portable propane grills
TopBud
TopBud is offline
PostPosted: Wed Aug 25, 2010 10:06 pm    Post subject: portable propane grills Reply with quote
I like to BBQ. I have a cheapy propane bbq I got from a yard sale for a few bucks and the flame isn't consistent and always blows out. I am wondering who has a "nice" portable propane grill set up. I want to stay propane, so I can hook it up to the tank and not tote around charcoal. post some pics to if you have them. Nothing better than bbq'd food.
Thanks
86 bostig SYNCRO
66 convertible Karmann Ghia
Rhinoculips
Rhinoculips is offline
PostPosted: Wed Aug 25, 2010 10:16 pm    Post subject: Reply with quote
I have a Magma Grill and mounted on the rear passenger quarter panel. Stows under bench while in transit. Do a search, there are many other nice ones.
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
1621
1621 is offline
I've admired Rhinoculips' set up for some time. Very slick, though I imagine it could be on the higher end cost wise.
Otherwise your average camp stove could work just fine. Coleman or the like.
Edit: Looks like he beat me to the Submit button by seconds. Very Happy
'85 Westy
jackbombay
jackbombay is offline
PostPosted: Wed Aug 25, 2010 10:21 pm    Post subject: Reply with quote
That is a nice set-up Cool
Which model do you have? I found one like yours on their website, but it was charcoal.
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
Rhinoculips
PostPosted: Wed Aug 25, 2010 10:30 pm    Post subject: Reply with quote
Here's the one I have. They have a little nicer one with a hinged lid which I really like. They are not cheap, but well worth it and will last several generations Very Happy
http://www.magmaproducts.com/Products/Marine_Products/Gas_Barbeque_2/Gas_005/A10-105/a10-105.html
The mount I used......
Click to view image
TopBud
TopBud is offline
PostPosted: Wed Aug 25, 2010 10:36 pm    Post subject: Reply with quote
that's what I was looking for. Thanks. I saw that picture a while ago and couldn't find it again. not cheap, but well worth it I guess, I was also looking at the holland companion
http://www.hollandgrill.com/index.cfm/fuseaction/products.detail/prodID/2/index.htm
also not cheap, but it will last a long time. I have a regular size holland and love it, but it is not a burger kind of grill, it is more like a convection oven. I love it though. Thanks
86 bostig SYNCRO
jackbombay
PostPosted: Wed Aug 25, 2010 10:39 pm    Post subject: Reply with quote
How is the heat output on it? I have had a few small portable LPG BBQs over the years and they seem to range from just hot enough to not really hot enough.
Samba ad here.
PDXWesty
PDXWesty is offline
PostPosted: Wed Aug 25, 2010 10:47 pm    Post subject: Reply with quote
I have a Weber Baby-Q (Q-100) and it performs better than any grille I've owned. The flame control is excellent on high and low, and the cast iron grille has excellent heat retention. I've been very happy with it. I also have a cast iron griddle that works very well when used on the grille. The problem I've had with a lot of the portable grilles is flame up when cooking on low like with chicken. Most don't cook on low heat very well. The Weber cooks on low with little flame up and very good heat control, but on high it will definitely broil a steak.
http://www.amazon.com/Weber-386002-100-Portable-Gr...amp;sr=8-1
89 Westy 2.1 Auto
Rhinoculips
PostPosted: Wed Aug 25, 2010 11:46 pm    Post subject: Reply with quote
My magma grill has an excellent heat output, very wide range. Low works great for slow cooking and high for that fast sear. Smooth action knob too.
Click to view image
Timwhy
Timwhy is online now
PostPosted: Thu Aug 26, 2010 4:23 am    Post subject: Reply with quote
I too have the Weber Q100. PDX Westy said it all, the grill works like the larger Weber I have on my deck. I have been very pleased with it cooking all sorts of meats and veggies. The only drawback to the Q100 is the size, if you're entertaining a large crowd, you may have to cook in stages.
The price was right for me too. My boss's boss gave me mine when I told him that it would go nicely in my Westy when I go camping. He said really, take one!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
DAIZEE
DAIZEE is offline
PostPosted: Thu Aug 26, 2010 4:32 am    Post subject: Reply with quote
Hints. If you have 2 burners (a few small ones do) then you can cook chicken over the turned off side. That should eliminate flare up, but this may take longer and requires that you not lift the lid as often.. Used on bill grills. Also I have a squirt bottle of water for flare ups. Another good way to cook chicken and keep it moist but cooked thru is to nuke it for several minutes. Gets the inside done better rather than having to burn the outside.
