sjhotz Samba Member
Posted: Thu Sep 16, 2010 8:24 am Post subject: |
Hey gang, need some opinions, just got a 74 Thing, getting it worked on. I was talking to my mechanic about some modifications on the car, and I mentioned my concern about stopping power on LA freeways and possible disc brakes up front.
What he wants to do is use drums from a super beetle which have larger and wider pads(which he has lying around so it would be much cheaper than disc conversion). He has the same setup on his Thing, and just did it on another one for another customer, and he has given me a nice set of 4 pattern alloy wheels to match the super beetle hubs which I just need to go get blasted and polished. And supposedly its much easier to find the pads.
My only concern is he mentioned that I would widen my wheel base by about 1/4 inch on each side. I was'nt quite sure what he meant (does it need a spacer or something due to different drums so they wont rub?, etc...), i mentioned my worries about offset. he assured me it would be stable at high speed and aid in cornering both on and off road.
Any of you have some insight on if this will work and any experience personally on results? |
man130 Samba Member
Joined: August 25, 2008 Posts: 407 Location: long island , ny.
Posted: Thu Sep 16, 2010 10:30 am Post subject: |
| I dont have any idea weather it would stop better then original, but my super with four wheel drums still might kill that old lady if she steps it front of me. As for clearing up what the mechanic meant when he said it would increase the wheel base by 1/4 inch each side, He must mean the drums are wider thus sticking the tire/rim out 1/4" each side. I thought THING drums where wider anyway ,but that may be only the rear ,not sure .I would look into Kublemans porsche/ghia disc conversion if your looking for the cheapest/effective way to get stopping power. Good luck |
GI Joe Samba Member
Posted: Thu Sep 30, 2010 5:54 pm Post subject: |
So I've read through Many of the tire threads and mainly see either Low rider, or Off road sizes/pics...
How 'bout some DD street radial sizes/pics.
I'm running 15x5.5 all around, and just have gotten over the 215/75 AT's.
I'm looking for something a little wider footprint, and a little lower profile(not a Lot though).
I've contemplated 255 60, OR 245 60's....
Thoughts/pics anyone? _________________ FORWARD: forward is only a good thing, when you're facing the right direction!
'74 Thing, "Our Thing"....
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
www.NLEOMF.com
Respect, Honor, Remember |
Pierre G Samba Member
Joined: April 28, 2007 Posts: 1769 Location: New Caledonia
Posted: Thu Oct 14, 2010 12:20 am Post subject: |
| GI Joe wrote: | .
Thoughts/pics anyone? |
I thing these sizes would be too big for your rims. I wouldn't buy wider than 225. Maybe 225/60 or 225/70 if this size exists... _________________ 1976 181/Thing (daily driver), 1967 fastback, 1973 squareback, 1964 microbus, 1967 Double Cab, 1969 westfalia (currently under resto), 1972 westfalia, 1978 westfalia, 1972 LM1C dune buggy, 1974 jean's bug, 1974 1303 (super beetle, currently under reassembly after new paint) + 2 semi wrecks 181 (1971 and 1972)... |
GI Joe Samba Member
Posted: Thu Oct 14, 2010 4:20 am Post subject: |
Pierre,
I agree with you on the too wide.. I've done a bunch more research and found that a 205 70 Or 205 65 is best suited for my wheel width. Although I think a 225 60 would be best suited for what I am going for, look wise although a tad wide for my wheel, But, 225 60/70 are recommended for 6-9" wide wheels.
More research is needed here! _________________ FORWARD: forward is only a good thing, when you're facing the right direction!
www.NLEOMF.com
thegunter Samba Member
Posted: Sat Nov 13, 2010 8:32 pm Post subject: |
| Just bought a 73 safari, and I was wondering if anyone knew if they ever came with 4 lug, or if that was something that someone converted it to, and how hard would it be to change it back? If pictures would be helpful, let me know! |
Semper_Dad Samba Member
Joined: May 14, 2005 Posts: 2612 Location: HELL Paso, TX
Posted: Sat Nov 13, 2010 8:34 pm Post subject: |
US Things were normally wide 5 on 14 inch wheels. 15 inch as option and military. Were your brakes converted to disk? Front drums are Beetle, rears are Thing specific and expensive.
Welcome to the group! _________________ 74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
Washington State 181 (Thing) Registry - current tally: 58
World 181 Registry Map: http://www.zeemaps.com/394427 Gitm registared boys!
Officially, there are only 98 181s in the world |
Posted: Sun Nov 14, 2010 10:33 am Post subject: |
| Not converted to disk, i've got drums all around, and they're all 4 lug... I'm pretty bamboozled... |
Posted: Sun Nov 14, 2010 11:01 am Post subject: |
| thegunter wrote: | | Not converted to disk, i've got drums all around, and they're all 4 lug... I'm pretty bamboozled... |
I'm guessing that the original rear drums needed replacement and the PO went with a cheaper alternative (bug drums). The front were replaced with matching 4 holes so he would have matching wheels (including spare) all around.
You can continue to run the 4 lugs or "reconvert" back to original. Those Thing rear drums run about $130 each for new German drums. Kubelmann may have some used for a little bit less. I hate skimping on important items like brakes so I would go for new.
Other option is to go disk conversion. $$$$$$, but well worth it.
