jimisox Samba Member
Joined: February 24, 2010 Posts: 82 Location: Huntley, Il
Posted: Fri May 21, 2010 11:26 pm Post subject: Generator Stand/intake manifold gasket questions |
I was sold and told all I need is the metal flanged gasket. I took off the stand and saw one paper, the metal and another paper gasket....do I need all of that again? I was told all I needed was the metal one and I'd be fine. Just want to be sure before I put it all back together tomorrow. Also while I was in there trying to get the stand out, I thought I needed to pull the intake manifold..please don't ask, I had clearance issues..I know now to loosen the shroud...So I did take the intake off and now I am wondering if I need to install new gaskets for that as well, or can I just use the old ones...and the little silver circular seals? inside of the intake to the block/case. Thanks for your help in advance |
t.tuescher Samba Member
Posted: Sat May 22, 2010 12:34 am Post subject: |
you should get the paper gaskets. for the stand and the intakes, who ever told you that you would be fine with one metal gasket for the generator is full of _________________ yellow 72 std. bug,
now with a set of new frd's |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sat May 22, 2010 3:25 am Post subject: |
unless I have a pretty complete gasket set in my stash, I just order one and have it on hand when I start tearing things apart - they are cheap (under $20) and then your butt is covered. As far as gaskets on the gen stand, I have seen that folks just use metal, but I also do the paper myself - don't want to take a chance. _________________ D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
Paul Windisch Samba Member
Joined: September 02, 2009 Posts: 2546 Location: Clinton Township, Michigan
Posted: Sat May 22, 2010 4:28 am Post subject: |
You'll need to repace the intake gaskets, as well. _________________ *ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer |
