jesus_chrysler Samba Member
Joined: March 04, 2009 Posts: 425 Location: Wisconsin
Posted: Fri Apr 08, 2011 2:47 pm Post subject: 63 brakes |
I have an early 63 single cab. It has the newer front brakes from what I can tell so far. They match the brakes off a 66 beam I have.
I am trying to order new brakes for the rear. How can I tell if it had the pre or post 63 brakes? Whats the difference? _________________ My collection:
58 beetle rag top
63 Single cab
67 11 Window
70 Charger 440
76 Kawasaki H1 triple 2stroke
71 Yamaha R5
06 Chopped HD |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Fri Apr 08, 2011 3:00 pm Post subject: |
you need to look at the rear drum diameter, or the axle nut actually. The later brakes are like 250mm drum, and the early ones are around 230mm. The dead giveaway is the 36mm nut for early, and the 46mm nut for late. There is some rare others, so just measure the drum diamether to be safe. Pictures work really well on the samba also.
Tony P _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Posted: Fri Apr 08, 2011 3:33 pm Post subject: |
Well I must have one of those bastard setups. Its a 36mm nut with 250mm dia drums. Are these drums valuable? 211 501 615B drums?
So would the 64up shoes be right?
58 beetle rag top
63 Single cab
67 11 Window
70 Charger 440
71 Yamaha R5
06 Chopped HD |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Fri Apr 08, 2011 5:46 pm Post subject: |
My 1963 camper had a 1967 transaxle with the one year only 1963 one ton RGBs (one year only brake drum) and the 1963 frontend with the odd front drums, so I put big stub axle RGBs on the rear and a 1964-1967 frontend on it. The 1963 drums are a pain in the butt to find. _________________ Don't worry; be happy. (Baba) |
Posted: Fri Apr 08, 2011 6:01 pm Post subject: |
Well my 63 has a bent trailing arm. stupid PO bent it with a winch i think. I got a 66 beam for the front. I am going beetle IRS in the rear with the bus brakes.
So would the '64-'67 shoes work? _________________ My collection:
58 beetle rag top
63 Single cab
67 11 Window
70 Charger 440
71 Yamaha R5
06 Chopped HD |
EverettB Administrator
Joined: April 11, 2000 Posts: 69801 Location: Phoenix Metro
Campy Samba Member
Posted: Fri Apr 08, 2011 11:30 pm Post subject: |
Now I remember that I installed the later model frontend on my 1963 bus so there would be thicker link pins. _________________ Don't worry; be happy. (Baba) |
