No $ for real relay..please help me wire this one
Goto page 1, 2  Next
sharkskinman
Lateral Lunatic
sharkskinman is offline
PostPosted: Wed Oct 27, 2010 8:05 pm    Post subject: No $ for real relay..please help me wire this one Reply with quote
i looked and looked and found a relay out of a saab
that has similar numbers and general placement on the tabs
OG: 411 941 583C (can use #111 941 583)
Part Code: 4109070A
Part Name: Bulb Check Relay
Part Description:
Bulb check relay for any 9000 94-98, 900 94-98, 9-3 99-03, 9-5 all.
The German made PA6 Hella relay (Saab part no. 4109070) is Hella part no. 5KG005675-01.
i dont have 25-30 dollars for this relay
on OG: 56,56a,56b, S
saab: 56a, 56al, 56aR, 56b, 56bl, 56bR, 31, C2
i can just pull the wires out of the fuse box and hook it up
S on OG relay in same spot as 31 on orange relay
im beleiving that the "a" is front and "b" is back
and there is L/R for each
56aR,56al and C2 are all smaller tabs and can be cut and not used
on the relay in my 411 the 56a isnt hooked to anything
sorry so the pics are so big
i used digital macro
red lead pencils work great to mark parts
no if they only made ones but only white
4/71 ~311 "Bettie" (F.I./Auto)
Supaninja wrote:
BTW none of us are "buggin" here, we roll something far superior to a bug
Ward Cleaver wrote:
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards
PS3 Black Ops "NKOGNEATO"
raygreenwood
raygreenwood is offline
PostPosted: Thu Oct 28, 2010 5:36 am    Post subject: Reply with quote
So what happened to your original relay? Are you sure its toast? Ray
sharkskinman
Lateral Lunatic
PostPosted: Thu Oct 28, 2010 9:33 am    Post subject: Reply with quote
so heres the OG relay
i think i found one for 11$ shipped but still with no job cant even afford that at the moment
but if i can just pull wires and hook this saab one up
ill be ok till i an get the real one
im only driving it to 2 places
first friday at findlay
and a get together sat morning right down the road
in the pool service
we would have rusty tools all the time
and we would soak a rag in Tranny Fluid and wrap them up
next day they would work perfect
can i just either soak it in Tranny or Brake fluid
i just need it to work untill i can get the real one
raygreenwood
PostPosted: Thu Oct 28, 2010 12:05 pm    Post subject: Reply with quote
Ok...here is the problem. 411's and 412's are notorious for leaking around the corners of the windshield. The water dribbles down and leaks into the relays which are upside down. It keeps them full of water. You need to take a file or dremel and knock the corners off the relay covers so they drain. Then smear the bottoms with silicone sealer and plug them back in after they dry. Until you fix the windshield gaskets...this will keep this from happening.
Better check your blinker relay as well. If you are dying for a relay...I can send you a spare. Ray
bb412
bb412 is offline
PostPosted: Wed Nov 03, 2010 5:12 am    Post subject: no for real realy Reply with quote
this realy is for the hi,and low beam, you can find the same on the motor cicle, harley,, i thing,, or for vw type1 and 2,for the years 70
sharkskinman
Lateral Lunatic
PostPosted: Wed Nov 03, 2010 9:22 am    Post subject: Reply with quote
ok
keifernet sent me a couple
and im getting a click but NO change in the hi/lo
then i put the OG one back in and same thing
click (slight) but no switching
also i keep burning the 1st fuse out when i turn the lights on
altho the lights do still come on
bb412
bb412 is offline
PostPosted: Wed Nov 03, 2010 10:04 am    Post subject: real realy Reply with quote
ok,, plug the realy and open the light swith for the low beam,,turn the key on ,, look if you have the low beam are open,, if not look the fuse,,or the wire on the realy,, if you have the low beam push the contact ,up and down ,in the realy for to see if you have hi beam,,use ,,vtvm testor for to test te contact on the realy,,good luck,,bb412
sharkskinman
Lateral Lunatic
PostPosted: Wed Nov 03, 2010 12:03 pm    Post subject: Reply with quote
i need to bridge the terminals to see if it clicks without the turn switch
(which terminals?)
i have outer low beams
and i here a slight click when flicking the turn switch
but they dont change
in Virginia i had an Old Spark Plug Cleaner that hooked to the cigerette lighter
i used that to media blast the ends of the wires on my 67 and 70 T3s
cant find one now...damn
bb412
We have to work on how you type
only put 1 coma or a coma and a space
or try to make them there own line
so its not such a run on
im sorry Embarassed
if this offends you(none meant)
but its hard to read your posts sometimes
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Nov 03, 2010 12:31 pm    Post subject: Reply with quote
bb412 is a French speaking Canadian I'm thinking. We have Americans here, who think it's Cute to use NO capitals/punctuation!
http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500
raygreenwood
PostPosted: Wed Nov 03, 2010 1:02 pm    Post subject: Reply with quote
bb412...is Albert. Yes...French Canadian. He is a nice guy and has such a lot of type 4 information and experience I totally overlook his keyboard issues. Ray
sharkskinman
Lateral Lunatic
PostPosted: Wed Nov 03, 2010 1:55 pm    Post subject: Reply with quote
Oh...