I got a new Toolbox BBQ when I came back from my trip last November. Haven't gotten to use it but hope to remedy that soon.
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
dhaavers
dhaavers is offline
PostPosted: Thu Aug 26, 2010 6:24 am    Post subject: Reply with quote
Mine (cheap):
http://www.amazon.com/Coleman-PerfectFlow-Insta-Start-Propane/dp/B000BPHNK4
$40 clearance - and now's the time of year to find BBQ deals! This has a surprisingly strong burner and heavy, porcelain-coated cast iron grate.
Not sure if it would turn down low enough for slow roasting/smoking. Works great for me because most of my camp cooking is quick: chicken/burgers/brats...
PS - Keep in mind, I'm CHEAP! Still, I love the look of the Magma & it'd be super easy to cook under the awning if there's weather...(just can't swing the $200+)
Bon appetit!
"The WonderVan"
climberjohn
climberjohn is offline
PostPosted: Thu Aug 26, 2010 8:32 am    Post subject: Reply with quote
I have heard good things about the Coleman Road Trip grill.
Dragonfly Vans (VW van rental outfit in Idaho) provides them with all van rentals, which to me says something about their quality and performance.
For you vans without a kitchen, this grill works as a normal stove and as grill, possibly a nice double duty item.
Amazon link:
http://www.amazon.com/Coleman-9949-750-Road-Trip-G...-2-catcorr
EDIT: More experienced users later on this thread have posted that this grill is Less Than Ideal, so please ignore this post! My face is red!
xo,
CJ
'86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
VANACATE
VANACATE is offline
PostPosted: Thu Aug 26, 2010 9:24 am    Post subject: Reply with quote
Its not a gas grill, and a little old school, but after much thought I settled on this little guy a while back as I really like the functional design:
http://www.sonofhibachionline.com/
buildyourown
buildyourown is offline
PostPosted: Thu Aug 26, 2010 9:36 am    Post subject: Reply with quote
I have the small Sea-B-Que. It's very light and portable. Fits in my rooftop box. Big enough to cook for several people if you are good with space and crafty.
Heavy duty SS will outlast me.
I got it as a gift but it's the best car camping/westy accessory ever.
VANACATE
VANACATE is offline
PostPosted: Thu Aug 26, 2010 9:39 am    Post subject: Reply with quote
And for the luxury of cooking big group meals with standard pots and pans at a campsite I keep this guy under the back seat (more then boiling water on a pop can stove) Very Happy
http://www.moontrail.com/primus-twin-stove.php
j_dirge
j_dirge is offline
PostPosted: Thu Aug 26, 2010 9:42 am    Post subject: Reply with quote
Have had a couple of the Magmas over the yrs on various boats.
Tough kettles! Charcoal or gas.. My latest one is gas and has additional heat plates that allow better/even cooking with pots/pans.. So you can easily turn it into a "stove". Pretty good heat/cook control.
Nice compact size.
Very easy to clean. All stainless. Parts are easily available. A bit pricey.
I've never had a Magma age out or stop working.. They've only moved on when a boat was sold.
We have one of the big Weber Qs.. a 330 I think, for use at home. It is a GREAT grill!
..and the little Q100 looks to be a good choice, too. I have had my eye on the little one for the family cabin... but they are not that cheap either.
Some advantages though, can be disadvantages.
The Magna needs a stand/mount.
The Weber portable Q-series needs a table of some sort..
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
PDXWesty
PDXWesty is offline
PostPosted: Thu Aug 26, 2010 9:47 am    Post subject: Reply with quote
I've been on a lot of campouts where people had the Coleman grilles and have been really disappointed with them. They're really not grilles at all though. They're a stove burner with a grate over the top. About the only thing they cook well is hot dogs. With the burner flame so close to the grate, it burns almost everything. I wouldn't consider this at all if you really like to grill/bbq.
89 Westy 2.1 Auto
Jon_slider
Jon_slider is offline
PostPosted: Thu Aug 26, 2010 10:11 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=295515&highlight=grill
on the right is a $20 Coleman single burner.
Here is a $5 Charcoal grill
http://tinyurl.com/ykala5z
Note that the Magma and Webber Q cook with the lid closed, true slow cooking BBQing.. the others are just grills, they only cook uncovered, which works fine for things that cook quickly
1621
1621 is offline
PostPosted: Thu Aug 26, 2010 12:36 pm    Post subject: Reply with quote
Jon_slider wrote:
You must not have kids or pets. Laughing
'85 Westy
Page 1 of 7
