marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Mon Oct 11, 2004 3:22 pm Post subject: Proper Prep. for repainting a roughish OG Paint VW? |
sorry, this is really long...but any suggestions or reassuarnce would be very welcomed...this will be my first body restoration and I want to do it as best as I can.
I've gone through countless threads trying to learn what I need to do at various stages of my body resto and was having trouble seeing the forest from the trees. So I put this list together as a road map of where i need to go and how i plan on getting there:
I think I have picked several medium and top-grade products that can be applied safely at home with affordable installation and safety equipment (appropriate filters, eye protection and ventiliation when welding/painting). From what I could tell, all these products are compatible with each other in my proposed applications.
The products I plan to use are:
POR-15 (rust inhibitor)
MasterSeries CT (rust inhibitor) and AG111 (hard enamel paint)
Rust Bullet (rust inhibitor)
Evercoat Rage Gold (filler)
Evercoat Easy Sand or Metal Glaze (glaze)
“All Metal” Filler (made by who?) (for filling at welds)
Dupont Centari Acrylic Enamel with Dupont Reducer and Urethane Hardener (Paint)
Primer: Dupont product _________?
Primer Sealer: Dupont Product _________?
Seam Sealer Brand? Weldable Primer Brand?
Step 1: Weld in Replacement Panels:
a. Remove crusty, rusty, weak sheet metal
b. Remove paint and surface rust
c. Fit replacement panel
d. Apply weldable primer (contains zinc, use filter when welding)
e. Apply POR-15 to backsides of panels that will be inaccessible after welding
f. MIG weld the panel in with many small tack welds
g. Grind welds smooth
h. Apply seam sealer to flanged and spot welded seams
i. Apply additional POR-15 along backside of welded seam
j. Clean welds with denatured alcohol and finish with “all metal” filler
k. Dry sand filler to smooth. Use a glaze filler to remove pinholes
Step 2: Fix Dented Areas:
a. Remove Paint and surface rust
b. Straighten using body tools
c. Dry sand dented area with 80 grit or 40-36 grit roloc discs
d. Apply Master Series CT (if dent was rusty)
e. Clean surface with denatured alcohol (if dent wasn’t rusty)
f. Fill with Evercoat Rage Gold w/ blue catalyst
g. Dry sand filler (36,80,180,320 grit)
h. Apply Evercoat Easy Sand or Metal Glaze to remove pinholes
i. Sand glaze coat (400-600 grit?)
Step 3: Fix Surface Rusted Areas:
a. Remove paint and surface rust
b. Etch metal
c. Apply MasterSeries CT to exterior and interior exposed body panel rust
d. Apply Rust Bullet to hidden and hard to reach rusty areas like: window sills, interior floors and interior of doors
e. Dry or wet sand smooth where accessible or exposed
Step 4: Recondition the Undercarriage:
a. Remove old paint, grease, surface rust and undercoating
b. Scuff surface with wire brush
c. Apply Rust Bullet
d. Apply MasterSeries AG 111 (flat black) to underside of car.
e. Not planning on sanding it smooth
Step 5: Prepare the original paint for repainting:
a. Wash and Degrease
b. Remove any spray paint and rattle can primer down to original paint.
c. Scuff the original paint with 400 grit
d. Wash with denatured alcohol? Wax and grease remover product?
Step 6: Prime Coat and Painting (ChillKoot’s method as described in the sticky)
a. Etch bare metal
b. Apply primer
c. Apply guide coat
d. Wet sand 300-400grit
e. Apply primer
f. Apply guide coat
g. Wet sand 600-800grit
h. Let sit 2-3 weeks to allow primer to shrink
Step 7: Painting:
a. Wash and use wax/grease remover product
b. Apply Primer Sealer in a color close to the final paint color (2 coats)
c. Base Coat, flash, Top Coat, flash, additional Topcoats w/ AE paint if desired
d. Color sand as necessary
Suggestions?....
Thanks, Mark Laken _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1046 Location: Jacksonville, FL
Posted: Sat Jun 02, 2018 5:34 pm Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
Resurrecting this thread after 14 years with no answers.