Don't forget if you go back to "wide 5" you'll need to change your wheels also. Maybe a 4 lug disk conversion would make lemonade out of lemons. _________________ 74 VW Thing - Walküre
Posted: Sun Nov 14, 2010 3:29 pm Post subject: |
| That's pretty much what I'll have to do I think. Just a four lug disk conversion. Thanks for the input everyone! |
SilverThing  Samba Member
Joined: July 19, 2004 Posts: 633 Location: Boise/Seattle
Posted: Mon Dec 13, 2010 9:45 pm Post subject: |
I was poking around through some old posts from one of the German speaking 181 forums elsewhere on the internets and came across a post about tires from a company I hadn't come across before.
http://www.papp-gumi.hu/index.php?action=shop&lang=GB&PID=1
They come in 185/70-14 and are only about $58 a piece at current exchange rate (I tried to post a picture, but it didn't come out). They remind me of some of the tires the Bundeswehr started using on the 181 later on (sometimes referred to as a NATO NDT).
Unfortunately, they are made in Hungary. I really wish we could get them here in the US... _________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 799 Location: Aiken, South Carolina
Posted: Wed Dec 29, 2010 12:25 pm Post subject: |
Ok.. I'm researching some stuff for my 944 disc swap, and need a little help with tire size. I know that I will gain 4.5mm offset on each side of the front. The wheels I have are 15x7 Cookie Cutters at 23.3mm offset, which gives roughly 5.9in of backspacing. Thing 14in wheels are 32.5?mm offset and 4.375in backspace. The outside of the wheel will sit inboard roughly 4mm from stock, and the inside a little over 2in (this concerns me the most).
How big can I go on tires before rubbing becomes an issue? I'd really like to fit 215/75/15 BFG Mud Terrains. It doesn't seem like the headlight buckets will be an issue, but I could definitely see the pan lip rubbing.
Any thoughts?
[edit] Oops, way off on my Cookie Cutter backspace calculation. Should be ~4.75in. |
Tait D Samba Member
Joined: July 21, 2008 Posts: 38 Location: Los Altos California
Posted: Tue Jan 18, 2011 7:33 pm Post subject: |
Just got new tires today!
It was time to replace those ancient Yokohamas (215 65 r15)
I went with the General Grabber at2 at 205 75 r15
All stock suspension except some Gas-a-justs in the rear, no rubbing or anything. I love the look and I love the height
can't wait to really test them out
 _________________ Life is much better in an air-cooled |
Posted: Wed Jan 19, 2011 8:00 am Post subject: |
Could you possible post a few more pictures with the Grabbers and let me know how they do on and off road?
I am leaning away from MT's and towards the 205/75 Grabber. It seems like a great balance of performance and road manners (not to mention cost and extra work involved). |
Tait D Samba Member
Posted: Fri Jan 21, 2011 5:45 pm Post subject: |
Well the look of the Generals is great
They are a little softer than my last tires, but so far they run very well on road
I don't have any complaints about road noise, not even noticeable considering how loud Things are
I just did some light offroading today, performed excellently, but let me emphasis LIGHT offroading. The best is yet to come. And keep in mind these tires got excellent off road ratings
In my opinion, the 205s are a good choice
Posted: Sat Jan 22, 2011 12:25 pm Post subject: |
Very nice, thank you!
The 60K mile warranty and off-road reviews say a lot about the Grabbers, not to mention being made by Continental. Looks like a definite winner to me. |
EODinert Samba Member
Posted: Sat Jan 22, 2011 3:04 pm Post subject: |
My thing came with 4 bolt beetle drums, too... Just a previous owner that was too cheap to fit the right parts. I just recently swapped them out for proper 5 lug wheels.
Those hungarian tires are awesome... I need some of those. _________________ '61 rag top beetle, '73 type 181, '66 13 window deluxe |
Alexios Samba Member
Posted: Mon Jan 24, 2011 9:46 am Post subject: Offset and backspace calculator |
Hi
Stumbled across this nifty calculator while i was trying to find out how much 5,5" vs 4,5" rims will stick out.
http://www.rimsntires.com/specs.jsp
Alex |
poptop Samba Member
Joined: February 27, 2003 Posts: 545 Location: jersey
Posted: Mon Mar 21, 2011 7:06 pm Post subject: |
ok can i use 15 inch bus rims in back or 14 bus rims in back and stock thing rims up front and have no problems ?? I read allot of thing threads and came up short on that. I have two things but one has severley rusted rims. and one already has 15s in back and 14s up front. 1979 safari. and 74 thing rusty rims. I already have allot of bus rims is why i ask! _________________ So what I drive the short bus! |
Van-go108 Samba Member
Joined: November 23, 2006 Posts: 3037 Location: Southwestern, NM
Posted: Tue Mar 22, 2011 6:40 am Post subject: |
Bus wheels. (all pre-1958)
Although, these are thin wheels (4") they appear to be inset further into the wheel well. I have "street tires" on this set of wheels but will probably get Off-Road tread later. It's the look I was going for. It seems wide is the norm. I would like to find a pair of widened 15" four slotted KPZ's or Lemmerz. There was/is a set in the classifieds but they're 14". I havn't seen or heard of any fitment issues. It's more about the tires you will try to use. _________________ "Okay, so there's 6 beers and 5 of us. You know what this means don't you? 4 of you are going to have to leave."
1983 1/2 Wasserbroken Vanagon(storage shed)
1973 Thing
1957 Continental Mark II Click to view image |
