Bad bug Samba Member
MinamiKotaro Samba Member
Joined: July 18, 2008 Posts: 1039 Location: Somewhere in TN
Posted: Sun Apr 12, 2009 2:56 pm Post subject: |
I've seen posts where people say they run them but I've yet to see anyone mention the specs or give a part number for the ones they use. _________________ 1967 VW Beetle
2276cc
MegaSquirt-extra v3.57
Check out my ongoing story. |
Posted: Sun Apr 12, 2009 4:05 pm Post subject: |
These springs will make a world of difference for valve control. I only wish someone that has used them will post here soon. |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sun Apr 12, 2009 4:32 pm Post subject: |
Bad bug- I haven't used them but am very interested as well. Some information from Alan Harland on Beehives:
-you need a .200" longer valve.
-installed height- 1.720 to 1.740"
-at 1.720"- 170 lbs. on the seat, 350 lbs. over the nose at .575" lift
-coil bind- 1.080"
-spring diameter- 1.2975"
- titanium retainers- 7 grams each
They're supposed to control harmonics much better than conventional springs so lighter spring pressures can be used. RD Spring (760 948 4698) are the people to talk to. Joel Mohr (posts on the CLF)is also a fan of beehives. He runs a shop in Hesperia, CA.That's all I know. Let me know if you find out anything. Al
Joel Mohr- [email protected]
760 947 6647
http://www.mohrprf.com/news.htm _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
cptcliffhanger Samba Member
Posted: Wed Feb 02, 2011 8:54 pm Post subject: |
bump for more interest! I want to use these instead of dual springs on my next engine! |
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Wed Feb 02, 2011 9:04 pm Post subject: |
Call and talk to Geoff Hart. He told me when I was ready to step up some more that he had something worth looking at. He pulled a set of these out from his front office. _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Wed Feb 02, 2011 9:09 pm Post subject: |
well it seems like the natural progression, GM is still making two valve head, pushrod engines and they seem to think this is the way to control the valves.. I want this technology on my next heads! |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Thu Feb 03, 2011 5:47 am Post subject: |
As already mentioned, contact Joel Mohr. IIRC, he has a combo that does not require longer valve stems. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
74 Thing Samba Member
Posted: Thu Feb 03, 2011 9:19 am Post subject: |
After you talk to Joel let us know what you find out and decide! |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Thu Feb 03, 2011 6:56 pm Post subject: |
http://forums.aussieveedubbers.com/viewtopic.php?tid=83554
Haven't heard any reports yet but they look good _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Thu Feb 03, 2011 7:02 pm Post subject: |
You guys have it figured about right.
The springs would fit on the head ok I think
The problem is the coil bind at 1.080. Usual installed height is 1.550, so if we leave .080 from coil bind that only allows .390 lift.
If you worked with retainers and sunk the valves a little 1.600 installed height is easily possible, but that is still not enough, only .440 lift possible.
So the logical thing is to use type4 length(.200 longer) or 1/4" longer valves.
If you only plan on using .450 or less lift I know of a oval wire conical spring that binds at 1.00" even, and yields 240 lb open.
I will give you the part number if you answer me three riddles....... |
tcgmark Samba Member
Joined: August 07, 2008 Posts: 55 Location: Fullerton, CA
Posted: Thu Feb 03, 2011 10:20 pm Post subject: |
I installed a set of Beehive springs on my heads a year ago. I started with new CB 044 heads, 40 x 35.5. I found the install height and necessary seat pressure information and used a chart they have over at comp cams website. For my application I used part number 26125. I use 1.25 scat rockers and when my geometry was dialed in I had .496 lift with a w120 cam.
From my limited experience, different head and valve combos will use different springs. My buddy did the same as me but he used a different spring and he had street eliminator heads and what looked like stock style valves (my valves had surelock keepers on them which i believe changed the install height number a little).
All this was put together over at rimco. I worked with Todd over there, finding measurements and figuring seat pressures.
So far it runs very well, but to be honest, I don't rev my motor high enough often enough to take advantage of them. I, however, believe that it is a very worthy upgrade for the valve train.
btw, I opted to not use titanium retainers, 1 for cost, and 2 because I was unsure how they would hold up to the higher seat pressures that VW's have. |
bugracr Samba Member
Joined: December 01, 2008 Posts: 87 Location: raleigh nc
Posted: Fri Feb 04, 2011 5:47 am Post subject: |
i sent a message to mohr, he directed me to r/d springs. this is the reply i got!
Hello Kris,
I do have a beehive kit available that uses th OEM valves. It's only rated for a max lift of 0.520" and the valve guide boss must be turned to a diameter 0.625". It has 95 lbs seat pressure and 260 lbs at 0.500" lift. The kit cost is $360.48 and includes beehive springs, titanium top retainers and bottom spacers, $227.38 for the steel retainer kit.
Regards
Zach Jones
R/D Spring Corp. |
RIS Samba Member
Joined: December 18, 2003 Posts: 3043 Location: Youngstown, Ohio
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Dec 09, 2013 5:27 pm Post subject: |
Bump.
Any updates? That price quoted above, is that for 32 valve V8 kit or only 16 springs? |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
Posted: Tue Dec 10, 2013 12:26 am Post subject: |
I run Comp Cam #26125 springs with long valves (CB racemaster wich are good with their 8mm stem and 5/16" tip offering plenty of valve locks choice) and with an FK44 on my 2165 bus engine bare Tims stage 2 heads, chambers and exhausts ports CBC-1 coated, it runs great. All part are available as a single replacement part in case of failure, I'm happy with those
Tool steel lifter 56g (those ones :http://www.thesamba.com/vw/classifieds/detail.php?id=1135575 )
Smith brother alu pushrod 47g
Comp #26125 springs 47g
Comp #762 ti retainer 5g
Comp #619 caps 2.3g
CB rockers, matched weights
Comp #628 locks 2.5g
_________________ my French blog https://vwpanelvan.wordpress.com/
Click here for my full pix detailed 2165 engine build with beehive valvetrain.
Sorry for my poor English, I'm a French guy ... |
Mrblue01 Samba Member
Joined: January 09, 2009 Posts: 18 Location: Westland, MI
Posted: Tue Dec 10, 2013 8:25 am Post subject: |
Performance Springs Inc. sells a beehive spring that will fit some VW applications.
Spring # = D148X
ID top = 0.630"
ID bottom = 0.850"
OD bottom = 1.180"
117lbs @ 1.500"
250lbs @ 1.000"
$104 / 8springs
R/D spring has made a retainer specifically for this spring to use standard VW valves and locks.
http://www.psisprings.com/ |
wilbur Samba Member
Posted: Wed Jan 07, 2015 10:42 am Post subject: |
modok wrote: |
What is the wind speed velocity of an unladed swallow?
Do tell the oval wire spring P/N?
Do you have any pictures?
Thank you
Wilbur |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Wed Jan 07, 2015 1:30 pm Post subject: |
What makes a beehive keep harmonics under control is to have a one end bigger than the other by as much as possible.
To use a spring with a smaller than stock VW OD is a bad idea just so the spring will have the installed height you want. To use a spring like the part # above is not much better than using a standard VW HD single spring.
I will have more on this latter.
Dan |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
