Thermo Time Switch differences
Wildthings
Wildthings is offline
PostPosted: Wed Dec 22, 2010 10:40 am    Post subject: Thermo Time Switch differences Reply with quote
Need to replace the Thermo Time Switch on my '72 411 which is running an L-Jet FI system off of a '76 bus. Would love a TTS which operated at about 20-25°C verses 35°C. Any one know what rigs might have used a TTS that operated in this range?
Thanks
Wildthings
PostPosted: Wed Dec 22, 2010 8:13 pm    Post subject: Reply with quote
Well getting no replies I guess I will go with the OEM 35°C TTS. Looks like JC Whitney will get my business with a genuine Bosch switch for $75 shipped. They also have the 15°C Porsche switch of $87 shipped.
Wildthings
PostPosted: Thu Dec 23, 2010 12:22 pm    Post subject: Reply with quote
Ordered the one for the Porsche from JC Whitney. Don't think I have ordered anything from them in a decade or more, not typically my first choice. But they supposedly have the part and they claim its a Bosch.
Why do these things fail or get out of adjustment anyway? I found several 35°C ones in my stash and all were still in the closed (cold) mode at least as high as 45°C.
raygreenwood
raygreenwood is offline
PostPosted: Thu Dec 23, 2010 7:03 pm    Post subject: Reply with quote
Sorry I was not close to my books and things to answer. They fail because they are a bimetallic element inside. Over the years and also with eat cycling, both metals work harden and lose some of their expansion or contraction ability. This makes them no longer accurate and sometime no longer operable. They can also corrode if they get moisture in them. There are also some models on some cars that have their own electrical heating element in them to give them the time feature. That can also burn through and fail just like a choke element. Ray
Wildthings
PostPosted: Thu Dec 23, 2010 7:16 pm    Post subject: Reply with quote
After not being able to find one that operated perfectly in my stash, it's got me worrying about keeping an L-jet running cheaply for another decade or two. I guess a button in the dash would work well enough if and when they become unavailable.
Wildthings
PostPosted: Fri Dec 31, 2010 12:37 am    Post subject: Reply with quote
JC Whitney didn't come through with a TTS for a Porsche, so I ordered one from them for a bus. We will see if they can supply the bus one for their quoted price.
Lars S
Lars S is offline
PostPosted: Sat Jan 01, 2011 6:57 am    Post subject: Reply with quote
There are lots of cheap (and small) industrial thermo switches available to almost any temperature setting and differtent hysteresis, wonder if these can withstand the vibrations at a car engine....
However these have no internal heating element in them so they will only use the heat from the engine to react and the right location is more important.
Below is one example.
/Lars S
http://ae.rsdelivers.com/product/rs/2455r-9082-459...82658.aspx
Porsche 914 -72, Bahia Red daily driver
VW411 2-d -70, White, in archive
VW412 4-d, -73, Gold Metallic, daily driver
Suzuki T500, -69, Candy Gold, in archive
Suzuki K50, -77, Black, daily driver
BMW R69S -69, White, in archive
Husqvarna 118cc, -47, Black, in archive
Wildthings
PostPosted: Sun Jan 02, 2011 12:20 pm    Post subject: Reply with quote
I think I will take the new stock style TTS switch when I get it and make a custom mount for it, relocating it to where it will be easier to access and set it up so it has a better thermal connection to the block.
ALLWAGONS
ALLWAGONS is offline
PostPosted: Thu Jan 06, 2011 9:40 am    Post subject: Re: Thermo Time Switch differences Reply with quote
Thanks
What's the part #?
Cancer, You have claimed another beautiful life, but You will be defeated....
I rather have a profitable than a sustainable lifestyle
Wildthings
PostPosted: Thu Jan 06, 2011 9:56 am    Post subject: Re: Thermo Time Switch differences Reply with quote
ALLWAGONS wrote:
Thanks
What's the part #?
Haven't found that such a part actually exists. The ones for a T4 engine either operated below 10°C or 35°C depending on year and the Porsche ones below 15°C. I have found nothing that tells me at what temperatures other cold starts on other vehicles operate. Was hoping someone else might know.
ALLWAGONS
PostPosted: Thu Jan 06, 2011 10:20 am    Post subject: Reply with quote
Actual pic. I'll look in my parts manual. I need onetoo. So I was told.
