watkinscapital Samba Member
Posted: Sat Jun 05, 2010 2:27 pm Post subject: Generator 12v Car Running = Idiot light on ? Help! |
First I know there are alot of forum topics about this but I have read through most of them and gone back to the car and tried.
The idiot light stays on when engine is running and will not go off, until car is turned off. I have checked and doubled checked all wiring and I am fairly cofident its done right. The battery is brand new and only getting 12 when car is running and when its rev'd it drops to 11-12.
Any Suggestions would be greatly apprciated? I am not sure what else to do.
What I have done:
I did polarize Gen.
Battery is brand new.
I Just put in a new voltage regulator.
Tested gen is putting out 40 amps at when rev'd ( http://www.nls.net/mp/volks/htm/gen.htm ).
Cleaned tabs and put in new connectors for idiot light.
new Regulator.
Generator:
Dale M. Samba Member
Joined: April 12, 2006 Posts: 10071 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Jun 05, 2010 5:56 pm Post subject: |
Do you know if new regulator is good?
Here is basics for testing.....
Generator/Regulator Test!
Disconnect all wires from Generator. (tag them so you get them back right)
Connect a test light ( 6 or 12 volt what ever is appropriate) on generator to the "D+" terminal ... Ground other side of light.
Ground "DF" or "Field" on generator.
Start engine... If light comes on and brightness increases as engine rpm comes up your REGULATOR is bad ( generator works ) Caution over revving engine to fast will cause light to burn out.
IF light stays dark ( does not light ) , check test setup again to be sure its right... If you rev engine up and light still does not light GENERATOR is bad.
People with experience using a VOLT-OHM meter could use the meter instead of light... look for VOLTAGE increase..
Dale _________________ Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
Posted: Sun Jun 06, 2010 8:15 am Post subject: |
With a voltmeter I Put Pos. on ( D+ ) / neg on ground and grounded (DF) to frame with jumper wire.
Results were a reading of 12v then when rev'd it went up to 35-40?
I figured this meant it was good, so I replaced the voltage regulator. Started car up and the idiot light was still on when started and would not go off even when rev'd.
I have not tried a test light but will get to that this morning after coffee. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25689 Location: Central Iowa
Posted: Sun Jun 06, 2010 8:23 am Post subject: |
Disconnect the #61 wire at the voltage regulator. The light should go out.
If it does not, then that wire is shorted someplace. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Jun 06, 2010 10:26 am Post subject: |
| It does go out. When unplugged, and did the same with both old and new regulator. |
Posted: Sun Jun 06, 2010 10:32 am Post subject: |
If you are getting 30-40 volts when full fielding the generator, Then the generator is good, and putting out properly.
Are the wires good from the generator to the regulator? Especially the DF wire?
That is the wire that controls the generator, via the regulator.
Do the same test you did at the generator, only this time do it at the regulator.
Disconnect the DF and the D+ wires at the regulator, and ground the DF wire while measuring the voltage at D+ wire.
Could be you have a break in the DF wire. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Sun Jun 06, 2010 9:48 pm Post subject: |
Did you happen to reverse DF and D+ wire when you replaced regulator?
Also regulator appears to be mounded on fiberglass.... Is it GROUNDED?
Posted: Mon Jun 07, 2010 8:36 am Post subject: |
I will really inspect wires, and test the regulator. Yes wires were in correct spots, however at one point they were reversed (not sure if this could have damaged the generator itself). The regulator is grounded although maybe not grounded good enough (have cable going from right side of regulator box to frame).
I will do some more testing soon and if nothing changes (I suspect its something obvious that Im missing), I'll order an alternator kit. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 3767 Location: Frankfort, Illinois
Posted: Tue Jun 08, 2010 6:48 pm Post subject: |
| watkinscapital wrote: | I will really inspect wires, and test the regulator. Yes wires were in correct spots, however at one point they were reversed (not sure if this could have damaged the generator itself). The regulator is grounded although maybe not grounded good enough (have cable going from right side of regulator box to frame).
Why do you think you could make the necessary changes the wiring changes that are needed to convert to an alternator when you can't figure out the generator system, which uses the same wires just terminated differently? _________________ Jerry...
If it's being towed, it must be a trailer!