...Haha! Laughing
i know your talkin bout me..
i know i know im horrible sometimes too
Mike Fisher
PostPosted: Wed Nov 03, 2010 2:10 pm    Post subject: Reply with quote
I wasn't really Spoon, since you at least put each thought on individual lines!
bb412
bb412 is offline
PostPosted: Wed Nov 03, 2010 4:18 pm    Post subject: realy Reply with quote
hey,,guy,, i make my best for to help you,, i know my english is not very good,, but my expérience on the 412 is not too bad,,thanks RAY,, btw,, if you look the pict.no 6,, you can see métal blade on the white plastic roller,, at each time you click the stearing arm, the métal blade swing on each side of the plastic gear,,she slide each side of the point,the most long plastic point,, by this action ,, you have the contact on the hi or low beam,,this realy is spécial for vw or motor cicle,, the stearing swith geeve the 12 volts on the realy coil,,,, only for 1 sec. ,,,only the time you make the click on the stearing swith,,it is like that for the long life for the coil,,tooday on the modern car ,,the stearing swith keep the 12 volts for the contact,, not like the old vw,, your problem is from the rust and the switching blade is a kind of spring blade ,, and now the blade d,t can keep her spring and she is finish,, look for to find an good relay,,vw,,or harley motor cicle,, the modern realy d,t can doo the job,,french bb412,,lol,,
sharkskinman
Lateral Lunatic
PostPosted: Wed Nov 03, 2010 4:59 pm    Post subject: Reply with quote
i have a couple other relays i got from keifernet that im going to try
but if they dont work
what should i be looking at
**For ALL ACVW Owners**
i bought another small 12v spark plug cleaner
i have used them before to "media blast" the tips of wires
they are just too hard to use a regular small brush
when the new one gets here im going to take the fuse box apart and clean all wires and soak the plastic parts so there is No Rust Anywhere
(also going to do EVERY wire end in the car)
my car has been sitting for more than 20 years
everything is dirty
i mean couple coats of brown, dirty!
and if you find it hard to type English as you speak french
try this http://babelfish.yahoo.com/translate_txt
i wonder how it would translate "Literally"..ha
bb412
bb412 is offline
PostPosted: Wed Nov 03, 2010 5:43 pm    Post subject: realy Reply with quote
sharks,,, look your pict,,5,, on the lefgth side of the realy,, you can see the 2 contact with long blade in the midle,, the midle blade is for 12 volts,, and the 2 oder contact are for the hi or low beam,, if you push on the midle blade for to geeve the contact on the bothom contact ,,the low or hi beam are on,, if the fuse burn ,, the realy is ground or you have an short circuit on the light wire,,make sure you have the good électric diagram for your car,,good luck,,,bb412
sharkskinman
Lateral Lunatic
PostPosted: Wed Nov 03, 2010 8:11 pm    Post subject: Reply with quote
ok so ...???
56---power from the headlight switch
56a--High Beams
56b--Low Beams
S-----Ground?...goes form headlight relay to heater switch?
31----?????
what is 31 for???
after taking my 411 to the VW get together this friday
"baby's first day out" Laughing
Most of the electrics are coming out
all the wires are getting cleaned
take the Emergency, headlight switch, radio, guages all out
all the relays will be cleaned
i think as you said bb412 the rust is just kinda everywhere
here and there on all the electrics
im also going to check things like continuity and such of the wires for everything i clean
Image may have been reduced in size. Click image to view fullscreen.Image may have been reduced in size. Click image to view fullscreen.
so im looking in my Drake and Clymer books and at the wiring diagram
and this is off a bus page
THIS one has dual horns
any of the others up till this one(year)
dont have duals
im tring to figure which diagram is correct
and didnt i see a diagram that was Colored/Vertical/English
in one of these posts not long ago
bb412
bb412 is offline
PostPosted: Thu Nov 04, 2010 4:01 am    Post subject: realy Reply with quote
sharks,, the 31 is a kind of ground for ,, realy ferrit,, it is for to ground the métal in the center of your realy coil,, not for the rest of the realy,, only for the center of the coil,,,,2,,, if you have the rust in the contact of the realy,,that can make an short circuit ,, each contact blade are insulate of the body ground,, the ,,,S,, is the normal ground for the realy coil,,the stearing swith is not ,,positive power,, the ,,S,, go on the stearing swith,,, and the stearing frame is your ,,S,,ground,,and the circuit is close,,
bb412
bb412 is offline
PostPosted: Thu Nov 04, 2010 10:19 am    Post subject: realy Reply with quote
sharks,,the ,,s,, go on the stearing swith ,,on ,,s,,, and ,,31 is ground with brun wire,, bb412
ALLWAGONS
ALLWAGONS is offline
PostPosted: Tue Dec 07, 2010 9:41 am    Post subject: Reply with quote
I just had the same problem as you. It rained a lot on Sunday night, on Monday morning I had no headlights, I pulled the relay and it was full of water. I pulled it apart to dry it and it was just as rusty as yours. i replaced it with my spare and it would click but no lights. I pulled it apart, cleaned it and I either had a right low beam or they would get stuck on high. Later it just stopped working. I went to my friend's place and he had a used one lying around. I installed it and I got them working again.
Cancer, You have claimed another beautiful life, but You will be defeated....
I rather have a profitable than a sustainable lifestyle
bb412
bb412 is offline
PostPosted: Tue Dec 07, 2010 2:48 pm    Post subject: no ¢ for realy Reply with quote
you can seal the hole by onder the dash,, and seal the window seal with the sylicone ,,the window frame as a hole on the corner,, you can see this hole by onder the dash with a good light,,bb412
Goto page 1, 2  Next
