turboedbug Samba Member
Joined: April 14, 2006 Posts: 260 Location: washington
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Fri Apr 01, 2011 5:28 pm Post subject: |
To the left of the speedo.
_________________ Glenn
Member #1009
#BlueSquare |
Glenn Mr. 010
Posted: Fri Apr 01, 2011 5:36 pm Post subject: |
Some are mounted under the dash, on a pod off the steering column and in a cup above the radio.
Try searching the gallery.
Member #1009
#BlueSquare |
QRP Samba Member
Joined: April 27, 2008 Posts: 1710 Location: NORTH HOLLYWOOD,CA
Posted: Fri Apr 01, 2011 5:50 pm Post subject: |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri Apr 01, 2011 5:53 pm Post subject: |
to the right of the speedometer:
_________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Apr 01, 2011 8:28 pm Post subject: |
I have MS, but I don't drive around like THAT all the time!
No sir only gauge I have is the speedo, and that's currently got a stripped cable spline so it's disconnected. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
dmilla Samba Member
Joined: February 19, 2005 Posts: 123 Location: Ventura County, CA
Posted: Sat Apr 02, 2011 8:25 am Post subject: |
_________________ Experience is recognizing a mistake when you make it again... |
Hotrodvw Samba Member
Posted: Sat Apr 02, 2011 8:34 am Post subject: |
_________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Posted: Sat Apr 02, 2011 10:54 pm Post subject: |
Fast-Fab! _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sat Apr 02, 2011 11:04 pm Post subject: |
Got mine too Hotrod!
MURZI Samba Member
Joined: August 25, 2005 Posts: 5063 Location: Madisonville, La
Posted: Sun Apr 03, 2011 3:04 pm Post subject: |
_________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Rome Samba Member
Joined: June 02, 2004 Posts: 9641 Location: Pearl River, NY
Posted: Sun Apr 03, 2011 7:39 pm Post subject: |
Posting photos in my response has never worked for me, even following the Samba instructions to the letter. Here are two possibilities from my own Beetles:
[img]https://www.thesamba.com/vw/gallery/pix/189173.jpg[/img]
The tach is from a Porsche 914, which has the same diameter as the Beetle speedo. This method requires cutting out the factory speedo opening, relocating it to the left, and welding in a new speedo pod to the right from another car for the 914 tach.
[img]https://www.thesamba.com/vw/gallery/pix/183195.jpg[/img]
Another 914 tach, this time in a RadioShack "project box" under the dash. Disadvantage is that it's out of your direct line of sight. |
fredy a Samba Member
Posted: Sun Apr 03, 2011 9:52 pm Post subject: |
my test _________________ sorry for the spelling |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Mon Apr 04, 2011 6:00 am Post subject: |
3.3/4" mini monster tach
Mine mounts with a plate sandwiched under the mirror
Hers uses a plate that screws in under the the visor mount screws
it works well because it's always in your peripheral, and you can't see it from outside. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
