooler.
I was curious if any one has any pictures or suggestions of best mounting locations and if it makes a difference.
Thanks in advance |
rsorak Samba Member
Posted: Thu May 20, 2010 6:37 pm Post subject: |
Cooler or a filter? I just put the new engine in my thing and its got a remote filter. I'm gonna tuck it in the rear bumper...Will post some pics as soon as I get it done. Should only be a day or 2... _________________ Rick '71 Westfalia & '73 Thing |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Thu May 20, 2010 6:44 pm Post subject: Re: remote oil filter location |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Fri May 21, 2010 3:36 pm Post subject: |
Here's a setup I've had for about 10 years.
This is a Canton/Mecca filter inside the engine compartment.
Forgive the dirty appearance, this car is driven; not polished.
By the way, here's what it looks like in my '71 Super Beetle, which is my daily driver.
and from underneath:
The Beetle has a much more compact arrangement, but the main differences are the smaller C/M filter and the virtual elimination of oil hoses; just that short one seen above.
Both cars are very easy to service, and the filters are kept away from splash, rocks, etc.
Best regards, Mondshine |
hank0306 Samba Member
Joined: January 18, 2010 Posts: 96 Location: Los Angeles, CA
Posted: Fri May 21, 2010 4:56 pm Post subject: becareful |
Watch where you run the oil lines. I just installed one and ran the lines to close the exhaust (stupid I know), on my maiden voyage my Thing filled up with smoke. Luckily some smart Thing owner on this forum told me to install an VDO oil pressure gauge, I saw the pressure begin to drop and shut it down at the same time the Thing filled with smoke. Saved my new engine. Point of the story is to be mindful where you run the oil lines. |
Posted: Fri May 21, 2010 5:10 pm Post subject: |
mondshine wrote: |
I like driving cars more than looking at them
That is an awesome setup! Google tells me that's not a cheap filter either! I'm also curios about the other bits in the left side of your Thing's engine compartment - a sigg bottle(?) and what are those white spheres?? _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
Posted: Fri May 21, 2010 5:43 pm Post subject: |
The Sigg bottle holds a quart of oil for emergencies. It happens to be a perfect fit in a standard fire extinguisher bracket.
The bubble thing on the left is a vacuum reservoir from an early Rabbit, it helps the vacuum operated cruise control accelerate under load.
You can (almost) see the fitting that connects the oil filter exit with the oil thermostat. On the right side of the oil thermostat is a check valve. The line leading up from the tee leads to an "Accusump" next to the driver's seat.
The gizmo on top of the oil thermostat is the control pressure regulator; one of the components of CIS fuel injection. Also visible is the cold start valve and the thermo/time switch.
Getting back to the oil filter, I believe Canton/Mecca filters are the best you can put on an ACVW. They are 8 micron filters which do not bypass, and can handle more pressure than any VW can produce. They are not that expensive; less than $100.
Here's a sketch of the oil layout:
Good luck, Mondshine |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Fri May 21, 2010 6:22 pm Post subject: |
Here's mine. It includes a thermostat valve near the filter that runs to an aux electric cooler (with t-stat fan switch). It's a cheesy low-budget version of mondoshine's. Mine is mounted to my rear cage, but I think a very similar setup could be mounted on the left air cleaner bracket.
Most importantly; I can remove the filter without making a frikin' mess.
_________________ My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22 |
Posted: Fri May 21, 2010 7:00 pm Post subject: oil filter location |
Thanks for the pics. I think I got it. and was chasing filter location. sorry if was not clear. |
Posted: Fri May 21, 2010 7:27 pm Post subject: |
63ziggy-
I was trying to sell you on the idea of locating the filter inside the engine compartment. It's only my opinion, but I think it's way better than having the filter outside in the mud splash. On the 181, there's plenty of room inside the engine compartment, and the mounting location for the aux air filter is very convenient. In addition, the fitting arrangement where the oil re-enters the engine is highly simplified if you simply drill the inner pulley tin, rather than re-shape it to accommodate the 90* fitting at the oil gallery entrance. Also, there are no hoses draped near the heat exchangers or exhaust system. Since you mentioned you are using an aux cooler, I assume you'll be using an oil thermostat. I used two bulkhead fittings which were 1/2" NPT X JIC-8 to mount the thermostat to the front bulkhead, where 2 additional hoses carry the oil to and from the oil cooler.
