gybemaster Samba Member
Posted: Fri Mar 18, 2011 1:40 pm Post subject: |
Ok, so I've just bought this to fit. However, apparently the bent-up bracket held a small bowden cable. One end clipped on the lever arm; the other end was operated by the cooling thermostat via an extension on one of the flap shafts in the shroud. Does anyone have pictures of what the special elongated shaft looks like so I can see if I have it to get the flap to work correctly? (I don't know what I'm looking for or how this setup to the air filter would look so I'm struggling to understand). I'd like to understand it though so if you could help I'd greatly appreciate it.
Also, should there be a little ball of weight on the end of the lever controlling the flap or is that correct as is? |
djkeev Samba Member
Joined: September 30, 2007 Posts: 8176 Location: Central Morris County, NJ
Posted: Fri Mar 18, 2011 2:44 pm Post subject: |
| gybemaster wrote: |
So sorry but which one did you purchase? This post is full of air filters and you "just bought this to fit"?
Which one is "this"???
Thanks
Dave
PS, I just noticed this is your post! Didn't know that before and here I was recommending that you look at it
Anyway, hows the ordering going?
Dave _________________ (o\ ! /o) (o)=l=(o)
1974 Super Convertible
http://www.thesamba.com/vw/forum/viewtopic.php?t=482968&highlight=rust+repair
Creating a 69 1/2 Ghia Convertible out of a 69 Coupe and a 70 Convertible
And the newest arrival!....... 86 Vanagon Westy!
http://www.thesamba.com/vw/forum/viewtopic.php?p=6315537#6315537 |
Snort Samba Member
Joined: April 02, 2005 Posts: 1188 Location: Seattle, WA
Posted: Fri Mar 18, 2011 2:51 pm Post subject: |
| If you have a cable operated warm air control, then it's the same type of setup as the late 60's 1500 air cleaners. Perhaps you should post a photo of your air cleaner in the Late Model Bug forum and see if anyone there has the cable system intact they could photograph for you. |
Posted: Fri Mar 18, 2011 3:38 pm Post subject: |
The shoppings going wel Dave, just bought a set of flaps + thermostat that are being shipped from your side of the pond over to me. The one I bought is:
I'm just trying to figure out how I get it to work with my shroud. Any ideas if its possible? |
djkeev Samba Member
Posted: Fri Mar 18, 2011 4:25 pm Post subject: |
Yes, it is possible. That air filter flap works off of the cooling flaps in the fan shroud that you are going to install.
Off the top of my head I don't have an illustration for you nor do I know if the flaps are different for engines with the cable controlled air filters vs the thermostat / vacuum controlled air filter flaps.
Do a little research on here, I do believe this was very recently covered with someone looking for the cable and the linkage for an air filter similar to yours. The cable system was installed for several years. being replaced by a thermostat on the filter and then a vacuum valve on the air filter. My 69 Ghia has the cable control flap but currently the engine is not easily accessed.
Anyone with information about the operating linkage and IF the flaps are unique for the cable controlled preheat flap??
BTW, with this air filter you would want the newer Breast plate with the 3 large holes.
Posted: Fri Mar 18, 2011 4:28 pm Post subject: |
| Cheers Dave, yeah I was going to acquire some tin with the thre large holes. Just need to know now if I can get this air filter fully functioning so hopefully someone can shed some light on how I go about it. |
djkeev Samba Member
Posted: Fri Mar 18, 2011 4:48 pm Post subject: |
| Pending the failure to implement a cable system could I just maually open and close the flap or would that pose issues? |
djkeev Samba Member
Posted: Fri Mar 18, 2011 4:59 pm Post subject: |
| So roughly speaking I should have the flap closed at what temp and open at what temp? Just so I can gauge the days as to when I shoud be opening or closing it? (Its not going to cause me engine problems is it not having it functioning with the exact engine temps controlled by the thermostat is it? |
djkeev Samba Member
Posted: Fri Mar 18, 2011 5:10 pm Post subject: |
On the air cleaners with the flap controlled by a thermostat (1971) the thermostat opens the flap at 27.5 - 32.5 C (81.5 - 90.5 F).
The thermostat senses the air temperature on the intake snout, not the temperature of the air passing through the snout.
Hope that helps steer you somewhat.
I live in New Jersey where we have cold winters (especially this year!) and hot summers. I (because my vacuum valve is bad on my 72 air cleaner) directly piped vacuum to the operating diaphragm all winter long. I'll undo it one the days are warm consistently, probably late May, early June.
Dave
(too bad you didn't know about the cable control needs of the air cleaner before ordering the flaps!) _________________ (o\ ! /o) (o)=l=(o)
Posted: Fri Mar 18, 2011 5:13 pm Post subject: |
| So in the winter I could leave the flap closed and in the summer leave it open essentially? |
djkeev Samba Member
KaferBus Samba Member
Joined: April 19, 2007 Posts: 164 Location: Albuquerque, NM
Posted: Sun May 15, 2011 5:18 pm Post subject: |
I hope I am not hijacking this thread....but I have a question about my oil bath filter too.
I have a 1600 single port engine in my 57'....is the engine to big for this type of filter?
I have heard from people it is not good for the engine to have a oil bath on it.....and I have another friend who says it is fine.
Advice?
Thanks in advance! _________________ 1957 Oval
1965 Kombi
1969 Beetle
1971 Super Beetle |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 9660 Location: Olympia Wash Rinse & Repeat
Posted: Sun May 15, 2011 6:59 pm Post subject: |
If you are not drag racing your 1600, it should be just fine. You might just need to change carb jets to have it work well. _________________ In Stereo, Where Available! |
fraggie Samba Member
Posted: Sat Jun 18, 2011 2:59 pm Post subject: |
Something i'm wondering.
does a oilbath filter better then paper filter ? _________________ http://fraggie.dyndns.org/ |
Posted: Sun Jun 19, 2011 8:09 pm Post subject: |
Yes.
Plus as you drive, the paper just keeps getting clogged up more and more.
With oil the filter element of coconut fiber just keeps being cleaned by the oil, and as long as you change out the filter oil when it is dirty as needed. _________________ In Stereo, Where Available! |
mrblyoung Samba Member
Joined: August 26, 2006 Posts: 580 Location: Turlock, CA
Posted: Mon Feb 06, 2012 5:10 pm Post subject: |
| gybemaster wrote: |
What is this oil bath off of? I have never seen one like that before and I have gone to a lot of swaps/seen a lot of VW's. I would like to find one of those as I have a 65 beetle and the larger oil baths don't fit very well under the decklid, but it is much easier for me to run the later engine tin as I have a 1600dp and would like to run the larger diameter pre-heat hoses. This oil bath is perfect.
Anyone that could shed some light to where I could find one of those, I would greatly appreciate it. |
Posted: Mon Feb 06, 2012 9:12 pm Post subject: |
Think it is a post-1968 air cleaner so the later 1600/1300 engines could be dealer installed in pre-1967 Beetles. _________________ In Stereo, Where Available! |
Posted: Tue Feb 07, 2012 12:28 am Post subject: |
| Yeah thats what it appears to be. Anyone know where to get one? |
