jessereitz Samba Member
Joined: August 14, 2010 Posts: 77 Location: Chicagoland, Illinois
Posted: Wed Aug 25, 2010 8:34 pm Post subject: no spark in a 1965 1200 |
I have a 1965 Beetle with an original 1200 in it. It will not spark, let alone start. I have replaced the coil, condenser, and battery. What would keep it from sparking? There is a green wire that looks as though it is coming off of the choke on the carb. It is not attached to anything. Will this have anything to do with it? _________________ 1964 Type 113- Waiting for $$$ for off-pan |
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Wed Aug 25, 2010 8:46 pm Post subject: |
Start with the basics - do you have 6V (or 12V if it's converted) to terminal 15 on your coil when the key is on? That terminal 15 is also the terminal your choke wire connects to (it's supposed to be a black wire, by the way) The green condensor wire connects to terminal 1 on the coil. I'd leave the choke unhooked while you figure out your spark issues though.
The points, are they opening? Are they free of corrosion or dirt? If you have +6V, and you open the points by turning the engine over by hand, you should be able to see and hear a small spark at them when they open, if they do not, something is wrong. And when them open you can use a screwdriver to short across them to also generate a spark.
What distributor do you have on there? (Yes, I know you said it was an original 1200, but I had the original engine in my 62 when I got the car in 1989 and it did not have the original distributor)
-Andy |
Posted: Thu Aug 26, 2010 6:41 pm Post subject: |
could any of the fuses prevent my distributor from producing as park? _________________ 1964 Type 113- Waiting for $$$ for off-pan |
Hammarlund Samba Member
Joined: June 15, 2009 Posts: 1539 Location: Central Texas
Posted: Thu Aug 26, 2010 9:03 pm Post subject: |
Quote: |
could any of the fuses prevent my distributor from producing as park? |
Not under normal circumstances. The line to the coil is supposed to be unfused. This is why we have to be careful when we handle it!
This diagram is not completely correct for your car; but it does show most of the important parts of the ignition system:
The biggest difference is that on your car a seperate wire runs straight from the B+ terminal on the voltage regulator to the ignition switch; it does not tie in at the headlight switch as on this diagram.
It's going to be a lot easier to fix this if you have a test lamp, or a voltmeter. You need some way to tell if voltage is present at a given spot or not.
Consider buying a multimeter. They are not expensive; a perfectly good one can be had for less than fifteen dollars, and you've already spent that much on ignition parts you didn't really need!
If you buy a voltmeter, I personally would get an analog one, like this:
http://www.sears.com/shc/s/p_10153_12605_034823620...482362000P
Digital ones tend to be confused by the rather intense electromagnetic fields present around an ignition system that uses points and a coil.
Whether you use a meter or a test lamp, you need to check for voltage at the coil as per Andy's post above. _________________ Trying to diagnose electrical problems without paying attention to what the red light is telling you is like trying to play the piano without using your hands. |
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Thu Aug 26, 2010 9:22 pm Post subject: |
Hammarlund wrote: |
Is this diagram wrong then?
http://www.thesamba.com/vw/archives/info/wiring/bug_62.jpg _________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote: |
I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
Posted: Thu Aug 26, 2010 10:16 pm Post subject: |
Quote: |
Is this diagram wrong then? |
Aw, hell, I was tracing the wire backward. How embarrassing.
I'm going to sit down and shut up now. _________________ Trying to diagnose electrical problems without paying attention to what the red light is telling you is like trying to play the piano without using your hands. |
64vdub Samba Member
Joined: August 05, 2008 Posts: 614 Location: Sunny So. Cal
Posted: Thu Aug 26, 2010 10:41 pm Post subject: |
A multimeter WILL give you the answer. Start with the basics _________________ 64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
Founding member of Derkaferklub, Southern Cal. since 2008
Q: Would you consider a trade? What do you collect?
