67 Standard Peach Kombi, West Palm Beach, FL
Goto page Previous  1, 2, 3 ... 22, 23, 24 ... 27, 28, 29  Next
don.ville
Samba YardMan
don.ville is offline
PostPosted: Fri Dec 03, 2010 7:23 pm    Post subject: Reply with quote
RAMZROD wrote:
possible lost family member?
http://www.thesamba.com/vw/classifieds/detail.php?id=1007065
WTF?
What the heck is it with Peach and Florida?
Miami Vice went off the air sooo long ago Confused
View user's profile Send private message Facebook Twitter Gallery Classifieds Feedback
CUCARACHA
QUE BOLA, ACERE!
CUCARACHA is offline
PostPosted: Sun Dec 05, 2010 11:41 am    Post subject: Reply with quote
FUCK THE COLOR! 14,000 $ wtf the dash better be signed by hitler! thats it im selling my car i got papers backing up the story that ferdinand porsche vomited on my front fender after a ss party! asking 27,000$ Laughing
65 beeter and f&#% you josh!
boomtown
boomtown is offline
PostPosted: Thu Jan 06, 2011 9:44 am    Post subject: Reply with quote
I'm late to this thread but find it interesting to know that others busses steer sloppy. My wife and I just bought a dc that is all over the road and was told by the previous owner it needed a new steering box. I found this thread by following a link from the NDBS post, so dan.ville thanks for linking it. Now I will try other avenues before I buy a new rebuilt steering box. Off to read the remainder or this thread, only as far as page 11 to date. Very Happy
When the children get older and want to know where the money went, show them your vacation videos.
don.ville
Samba YardMan
PostPosted: Sun Jan 16, 2011 8:25 pm    Post subject: Reply with quote
After my driveway alignment, the wheels are straight, and the bus stays on path if you let the steering wheel go on the highway, BUT, the wheel was a little off center. Causes my turn signal to turn off too early on right turns.
I did not really want to redo the whole alignment, since it has been so good, so I detached the drag link with my new ball joint removal tool.
NICE ........... Very Happy Smile Cool
spin the ball joint twice and reattach. Wheel straight, me happy, and turn signal good to go....
don.ville
Samba YardMan
PostPosted: Sun Jan 16, 2011 8:29 pm    Post subject: Reply with quote
When I got the bus, I took off the pedal pan to work on the steering, and have not put it back on since.
Bout time now:
trying to clean up my garage, so out of the way means back on the bus where it belongs.
don.ville
Samba YardMan
PostPosted: Sun Jan 16, 2011 8:33 pm    Post subject: Reply with quote
FOURTH brake light Very Happy
Went to the junkyard today to get a third brake light from a late model Isuzu Trooper.
Had to use 3M moulding tape to hold it on to the inside of the glass.
don.ville
Samba YardMan
PostPosted: Sun Feb 20, 2011 8:47 am    Post subject: Reply with quote
Putting the peach to work:
don.ville
Samba YardMan
PostPosted: Sun Feb 20, 2011 8:55 am    Post subject: Reply with quote
Trying to find the solution to my rear wheel play.
http://www.thesamba.com/vw/forum/viewtopic.php?t=402226
Backing plate off (the weep hole was plugged with gasket sealer)
Using the floor jack to tilt the axle end up so the trans fluid doesn't leak out
Parts to go in
Order of parts as they were removed ( I think the spacer on the right side of the bearing is in backwards.)
Backing plate off
don.ville
Samba YardMan
PostPosted: Sun Feb 20, 2011 9:02 am    Post subject: Reply with quote
Bearing cap with spacer inside it.
There seems to be a custom
Parts as they were installed, separated.
More new parts
don.ville
Samba YardMan
PostPosted: Sun Feb 20, 2011 9:07 am    Post subject: Reply with quote
Looks like the part number is 211 501 311 but the middle of it was made larger with a grinder:
Caked up with gunk:
Clearing weep hole with wire.
