Hose for heater aux fan
Wildthings
Wildthings is offline
PostPosted: Mon Nov 22, 2010 8:13 pm    Post subject: Hose for heater aux fan Reply with quote
Looking for hose to run from the electric fan in the engine compartment to the tubes running down to the heater boxes. Found this stuff on line. Open for opinions on this hose and any other possible solutions.
http://tinyurl.com/29xrwr2
vonkr
vonkr is offline
PostPosted: Tue Nov 23, 2010 2:42 am    Post subject: Reply with quote
If it fits, I think it's a perfect solution!
raygreenwood
raygreenwood is offline
PostPosted: Tue Nov 23, 2010 6:52 am    Post subject: Reply with quote
Looks decent. Zims is a very good place . I used to buy certain parts there when I lived in Dallas. They are just on the South side of pricey so if its something you needed it was not too painful. They had lots of Hella parts. Ray
Bill12
Bill12 is offline
PostPosted: Tue Nov 23, 2010 6:34 pm    Post subject: Bus depot has heater hoses? Reply with quote
http://www.busdepot.com/details.jsp?partnumber=211261235A
and the alt. side.
http://www.busdepot.com/details.jsp?partnumber=211261236
germansupplyscott
germansupplyscott is offline
PostPosted: Wed Nov 24, 2010 7:48 pm    Post subject: Reply with quote
the fan is 60mm on one side and 55 on the other.
scott lyons
http://www.germansupply.com
VW Bus-Centric Online Parts Source
Wildthings
PostPosted: Tue Nov 30, 2010 6:33 pm    Post subject: Reply with quote
That is true for a bus, but checking the hoses sizes for my '72 411 4dr shows that they are both 55 mm, at least on the fan end.
germansupplyscott
PostPosted: Tue Nov 30, 2010 6:52 pm    Post subject: Reply with quote
type 4 parts books says:
411 261 235A warm air hose, left 55mm dia x 300
411 261 236A warm air hose, right 60mm dia x 520
scott lyons
raygreenwood
PostPosted: Tue Nov 30, 2010 8:35 pm    Post subject: Reply with quote
I believe the wagon with its odd blower had the two different diamter hoses. The two and four doors with center mounted blower had equal size hoses if memory serves. I can measure both when i get home this weekend. Ray
Wildthings
PostPosted: Tue Nov 30, 2010 8:52 pm    Post subject: Reply with quote
I went out and remeasured my blower, yes Scott is right there are two different sizes on the 4 dr. The book shows it is the wagon style blower that uses the same diameter hoses for both sides. Don't know what the VW engineers where thinking when they came up with the various systems they used for the heat, they just seemed to like to come up with a whole pile of different parts for slightly varying applications.
VW must have had an engineering exchange program with the truck division of International Harvester. Gotta keep that interchangeability down to an absolute minimum for some reason.
raygreenwood
PostPosted: Wed Dec 01, 2010 7:21 am    Post subject: Reply with quote
Wow....talk about memory failure Laughing . I knew there was one that was odd.....I could of sworn it was the wagon blower. That one with its odd connections ...and the one really long hose to get back to the right side.
Learn something new every day. Ray
germansupplyscott
PostPosted: Wed Dec 01, 2010 10:03 am    Post subject: Reply with quote
not that the parts books has everything 100% correct, but typically they are pretty accurate. the book only shows one blower, it's the centre-mounted one similar to the bus unit - early type 4 powered bus has a blower that is identical to the 411 unit in fact. later bus has a plastic housing to the blower but the hoses are still the same size.
what is this other type of blower you're speaking of - for a wagon?
scott lyons
Wildthings
PostPosted: Wed Dec 01, 2010 10:14 am    Post subject: Reply with quote
Wagons had a single outlet blower mounted off to the left side that connected to a "Y" setup to feed the two heater boxes. The outlet of the blower itself was rectangular in cross section.
raygreenwood
PostPosted: Wed Dec 01, 2010 3:34 pm    Post subject: Reply with quote
X2...yes. If memory serves (which sometimes it does not Laughing )....the actual motor on both models is the same, but the squirrel cage is different on the wagon.I think smaller in diameter but longer, and as Wildthings noted, the single side opening housing. I think at one time I may have swapped a wagon motor into a 4 door...it was a bit of work. Ray
Wildthings
PostPosted: Wed Dec 01, 2010 5:04 pm    Post subject: Reply with quote
I went down the motor swapping road a few years back, and remember that there were multiple motors used over the years. I seem to remember that there was a minimum of interchangeability between them. Different mounting of the motor to the fan housing, different rotation, and maybe different amperage as well.
raygreenwood
PostPosted: Wed Dec 01, 2010 6:55 pm    Post subject: Reply with quote
Yes....pretty much all true. The wagon version is more can shaped and maybe slightly larger in diameter (motor can). It also has a different mounting plate and required different holes in that plate to mount to a 2 door style housings....and the fan had to be swapped...not easy but I cannot remember exactly what was required.....and I think I had to swap polarity.
It was easily 15 years ago. After that I quickly got as many spares of the right kind as possible.
I do remember that at first blush I thought it would be a simple swap. It ended up as two days of miserabl crap to get a functioing swapped over motor. It was cold so I needed it.
It ran for a long time though...and I may still have that motor somewhere. Ray