A: I collect money
GO SF GIANTS! |
Posted: Fri Aug 27, 2010 12:54 pm Post subject: |
I should add that the engine turns over. I am getting electricity everywhere except the spark plugs _________________ 1964 Type 113- Waiting for $$$ for off-pan |
Posted: Fri Aug 27, 2010 3:13 pm Post subject: |
You say you get power every where but the spark plugs - does that mean you actually did a voltage check at the plus terminal (15) on the coil?
The power line going from the ignition switch terminal 50 to the start-tab on the starter is one straight cable - but then the power lead going to the terminal 15 on the coil is different - it makes a stop at the fusebox first, the unfused side of the fuse closest to the steering column, then back to the rear. So, two different pathways, you can have one connected and work fine but have problems with the other - that's why we've telling you that you need to get a meter and check for voltage at terminal 15 on the coil.
If you haven't, get yourself a multimeter. Heck I've bought like like 8 or 9 different ones over the years, some are really el-cheapo ones I got for 5 dollars at Harbor Freight, (others are much more expensive ones for tach/dwell, thermometer, and other more advanced functions) but all you really need is a basic one to check for voltage there - Something like this will work fine:
http://www.harborfreight.com/7-function-digital-multimeter-90899.html
You never said, is the car 6V or 12V?
-Andy |
casamagana Samba Member
Joined: February 21, 2009 Posts: 81 Location: West Covina, CA
Posted: Fri Aug 27, 2010 4:12 pm Post subject: Let me try |
You said "There is a green wire that looks as though it is coming off of the choke on the carb. It is not attached to anything. Will this have anything to do with it?" Is the wire attached to your distributor bright green? I wonder if it is broken off of the distributor and incorrectly attached to the choke?
Try this. Key off. Disconnect anything attached to the neg. side of the ignition coil (term. 1). Key on. Take your test light, 6 or 12 volt as appropriate, and check for power. If it lights, chances are everything from that point back to the ignition switch is good. If it does not light, start tracing backwards.
A picture of the distributor, choke, and coil connections would be helpful. _________________ 1966 Bug
1978 Super Beetle Convertible |
Posted: Sun Aug 29, 2010 10:51 am Post subject: |
sorry guys, i've been busy lately. The car is a 6v _________________ 1964 Type 113- Waiting for $$$ for off-pan |
Posted: Sun Aug 29, 2010 11:39 am Post subject: |
6V can be more promblematic due to poor connections and subequesnt voltage drops.
Anyway you still need to get a test light or voltmeter and do some troubleshooting. |
Posted: Sun Aug 29, 2010 8:08 pm Post subject: |
maybe I should be more specific. I have electricity in the car at least. I have a few test lights actually, how do I test it? I tried what you said but i could not get anything _________________ 1964 Type 113- Waiting for $$$ for off-pan |
Posted: Mon Aug 30, 2010 5:34 pm Post subject: |
Please help me! how do i test for power at the coil. You guys keep saying to, but I don't know how. I put the positive to the positive side of the coil, and the negative to the negative, I got no light. I don't know if I am doing it wrong, the light doest work, or a combination of all three. Help please! _________________ 1964 Type 113- Waiting for $$$ for off-pan |
Posted: Mon Aug 30, 2010 6:00 pm Post subject: |
You just turn the key on, put your test light or meter on the plus side/terminal 15 (black wire) on the coil and the other wire to the engine block or any other bare metal/ground. |
Posted: Mon Aug 30, 2010 6:03 pm Post subject: |
ohhhh okay, thanks! _________________ 1964 Type 113- Waiting for $$$ for off-pan |
Zundfolge1432 Samba Member
Posted: Mon Aug 30, 2010 6:10 pm Post subject: |
All very good advice but for the complete novice I'd go directly to Muirs troubleshooting for no start condition he needs to understand primary from secondary and proceed in a logical order which as John wrote it is easy to follow.... I know we all rag on John from time to time myself included but his troubleshooting diagram is easy to use ............It saves time to instead of buying things like batteries, this guy is gonna spend a fortune using the shotgun approach... |