Type 3 III drums fit into bearing cap after grinding by previous owner
don.ville
Samba YardMan
PostPosted: Sun Feb 20, 2011 9:19 am    Post subject: Reply with quote
Big spacer compared to spacer in new kit, not the same part:
Spacer parts comparison
I thought one side of this bearing stuck out more than the other.
Turns out the washer was stuck to the bearing
The axle tube end has a small recess (like a slight dish shape).Image may have been reduced in size. Click image to view fullscreen.
don.ville
Samba YardMan
PostPosted: Tue Feb 22, 2011 9:12 pm    Post subject: Reply with quote
Painted my used drums with hi temp flat black.
The order of axle seal parts on the Type 3 swing axle with new bearing
The EMPI spacer was slightly taller than the one that was in there.
That was the driver's side. The old bearing just came out of the axle tube by just using my hand to take it out.
When I put the new one on, I had to use the drum to press it all the way into the axle tube.
The in/out play that I had on the axle was gone by then.
Arrow Arrow Arrow Arrow
Passenger side was not so easy.
1) the spacer was hard to come off, so I had to get out my Harbor Freight special.....(I use it much more than I thought I ever would)
Here the sharp edges help split the spacer from the bearing.
Made a custom bearing puller using some leftover project bolts from Home Depot and a grinder (actually a cutoff wheel)
Back to the Harbor Freight special again
don.ville
Samba YardMan
PostPosted: Tue Feb 22, 2011 9:18 pm    Post subject: Reply with quote
Close up of the groove in the bearing cap to accept the large o-ring from the axle seal kit
A clean assembly photo of the bearing cap, seal, spacer, o-ring located in the groove, and high tack gasket sealer to try and keep it dry...
Put some high tack sealer on the backing plate too.
cru62
cru62 is offline
PostPosted: Tue Feb 22, 2011 9:53 pm    Post subject: Reply with quote
Thanks for the picture heavy posts. I, for one, really appreciate the visuals.
Founding member of
Arrested Decay
"Of all the myriad parts which comprise a modern automobile, the one most prone to sudden and catastrophic failure is often the nut behind the wheel"-anonymous
"Buy the best and cry once."-Gene Berg
bugger101
bugger101 is offline
PostPosted: Wed Feb 23, 2011 4:53 pm    Post subject: Reply with quote
are you going to winter jam in daytona
don.ville
Samba YardMan
PostPosted: Wed Feb 23, 2011 5:56 pm    Post subject: Reply with quote
Thanks
Yes...leaving WPB Friday morning and leaving Daytona Sunday
don.ville
Samba YardMan
PostPosted: Wed Feb 23, 2011 9:31 pm    Post subject: Reply with quote
Few days of driving after the axle seal job.
I installed the driver's side large o-ring in the space between the backing plate and the bearing
Snort wrote:
Large O-ring, hard to see on the early ones, they sit right in the backing plate space.
and got this:
I installed the passenger side large o-ring in the bearing cap
and got this:
arod
arod is offline
PostPosted: Thu Feb 24, 2011 6:17 am    Post subject: Reply with quote
Evil or Very Mad Evil or Very Mad Evil or Very Mad would be me!
1966 VW Westfalia
2008 VW Passat wagon
Live to drive vw's. Drive vw's to live.
bugginmiami
bugginmiami is offline
PostPosted: Thu Feb 24, 2011 7:43 am    Post subject: Reply with quote
And on the 8th day, god created 'The IRS Conversion'.
Youll get it donville! See ya this weekend.
jasonw
* Volksblast in Miami Jan 20, 2013 !! *
* ---www.volksblast.com--- *
don.ville
Samba YardMan
PostPosted: Thu Feb 24, 2011 6:41 pm    Post subject: Reply with quote
jasonw
The 9th day brought the Honda Odyssey minivan Very Happy
One day I guess, right now I'm living life as a swinger (axle).
Page 23 of 29
