bpritchert87 The Idea Man
Joined: February 26, 2007 Posts: 1507 Location: Wisconsin
Posted: Tue Jul 20, 2010 6:11 am Post subject: intake and generator stand gaskets |
Yes! I researched....
couldn't find what im looking for...
1) THe generator stand metal gasket is to point to the "right" loovers down?? right?? ok check....
2) the intake metal gaskets are to have the ridge facing upward when installing???
3) metal or thicker fabric like intake gaskets...
4) there is too different sizes for the gen/alt stand (1) gasket that has smaller loovers and on that has larger..(was thinking of putting the smaller loover'd one in becuase i had issues when it the larger one was installed correctly..) which one!!
I ask these because after starting up my "new/rebuild" engine it only ran on the "left" side.. so we knew it was an intake leak.. (because it ran great when rev'd higher..)
and we also had lots of oil coming up from the gen/alt stand into the air cleaner.... YES THE ALT/GEN STAND GASKET WAS INSTALLED CORRECTLY!! im 100% positive (researched on here seen multiple posts about it and had my friend (30 yr vw mechanic) come over and he said it was installed correclty...
Thanks again Guys!!! _________________ Knowledge is Power Read and Learn !!!
The Intelligence of a Man should not be measured by his age....
check out my sand rover t bug build! http://www.thesamba.com/vw/forum/viewtopic.php?t=287204 |
Posted: Tue Jul 20, 2010 8:03 am Post subject: |
im pretty sure that the ridge on the metal intake gasket goes up according to the book i have at home....
any insight? _________________ Knowledge is Power Read and Learn !!!
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Tue Jul 20, 2010 8:26 am Post subject: |
thanks..
seen that picture when searching... so i have it in the right postion.... what about the size of loovers??
have a couple gasket kits with 2 dif. size loovers in it.. _________________ Knowledge is Power Read and Learn !!!
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Tue Jul 20, 2010 9:35 am Post subject: |
The louver size doesn't make a difference. Main thing it prevents oil from foaming or coming up the neck. |
Posted: Tue Jul 20, 2010 9:42 am Post subject: |
im asking because i had the gasket installed correctly and i had oil still coming up the neck and into the line that goes to the air cleaner....
when i took apart everything (to fix an intake leak) and this issue i verified i had the correct direction etc... and then got out my gasket kit sets..
and bam! (2) different sized loovers same gasket both fit.. didn't know if there was a larger one or a smaller one....
figuring that a larger one would be the root of my problem..
Thanks! _________________ Knowledge is Power Read and Learn !!!
Posted: Tue Jul 20, 2010 11:16 am Post subject: |
well im going to use the smaller loover'd gasket....
hopefully that will solve the oil blow by in air cleaner...
and i believe ridge up is the correct way to postion the intake metal gaskets...
ill be careful when installing them to torque one bolt then the other...
nice and even to get a good squish....
i also have the fabric style that i will use instead if i can find them both.... jeez where did i put the other gasket....
Thanks!! please post if you have ANYTHING to contribute... _________________ Knowledge is Power Read and Learn !!!
Posted: Tue Jul 20, 2010 2:14 pm Post subject: |
Quote: |
and i believe ridge up is the correct way to postion the intake metal gaskets... |
You can install them that way but louver down is the correct way.
The louver down way deflects the oil down before it ever enters the generator/alternator stand. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Posted: Wed Jul 21, 2010 5:24 am Post subject: |
turboblue wrote: |
The louver down way deflects the oil down before it ever enters the generator/alternator stand. |
yep got that... just that there is two different sized loover'd sections....
ill get a picture... i used the smaller one and put it back together and still getting some (not that much) oil squirting into the air cleaner... _________________ Knowledge is Power Read and Learn !!!
Dale M. Samba Member
Posted: Wed Jul 21, 2010 8:35 am Post subject: |
Louver size will not do a thing to help your problem, if you are getting oil pushed up through breather tube its probable because of to much pressure in case maybe to much blow by at rings..... You are trying to cure a symptom and maybe not the problem....
Posted: Wed Jul 21, 2010 9:14 am Post subject: |
Dale M. wrote: |
Louver size will not to a thing to help your problem, if you are getting oil pushed up through breather tube its probable because of to much pressure in case maybe to much blow by at rings..... You are trying to cure a symptom and maybe not the problem....
Dale |
ok... Thanks ill check into the oil pressure side of your statement...
to be honest when the engine started for the first time the oil pressure gauge wasn't working..(still isn't) so i will look into getting it wired correctly and report back what i get....
i ended up going with the "felt" intake gaskets and used the smaller "looverd" gasket face down to the right...
after start up ( didnt get a chance to break it in since it wasn't running on both sides last time) i got a milkly oil mixture coming up still from the alt/gen stand... def. not as much....but still a little
seemed really hot but i haven't been around an aircooled engine that ran for quite a while.. (will get a thermometer and oil pressure gauge fixed before next start up)...
also want to note that i got a "white" smoke coming out of the exhaust after shut down and it smelled weird... i figure it might be the grease that i put on the gaskets (only a light film..)
any ideas? _________________ Knowledge is Power Read and Learn !!!
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Jul 21, 2010 9:54 am Post subject: |
bpritchert87 wrote: |
Thanks!! please post if you have ANYTHING to contribute... |
The smaller the holes, the less breathing, the more oil will blow.... |