I could use answers to these questions. Anyone have input?
Cheers,
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
jason Samba Member
Posted: Fri Jun 08, 2018 5:35 pm Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
What was question, I read it as a statement?
Media blast, epoxy, filler, primer and paint. |
Spezialist Banned
Posted: Mon Jun 11, 2018 5:36 pm Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
Evil_Fiz wrote: |
Cheers,
Emil |
Great autobody restoration guys use quality materials, didn’t see any on the list.
I only use PPG or Glasorit. About the same cost overall. Worth every penny.
Right out of the gun after 30 minutes to clear the fumes out of that tiny space
No buff, no bullshit. _________________
Posted: Wed Jun 13, 2018 6:59 am Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
Spezialist wrote: |
...Great autobody restoration guys use quality materials, didn’t see any on the list.
I only use PPG or Glasorit. About the same cost overall. Worth every penny. |
Nice work, it gives me hope that i can paint my Ghia in my two car garage. Since you have a good understanding of what is going on, could you elaborate on the above list and perhaps make recommendations on products and procedure?
Thanks,
kiwighia68
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Jun 13, 2018 10:54 am Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
Evil_Fiz wrote: |
Spezialist wrote: |
Thanks,
Emil |
You've been 'talking about paint jobs' for 3 years & have not made any progress yet? Buy CUSTOM PAINTING by Tom Brownell & follow his advice! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Spezialist Banned
Posted: Wed Jun 13, 2018 11:39 am Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
Evil_Fiz wrote: |
Spezialist wrote: |
Thanks,
Emil |
I did a repair on that bus outside while it was snowing in gilroy California, I’ve learned how to more with less over the years.
I painted this bus panel by panel outside of my shop in Lahaina, since shop space is so expensive there. There was no room in my shop.
Eventually I’ll do a write up for the home hobbiest on the tricks I’ve learned.
I had a head start since my dad was a union autobody frame guy when I was growing up.
I’ve litteraly been doing it since I was a kid. _________________
Spezialist Banned
Posted: Wed Jun 13, 2018 11:43 am Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
Mike Fisher wrote: |
Evil_Fiz wrote: |
Spezialist wrote: |
Thanks,
Emil |
You've been 'talking about paint jobs' for 3 years & have not made any progress yet? Buy CUSTOM PAINTING by Tom Brownell & follow his advice! |
I respect slow cautious moves by potential restoration neophytes, more cool cars have been ruined by good intentions of dreamers than I care to think about. Hi Mike! _________________
Posted: Wed Jun 13, 2018 11:45 am Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
...You've been 'talking about paint jobs' for 3 years & have not made any progress yet? Buy CUSTOM PAINTING by Tom Brownell & follow his advice! |
I apologize for mistaking this forum as a place to ask questions and educate myself. Please let me know what a reasonable time frame is to gather the information I seek and complete my project. If I had the the good fortune of having been born knowing everything required to complete all tasks expected of me before my expiration date, I would be sharing that knowledge with others rather than deriding them for attempting to learn from the experiences of others. Everything YOU know today had to be learned. I'm sure you asked for help once or twice along the way.
... and yes, I HAVE made progress on my project (take a look at my build thread if you don't believe me,) but that does not mean I have to stop educating myself and looking for complimentary or alternative information.
Since you have been keeping such a close eye on my forum activity, please make note of all the opportunities I have taken to help others. I don't know everything but I know how to be helpful and humble.
"Custom painting - The do-it-yourself guide to custom painting" by Tom Brownell was written over 18 years ago. I'm certain new products exist that were not covered in the book.
The good news is that hidden within your caustic response is advice I can actually use. I was unaware of that book. Thank you kindly.
kiwighia68
Posted: Wed Jun 13, 2018 12:08 pm Post subject: Re: Proper Prep. for repainting a roughish OG Paint VW? |
Spezialist wrote: |
The kid looks comfy and pretty impressed with your work as well
Looking forward to your "Tips-n-Tricks."
kiwighia68