The Southside Buggistas - Volkswagen & Kit Car Club
www.southsidebuggistas.com
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Posted: Wed Jun 09, 2010 4:52 pm Post subject: |
lostinbaja:
Did you add anything beneficial here or just trying to get your post count up?
I am trying to figure out what is going on with the system which was my reasoning for the post, it could be a bad ground, it could be a fried wire. If you’ve got some suggestions for me to try out I may get some garage time tonight so let me know. |
zozo Samba Member
Joined: October 15, 2005 Posts: 4138 Location: In cahoots, south o' San Antone
Posted: Wed Jul 07, 2010 1:07 pm Post subject: |
I'm following this thread VERY closely, as I'm have the exact same problem with mine. I've also installed a new VR, have a new battery, etc, etc.
The one thing that I'm thinking might be the problem with mine was the DF post was loose in the generator. The lock nut had backed off for some reason. Initially, this was accompanied by the DF wire to the VR being broken at the connector and losing contact.
I had thought that tightening the DF post and putting a new connector on the wire would turn the trick, but I find myself in exactly the same situation as you.
Posted: Wed Jul 07, 2010 2:15 pm Post subject: |
| I've been swamped lately and have not had time to get out in the garage. Its funny you mention the DF post being loose because mine was as well, but i figured it was ok because I was getting a amp reading off the Gen. |
Posted: Wed Jul 07, 2010 2:17 pm Post subject: |
You may have a broken wire to the DF post, inside the generator.
It is a solid wire inside there, and if it wiggles around too much, it will break. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
zozo Samba Member
Posted: Wed Jul 07, 2010 8:24 pm Post subject: |
| Russ Wolfe wrote: | You may have a broken wire to the DF post, inside the generator.
It is a solid wire inside there, and if it wiggles around too much, it will break. |
Is there a solution to fix the problem, or is the only solution to replace the generator? I'm bettin' that it'd be cheaper, simpler, and far less problematic to just put a new generator on it. In this case, I hope I'm absolutely wrong.
Thanks in advance.
As an afterthought, I re-read the polarizing instructions and noticed that it said the DF needed to be grounded to the generator body. I didn't do that, I grounded the DF post to a known good ground by the decklid. Would that prevent the generator from being correctly polarized? |
zozo Samba Member
Posted: Fri Jul 09, 2010 7:35 pm Post subject: |
To whomever posted this picture in whatever thread I found it, THANK YOU, THANK YOU, THANK YOU. After looking at this picture, I was able to diagnose my problem, and resolve it. A little time, a little solder, and voila, the problem has been fixed. I'm charging properly, and the idiot light has been extinguished.
Once again, THANK YOU to whomever posted this picture and provided the associated narrative on how to fix it.
Markymark875 Samba Member
Posted: Tue Jul 13, 2010 9:49 pm Post subject: Generator |
| Is that behind the pulley, I am having the same problem as you guys to, I wonder if I might have broken that wire while putting a screw driver in that slot to tighten the pulley nut? |
zozo Samba Member
Posted: Thu Jul 15, 2010 2:57 pm Post subject: |
Yessir, just pull the pulley off, look in there with a flashlight, and all will be made clear.
I fixed mine in about 20 minutes, and I only have one eye. If I can do it, anyone can.
Good luck.
Feel free to PM me if you have any questions about the process. |
Posted: Sun Jul 18, 2010 3:50 pm Post subject: |
| Thx for the help, the wire on mine is not broken, I cleaned the brushes/and copper?? cant remeber name of it, light is still on now, but very dim, seems to be charging a little |
dunebuggy09 Samba Member
Joined: May 02, 2012 Posts: 17 Location: NORTH CAROLINA
Posted: Thu May 03, 2012 9:23 pm Post subject: |
| I'm having same issue change yep gens and three vr. My car Will run with battery cable off while car is running. Idot light on. D+ and df have power on them when car running. |
Posted: Fri May 04, 2012 7:17 am Post subject: |
| dunebuggy09 wrote: | | I'm having same issue change yep gens and three vr. My car Will run with battery cable off while car is running. Idot light on. D+ and df have power on them when car running. |
That is "normal" with good/functioning generator system...
Why the idiot light is on is the mystery... Did you pull it off VR (terminal 61) and did it go out?
