Paint mixing FAQ
Goto page Previous  1, 2, 3  Next
Afterlame
Afterlame is offline
PostPosted: Sun Nov 15, 2009 7:01 am    Post subject: Re: primer color for panel interior Reply with quote
booyak wrote:
does anyone know of a good match for the primer color for the interior of a 59 panel? Thx
Interested too !
to make some area outside but it's probably the same primer that inside (?)
Nobody as a reference ?
joebug1956
joebug1956 is offline
PostPosted: Sat Dec 26, 2009 9:03 pm    Post subject: Reply with quote
Anyone know what I can use to paint the deluxe split window dash pods with?
Ady6119
Ady6119 is offline
PostPosted: Fri Jan 22, 2010 11:13 am    Post subject: Reply with quote
How much paint do i need for my bus 21 win. deluxe '67?
I have;
3 Liter BC red for middle side and under chassis
3 Liter white for top side and interior + thinner and hardener,
Should be enough ?
Sanny
Sanny is offline
PostPosted: Thu Jan 28, 2010 8:57 pm    Post subject: Dove Blue in Valspar or PPG? Reply with quote
Does anyone have the formula in Valspar or PPG for Dove Blue or should I just custom match a piece of the original paint color?
flyertim
flyertim is offline
PostPosted: Sat May 15, 2010 8:04 am    Post subject: L351 Korallenrot (Coral Red) Reply with quote
my local paint jobber found the code for L351 Coral Red (56-58 beetle) from BASF.
this is for their UNO (single stage) line of paint:
color id: MS137584
solution id: CL682996
SC01 (base booster) = 89.5
SC77 (iron red) = 659.7
SC90 (white) = 813.4
SC10 (mixing clear) = 955.0
SC63 (chrome yellow) = 1044.6
SC25 (carbon black) = 1074.0
this will give you 1 quart of paint.
"Broadsword calling Dannyboy"
my '57 rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=369883
MichaelTucson
MichaelTucson is offline
PostPosted: Mon May 17, 2010 8:09 pm    Post subject: Bahia red ('71) code? Reply with quote
Does anyone know a PPG code for Bahia red? (vw code L30E).
Mike
themobilenotary
themobilenotary is offline
PostPosted: Tue May 25, 2010 8:47 pm    Post subject: Re: Dove Blue in Valspar or PPG? Reply with quote
Dove Blue VW Color L-31
RGB 144 176 232
HEX 90BOE8
PPG Code 11668
Smile
Craig
1958 Single Cab
1970 Fastback
MichaelTucson
PostPosted: Fri Sep 24, 2010 1:05 pm    Post subject: Re: Bahia red ('71) code? Reply with quote
Mike
For reference for anyone, the PPG code for Bahia Red ('71, L30E) is 71852.
I saw that on page 1 of this topic, someone had posted a link to a site where you can look them up. Don't mean to be redundant, but since it looks like a bunch of us missed that link, here it is again:
http://tcpglobal.com/autocolorlibrary/acl_files/volkswagen.html
'63 Ghia
'71 Super Vert
'71 Ghia
jb17atita
jb17atita is offline
PostPosted: Thu Feb 17, 2011 9:04 am    Post subject: Re: Dove Blue in Valspar or PPG? Reply with quote
RGB 144 176 232
HEX 90BOE8
PPG Code 11668
Smile
Craig
Nice!!
By any chance won't you have those codes for L35 - Metallic Blue?
Davemccabrio
Davemccabrio is offline
PostPosted: Thu Apr 14, 2011 6:04 am    Post subject: L274 code Reply with quote
Does anyone have the codes/ formula for L274 Sand Beige? Need it for my wheels, and I need it soon!
Thanks!
cavi21
cavi21 is offline
PostPosted: Tue Jun 07, 2011 1:31 pm    Post subject: Reply with quote
If you need any color information that was made with Glasurit, you have in their webpage all the mixin information, it's really easy to use.
You have to put in Manufacturer Volkswagen, then select the year and write the color in the "color name box", there are more options too.
Then you click in the search button and will show you the colors, click over the color you need the mixin, then below select Line and after that click in the "next button", you will have all the information you want!
I hope this help anyone
http://coloronline.glasurit.com/
That's the link.
David
David is offline
PostPosted: Thu Sep 01, 2011 7:18 pm    Post subject: Reply with quote
That's the link.
Thank you, this is very helpful! There's a guy over in the Oval forums looking for this information.
Cheers,
Dave
*October '54 Ragtop
Stuggi
Stuggi is offline
PostPosted: Wed Sep 21, 2011 4:03 pm    Post subject: Reply with quote
Sikkens has a lot of them with the original codes, just remember to just search for Volkswagen, and then the paint code like VWL512 (for velvet green L-512). Also don't put in a year, since Sikkens is a bit off with their periods for when a paint was used.
http://www.qnetonline.nl/SIKEW/SearchForm/SearchMethod
Orange Bug 1970 Beetle
Green Bay Bus 1969 Panelvan
Orange VW Fest!
Pulled out of a Lake Fest!
flawedmasterpiece
flawedmasterpiece is offline
PostPosted: Sun Oct 30, 2011 6:40 am    Post subject: dupont to glasurit Reply with quote
Hello,
I am finally ready for paint on my 56 ragtop after more than 5 years of "when I can weekends". I did a trade with a fellow that is the towns best paint and restoration guy and he will be painting it for no charge to me. Problem is we can not find a conversion from the Glasurit Polar Silver (L324) to Dupont paints. I was wondering if there is anyone out there that has painted one in a close color and might have a corresponding code for me. Any assistance will be helpful as always. I will also post this in Oval section but wanted to post it here to cover my bases.
Thanks
Bill Sullivan
Bill Sullivan is offline
PostPosted: Fri Apr 06, 2012 6:09 am    Post subject: Need Wild Westner paint codes Reply with quote
for 1973 transporter ... Do not find it on vw color chart. Tks Bill
ppgpaintlady
ppgpaintlady is offline
PostPosted: Fri May 11, 2012 12:57 pm    Post subject: Bordeaux Red L51 - PPG Mixing Code Reply with quote
I need your help, my painter cannot find a PPG Mixing code/formula for L51 Bordeaux Red.
Any help would be appreciated.
thx.
---The only one I found was for a 1984 VW BORDEAUX RED PPG#51884 OEM#LB3A.
Hope that helps!
ppgpaintlady
PostPosted: Fri May 11, 2012 1:01 pm    Post subject: Re: Dove Blue in Valspar or PPG? Reply with quote
As there are a few on file, for Dove Blue. It would be best to take a piece with you to make sure they can mix the correct color.
ppgpaintlady
PostPosted: Fri May 11, 2012 1:06 pm    Post subject: Re: Bahia red ('71) code? Reply with quote
Mike
code has since changed to PPG#2698
ppgpaintlady
PostPosted: Fri May 11, 2012 1:12 pm    Post subject: Re: L99D Reply with quote
boxofrox2 wrote:
Was wondering if L99D is available.
PPG info = Topaz Poly 1975-1976 -->#2886 and yes!
Austin16V
Austin16V is offline
PostPosted: Mon Jun 18, 2012 7:05 am    Post subject: L21 Mixing codes Reply with quote
Hi,
My local paint shop have no codes for L21 (pearl Grey).
I am after some 2K and some cellulose.
They use ICI for 2K and Maxmayer for celly.
Any help appreciated!
Thanks
Page 2 of 3
