VW Nut Samba Member
Joined: September 18, 2004 Posts: 55 Location: Portland, Oregon
Posted: Fri Oct 22, 2004 10:09 pm Post subject: Rear luggage area |
I need to replace the luggage area behind the back seat in my 63. I was wondering if the luggage are a from a 74 standard beetle would work to patch the area. If not, what years can I cut a patch panel out of and have it match my 63? _________________ Why is it a bad thing to be lost? |
biggene Samba Hillbilly
Joined: August 12, 2003 Posts: 1182 Location: Hanceville, Al
Posted: Sat Oct 23, 2004 5:13 am Post subject: |
I was told by the body shop that is replacing mine, that any year tray will fit. I know the ones that they sell as repro parts are supposed to fit all years for sure. _________________ There will come a time when you believe everything is finished. That will be the beginning.
Louis L’Amour
My 67 Build |
Miguel Arroyo Samba Member
Joined: April 02, 2004 Posts: 3122 Location: Miami Beach, Florida
Posted: Sat Oct 23, 2004 7:38 am Post subject: |
I had mine replaced on my 1970 about a year ago. I opted to purchase a replacement panel from California Imports. I just went to their site and they have it in stock for $119 plus S&H. If the cost of cutting the replacement part and removing any rust/grease/dirt/etc plus painting it is higher than a new panel plus paint you will have to decide. By the way the one from California Imports came with the gasket.
Whichever you do make sure they paint the side that goes against the engine before it is installed. Also make sure they use good seam sealer to go over the welds. Finally make sure they paint over the welded areas to prevent corrosion.
Good luck. |
VW Nut Samba Member
Posted: Sun Oct 24, 2004 8:12 am Post subject: |
Thanks for the response. I have a line on the replacement piece from a guys who will cut it out of a 74 he has laying around. My trusty angle grinder with the wire wheel will make quick work of cleaning the panel up. As far as putting it in the car, I plan on doing the work myself. I'll be putting it in with the body off, so sealing and paiting both sides will be a snap. _________________ Why is it a bad thing to be lost? |
