slammed 68 Samba Member
Joined: October 14, 2009 Posts: 58 Location: south bend IN
Posted: Sun Mar 27, 2011 6:13 am Post subject: speedo cable problem |
| my speedo cable was broken when i got the car bought one from ghia parts it broke going down the road. ordered another one it lasted two days then broke again. could it be the speedometer. its stamped on the back that it was rebuilt in 87. also the cable seem to be waaaay to long i routed what appeared to be right way but it seemed way to long. it had a huge curve it in which i think may have led to its breaking but not sure. i figured the cable should run with a slight curve from the speedo to the hole in the fire wall and out to the wheel with enough room to flex when the wheel is turned. is there another company that sells cables to fit the type three. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 12428 Location: Eugene, OR
Posted: Sun Mar 27, 2011 6:23 am Post subject: |
I'd run a good used cable that I Knew was the correct length! It won't last either if your speedometer is froze up. _________________ http://s169.photobucket.com/albums/u236/mr_bojangles500/
69 FI/AT square Daily Driver
66 sunroof,67,71,71,71 AT,72,72 AT Parts
56 & 57 oval ragtop $2,500 |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 2072 Location: Southern AB
W1K1 Samba Member
supaninja Samba Member
turbomicrowaves Samba Member
Posted: Sun Mar 27, 2011 9:24 am Post subject: |
I also took mine apart and cleaned out the old dried up grease and re-lubricated the gears. It made a huge difference. _________________ '68 Sunroof Squareback
"There are no pieces"
OCT3 - Orange County Type 3's |
Posted: Sun Mar 27, 2011 10:16 am Post subject: |
| it spins very freely i took the little piece that broke off inserted it into speedo and can spin it quickly withmy fingers like im snapping and it jump up to 15 to 25 depending on how quickly i flick it. |
Posted: Sun Mar 27, 2011 10:24 am Post subject: |
| slammed 68 wrote: | | it spins very freely i took the little piece that broke off inserted it into speedo and can spin it quickly withmy fingers like im snapping and it jump up to 15 to 25 depending on how quickly i flick it. |
It will still spin freely with the dirt and grime in it, but it cause the cable to bind a little, that's why you hear whining sometimes. _________________ '68 Sunroof Squareback
Kadin Samba Member
Posted: Wed Apr 04, 2012 4:02 pm Post subject: |
So I replaced my Speedometer today (the old one was good but wanted to change the clock out so changed the speedometer to match) and then when I was driving it was working for a little while and then all the sudden dropped to 0mph.
Do you think this would be an issue with the cable, the speedometer, or both? |
blankmange  Type 3 Darksider
Joined: July 17, 2004 Posts: 11640 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Wed Apr 04, 2012 4:13 pm Post subject: |
| Kadin wrote: | So I replaced my Speedometer today (the old one was good but wanted to change the clock out so changed the speedometer to match) and then when I was driving it was working for a little while and then all the sudden dropped to 0mph.
could be either - pull the cable and take a look.... _________________
| 19super73 wrote: | | You wouldn't understand intelligent humour even if it slapped you upside your SOS pad head. |
póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Kadin Samba Member
Posted: Thu Apr 05, 2012 10:42 am Post subject: |
| blankmange wrote: | | Kadin wrote: | So I replaced my Speedometer today (the old one was good but wanted to change the clock out so changed the speedometer to match) and then when I was driving it was working for a little while and then all the sudden dropped to 0mph.
could be either - pull the cable and take a look.... |
Weird.... I just drove it again and the speedometer came back on for about 30 seconds and then went off again..... maybe just a loose connection.... |
