Project Widow Maker
Goto page Previous  1, 2, 3 ... 9, 10, 11, 12  Next
Forum Index -> Kit Car/Fiberglass Buggy Share: Facebook Twitter
wythac
wythac is offline
PostPosted: Sat Nov 06, 2010 9:57 am    Post subject: Reply with quote
Having indulged in some of those sorts of diversions you describe during my builds, I think I might be able to answer that;
Sometimes I didnt feel like taking on a big project, or wanted to see something done that would provide some immediate gratification. I would pick some little BS thing that I could see completed in a few hours.
Another thing I would do is spend some time assembling things that I knew would have to be disassembled before final install. In many instances during the mockup process, I just wanted to see if something was going to look as I envisioned. Other times, I just wanted a taste of what the completed car was going to look like, and I would spend a few hours working again on stuff I knew was, in the grand scheme of things, a waste of time. One thing these sort of diversions did provide was inspiration to continue, a whetting of the appetite for getting the car done.
gr8cobbler
gr8cobbler is offline
PostPosted: Sat Nov 06, 2010 10:22 am    Post subject: Reply with quote
Well said Wythac, The big jobs need significant time commitments, the wife & kids, and job make those chunks of time pretty hard to find, at least for me. Most of my build time is comprised of 15 minute bursts unfortunately. I don't want to screw up an engine rebuild by not being able to focus uninterupted and do it right the first time.
Being able to complete any part or aspect keeps the momentum, small though it is, going in the right direction. On a build like this one I imagine there are many problems that take some real head scratching and if allowed to cook over time produce better answers. A side project, spare tire mount with matching lug wrench, is low stakes progress during the mental simmering time for the major problems. Cool
I think JSB's point is also understandable and I wish my life afforded me the ability to keep the horse in front of the cart all the time. Smile
Gary
Being a cheap old fart is just a front for my actual lack of money. Smile
jspbtown
jspbtown is offline
PostPosted: Sat Nov 06, 2010 2:14 pm    Post subject: Reply with quote
gr8cobbler & wythac:
Interesting perspectives...thanks.
Maybe I should try that on the Avenger. I even chose cutting back all the dead plants and mulching leaves today instead of sanding primer. I did get the inspiration to apply the guide coat....not much of a project...but maybe I will assign it into one of those "inspirational diversions" tasks.
Who knows...maybe I will feel like sanding all day Sunday!
Thanks guys.
dsmbuggy
dsmbuggy is offline
PostPosted: Sat Nov 06, 2010 3:53 pm    Post subject: Reply with quote
For me it is more important to do little things than not doing anything on the project.
There is so many little things to do.
when they are done I cross them off my list and move to the next.
I sometime need those instant gratification one hour jobs to keep me going when motivation is low.
Don't worry I get back to bigger stuff soon.
New ideas do not scare me, old ones do.
Thanks: TANGO, MATTY, JE, MEMER.
http://www.1aauto.com/blog//
GS guy
GS guy is offline
PostPosted: Sat Nov 06, 2010 6:50 pm    Post subject: Reply with quote
I find that it's largely a matter of "this needs to be fleshed out before I can fit that". For instance I was recently working on "tabbing out" the rear of my chassis to mount engine wiring. Sounds simple enough? But found I needed to complete the engine wiring harness to figure out where the tabs needed to be. That wasn't so simple! But once the wiring was in place and hooked up (not insignificant on an EFI/turbo motor!) I could find perfect placement on the tabs.
Then there's the other ideas that pop up when you're working on something else - and realizing that if you're going to follow through on that idea - it needs to be done now rather than later. At least that's what I run across.
Even small or relatively simple accomplishments bring a lot of satisfaction!
70's vintage Deserter GS buggy - undergoing transformation to Super GS!
Raketemensch
Raketemensch is offline
PostPosted: Tue Nov 23, 2010 7:15 pm    Post subject: Reply with quote
Just gotta say.... I had kicked the Samba habit, I hadn't logged on for almost two months, until this afternoon when your build jumped into my head.
I love this thing, and it's good to see all the progress you've made.
superman73
superman73 is offline
PostPosted: Mon Dec 13, 2010 6:24 am    Post subject: Reply with quote
any updates?
Chuck
Jesus Saves
98 TDI beetle 5-speed
70 deluxe bus
74 ghia 1776 dual carb
67 manx clone
66 safari trail
various other parts cars.
http://www.thesamba.com/vw/forum/viewtopic.php?t=228364&highlight=superman73sb+bellsouth
Azsilverbug
Azsilverbug is offline
PostPosted: Sat Dec 18, 2010 10:10 pm    Post subject: Reply with quote
I like it.
