saddlesore1 Samba Member
Posted: Sun Apr 17, 2011 10:15 am Post subject: Body filler before primer or after? |
What is the best way to go about this? have done some body work and had to put a coat of primer on the spots to avois rust. Do I need go back down to bare metal for the body filler or can it be applied over the primer? |
dawerks Samba Member
Posted: Sun Apr 17, 2011 10:31 am Post subject: |
Either way! If you epoxy before filler then you have extra rust protection. If you put the filler on the metal, it usually adheres better. But, filler sucks up water. You have to put something non-porous on top of the filler otherwise water will be pulled right to the metal underneath (I've only heard this, no first hand proof).
But either way will be fine. The thing is 'mechanical' adhesion and the surface should be super clean and be sufficiently roughed up to grip. _________________ "There is only one sin; disconnection from self." |
TonysGarage Banned
Joined: December 11, 2010 Posts: 419 Location: Orange County, CA
Posted: Sun Apr 17, 2011 7:29 pm Post subject: |
dawerks wrote: |
But either way will be fine. The thing is 'mechanical' adhesion and the surface should be super clean and be sufficiently roughed up to grip. |
im going to have to disagree. DO NOT just apply filler over primer...the only filler that is designed to go directly on primer is poly filler---and poly filler is designed to straighten out small waves and pinholes. not dents.
if you have a dent or large wave that has to be filled and have already done as much hammer/dolly as you can--the primer needs to be taken off and the metal has to be sanded to allow a better bite for the mechanical adhesion to take place.
good luck--buy quality filler and follow the specs...do not apply over paint/primer if you want a product that will perform and last. _________________ I dont take shortcuts, i put care and pride into all i do--for a fair price of course |
Posted: Mon Apr 18, 2011 9:36 am Post subject: |
Not just any primer, but epoxy. Rage Gold is what I use and it works beautifully over epoxy.
There will obviously be times when you can't get to metal to apply filler.
What happens if you put filler, then sand it and there is still a low spot? _________________ "There is only one sin; disconnection from self." |
TonysGarage Banned
Posted: Mon Apr 18, 2011 11:34 am Post subject: |
Did he say he used epoxy? I thought I read "primer". And it is still suggested to apply filler DTM even if you have epoxy on there. But if you apply over epoxy and have great results--that's awesome.
And I'm kind of confused with your other question--saying there are times where you can't get to metal and what happens if you apply filler, sand and there is still a low spot??
Obviously filler can be applied over filler. If you are filling a large dent with filler (not my style but many do just "fill" dents) then it's suggested to do it in thin layers anyways.
If you applied filler, thought it was straight and primered--only to block and still see a low spot--that's what poly filler is for.
And I can't even think of a time I can't get to bare metal. _________________ I dont take shortcuts, i put care and pride into all i do--for a fair price of course |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Mon Apr 18, 2011 2:32 pm Post subject: |
chill,... gentlemen
filler goes against metal.
primer goes on last,.
anything more then 1/16" is a cat burying shit and might look ok for now, but will stink later,..
metal work is the key and to get it as close as possible.
Rage is a kickass product.
Bondo is not. _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
Posted: Mon Apr 18, 2011 3:42 pm Post subject: |
Foxx wrote: |
chill,... gentlemen
Bondo is not. |
good post _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