Very simple and clean.
On the other hand, I really like the way it turned out on the Beetle, the Thing could have been done the same way. The shorter C/M filter is more than adequate for 2 or 3 oil changes, and it's a nice, tight, and dare I say elegant solution because there aren't hoses running all over the place. The Beetle installation is less than 2 years old, so there's 10 years between the two projects. Take another look at the Beetle photo.
Whatever you decide, just remember the reason you bought the Thing...
to have fun with it.
man130 Samba Member
Joined: August 25, 2008 Posts: 406 Location: long island , ny.
Posted: Sat May 22, 2010 11:31 am Post subject: |
Mondshine- In your sketch of oil layout what is the thing to the right of the oil cooler fan? Is there anyway you could label that sketch with what parts are which? If you have the time ,It would be a big help as I have to set up oil cooler/filter for my new motor ,thanks |
Posted: Sat May 22, 2010 12:34 pm Post subject: |
Man130-
That thing is an "Accusump".
http://www.accusump.com/accusump_tech.html
It's an aluminum cylinder with a piston which moves inside the tube.
On the side of the piston with the gauge, air is trapped under pressure as the cylinder is filled with oil on the other side of the piston, where the valve is.
This thing serves two purposes. First, it serves as a pre-oiler. Before the engine is shut down, the valve is closed. When it's time to re-start, the valve is opened and the oil galleries are pressurized as the air (under pressure) moves the piston. Pre-oiling is a nice feature if you only start the engine once a month, etc. The second function is to provide oil in situations of oil starvation; like in a hard corner or due to a pump failure. It only holds 1 1/2 quarts, but it buys a few seconds to avoid a catastrophe.
In the diagram, the part with the little arrow is a check valve, a one way valve that routes oil from the Accusump to the galleries and not back to the pump.
Here's what it looks like in the car:
My Accusump is a pretty old one, 25+ years, they look a little different now.
I bought it because of the infrequent use of the Thing, which I don't get to drive as much as I'd like to.
man130 Samba Member
Posted: Sat May 22, 2010 6:16 pm Post subject: |
Mondshine-Thanks for the info ,Ive never heard of the accusump .sounds like a great idea for motor that arent run much. |
1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Mon May 24, 2010 7:08 am Post subject: |
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Mon May 24, 2010 9:43 am Post subject: |
Adam, did a neat job of the oil filter in my 2054 Thing.
But I now have red foam filters over the standard filters ion the Weber 34ICT's
_________________ 63 singlecab
73 thingster
74 Thing |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Thu Aug 25, 2011 7:16 pm Post subject: |
Hope I don't get blasted for this one! LOL!!
I have routed my oil lines, but I am not convinced it's the safest/best route available..
Here's a couple pics. Any thoughts on a better path to take? I was thinking to go below the lower exhaust pipe, but I don't want them too exposed to road debris, yet they need to be away from the exhaust pipes.
Also, the FLAPS guys gave me heater hose(seems too pliable). Is that acceptable, or is there specific Oil line I should get???
Lastly, Does the barbed fittings and hose clamps suffice, or does this system Need AN or Ferrell type fittings??
Thanks in advance!
_________________ '74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember |
vgajames Samba Member
Posted: Thu Aug 25, 2011 7:36 pm Post subject: |
If you have heater hose it want last long.You need high pressure oil hose.
http://www.cbperformance.com/catalog.asp?ProductID=250
The barbed fittings with probably be ok.
Are those Mann filters HP rated like the K&N HP3001 ? |
Posted: Fri Aug 26, 2011 10:29 am Post subject: |
vgajames wrote: |
I don't know what the burst pressure rating is for the Mann W719/5, but Mann is an OEM supplier of filters for VW and Porsche. Probably more significant is the difference in the bypass pressure. The HP3001 has a bypass pressure rating of 8-11 p.s.i., while the Mann filter has a bypass pressure of 2.5 bar or 36 p.s.i.. |
Posted: Fri Aug 26, 2011 1:38 pm Post subject: |
Captain Spalding wrote: |
vgajames wrote: |
I was referring the the canister thickness.I have seen oil filters blow up on
full flow VW's.The can swells up and boom. |