You can tune a piano,but you can't Tuna Fish
1962 Bug
1968 Bug
1976 Bug
Manx clone on 65 pan
dsmbuggy
dsmbuggy is offline
PostPosted: Sun Dec 19, 2010 7:49 am    Post subject: Reply with quote
Sorry for the lack of updates.
The last couple of month I focused on getting the car started again.
That means redo the fuel system, coolant lines to the back, and water to air intercooler system.
Bosh 044 fuel pump, big filters and AN8 braided lines.
The mounting straps for the 12 gallons aluminum fuel tank and the fuel pump wiring underneath the tank. (notice the cooling Jug for the beer)
I actually use the cooler as an ice chest for the water to air intercooler.
I also received my new turbo: Forced performance DSM 82 HTA.
Should be good for around 700hp.
With this I ordered this beautifully crafted JMF drag manifold.
This thing is a beast.
The engine bay coming along.
Notice the waste gate dump BOSOZOOKU STYLE
The office.
My friend Tango also started the fab of the aluminum sides.
His fab table.
Complex shapes.
The front half in place.
The complete side pods.
That is all for now.
EODinert
EODinert is offline
PostPosted: Fri Dec 24, 2010 8:51 pm    Post subject: Reply with quote
This car is so bad-ass.
'61 rag top beetle, '73 type 181, '66 13 window deluxe
portlyparatroop
portlyparatroop is offline
PostPosted: Thu Jan 13, 2011 8:19 pm    Post subject: Reply with quote
whew.... what an inspiring 10 page read! (nice to see someone else thinking outside the box)
*also* glad to see you plan on helping that little 4G63 a bit... think they were only around 190hp. stock - KEEP AFTER IT (wish I was closer to help)
superman73
PostPosted: Fri Jan 14, 2011 7:58 am    Post subject: Reply with quote
any progress?
Chuck
Jesus Saves
70 deluxe bus
67 manx clone
66 safari trail
OutCasted
OutCasted is offline
PostPosted: Thu Jan 27, 2011 8:24 pm    Post subject: Reply with quote
superman73 wrote:
any progress?
X2
dsmbuggy
dsmbuggy is offline
PostPosted: Sat Jan 29, 2011 2:13 am    Post subject: Reply with quote
Wiring.....wiring..... cables.... relays..... switches....more wiring...
It is cold in here (28º in the garage)
adriaan pienaar
adriaan pienaar is offline
PostPosted: Sat Jan 29, 2011 6:29 am    Post subject: Reply with quote
dsmbuggy wrote:
(28º in the garage)
Celcius Image may have been reduced in size. Click image to view fullscreen.
Farenheit? Image may have been reduced in size. Click image to view fullscreen.
Twisted Evil
Looking good! Cool (as always Wink )
Please say Hi to us at
www.aircooledvwsa.co.za &
www.hotwheelsclubza.com
dsmbuggy
dsmbuggy is offline
PostPosted: Sun Jan 30, 2011 7:20 am    Post subject: Reply with quote
28º Fahrenheit.
I was getting bored with wiring so I decided to build the member brace.
The front subframe on DSM is prone to crack when removing some of the engine bay OE bracing.
I decided to build this brace because I remove quiet a lot of material up front.
I used part of the existing braces for mounting points but my brace connects the A arms mounting points.
I used square tubes but skinned them to avoid flexing.
I love my flaring dies.
All tack welded.
fully welded and painted.
TC/TeamEvil
TC/TeamEvil is offline
PostPosted: Sun Jan 30, 2011 9:14 am    Post subject: Reply with quote
OK . . . . where'd you get those cool flairing dies ?
dsmbuggy
dsmbuggy is offline
PostPosted: Sun Jan 30, 2011 12:43 pm    Post subject: Reply with quote
http://vansantent.com/sheet_metal_machines/flare_tools.htm
superman73
PostPosted: Mon Jan 31, 2011 6:29 am    Post subject: Reply with quote
SWEET!!!! Very Happy
Chuck
Jesus Saves
70 deluxe bus
67 manx clone
66 safari trail
EODinert
EODinert is offline
PostPosted: Thu Mar 31, 2011 12:51 am    Post subject: Reply with quote
This thread seriously needs an update...with lots of pics, please.
Reply to topic    Forum Index -> Kit Car/Fiberglass Buggy All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 10 of 12
