Ratwell Baywindow FAQ
Goto page Previous  1, 2, 3  Next
66-Ghia
66-Ghia is offline
PostPosted: Wed Mar 11, 2009 2:13 pm    Post subject: Tires Reply with quote
Ok if you want to help this old man again (77) I have a 1971 7 passenger bus that have 205/70R14 tires on it that the P.O. had install just before he left from Calif. to NJ . They are called "Euro Metric" The spare is a Dunlap
P195/75R14. QUESTION would I be ok leaving the 205's in the rear and changing the fronts to 185R /14C
All of the above 205's only have less than 4000 miles on them.
Any answers will be very helpful.
Thanks again
Bud
theizzardking
theizzardking is offline
PostPosted: Wed Mar 11, 2009 2:20 pm    Post subject: Re: Tires Reply with quote
Thanks again
Bud
this question would be better suited for the tires thread below this one., and i see no problem with that as long as the tires on the same beam are the same size, fronts match and rears match. but not front to rear and front to rear.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer"
CompuTom
CompuTom is offline
PostPosted: Tue May 12, 2009 3:06 pm    Post subject: What are the different types of campers? Reply with quote
I had a 1973 orange bus with standard hardtop but jalousy windows on middle bays, fold down bench/bed in rear, and folddown table on side. Is this a "halfcamper"? No plumbing or electrical or LP. Very basic but extremely functional for daily commutes and weekend camping. Is this a "weekender"? What are the camper sub-types called? Thanks.
P.S. I know the Eurovan has a model called the MV with this configuration. What does MV stand for?
theizzardking
PostPosted: Tue May 12, 2009 3:16 pm    Post subject: Reply with quote
it is most commonly refereed to as a "weekender"
campers with out tops are called weekenders, it is sort of a layman's term.
various companies did various conversions of the original baywindow transporter.
the companies i know of and most likely cannot spell correctly.
asi
adverturewagen
Rivera "rivi"
campmobile
westphila "west"
dormmobile
here's a good thread talking about the weekender
http://www.thesamba.com/vw/forum/viewtopic.php?t=327136&highlight=camper+types
another one on custom camper companies
http://www.thesamba.com/vw/forum/viewtopic.php?t=230102&highlight=camper+types
the rare campers of vw
http://www.thesamba.com/vw/forum/viewtopic.php?t=246083&highlight=rare+campers
and the best list of campers
http://www.type2.com/library/camper.htm
theizzardking
PostPosted: Mon May 18, 2009 4:41 pm    Post subject: Reply with quote
yeah but he's right paint codes is a faq! cool to see a few people today rocking the search button and adding to existing threads!
ahhclem
ahhclem is offline
PostPosted: Thu Aug 06, 2009 11:25 pm    Post subject: carb swap Reply with quote
I am fairly new at VW buses, I have a 71 bus with a dual port 1600 and the original one bbl carb. I would like to switch to something that will give me a little more balls without killing me in mpg and the wallet. What suggestions has anyone got. Thanks.
theizzardking
PostPosted: Fri Aug 07, 2009 9:50 am    Post subject: Re: carb swap Reply with quote
save the intake manifold as they are a one year only hard to find item.and get new dual intakes with a vacuum tube on them(need this for vac assisted brakes). upgrade to dual pict 34's carbs. it will get you a lot more power but not kill the mpg's you could always upgrade to 40's or 44's later but i find the dual 34's are fine on my 1600dp. also think about your exhaust it's another cheap item that can boost your power output...well at least use the hp's you have better.....
thanks for tacking on to an existing thread!! but a search can really help you out as this thread doesn't get visited often and usually is just a reference thread.
pm me if you need help and i'll do my best to walk you through what i know and/or point you to someone who can answer your questions in more depth.
babysnakes
babysnakes is offline
PostPosted: Fri Aug 07, 2009 2:27 pm    Post subject: Reply with quote
Or try dual Weber 34 ICTs, You can get a deal on used ones. Good mpg also.
'69 SC under resto
'72 deluxe daily
'78 Westy motor transplant in progress
'71 super vert
1st bus, '67 Westy in '83. Thank you '74 Pontiac Ventura.
Luftwagens
420GOAT wrote:
..dont ever ever ever ever EVER, compare any bus forum to a bug forum...
theizzardking
PostPosted: Fri Aug 07, 2009 2:35 pm    Post subject: Reply with quote
ha my bad that's what i was thinking of webbers duh! lol good catch on that one babysnakes. tgif. and seriously good catch lol
mmreed
mmreed is offline
PostPosted: Mon Sep 28, 2009 6:04 pm    Post subject: Weber Progressive Question Reply with quote
I have a Weber Progressive carb in my '72 Wesrfalia and need help with the location of the vacuum and emission hoses. Can someone please post some photos?
dmadore
dmadore is offline
PostPosted: Mon Jan 18, 2010 4:49 pm    Post subject: New to forums Reply with quote
Great info!
1976 Westfalia 2.0L Fuel Injected
thewalrus
Goo Goo G'Joob
thewalrus is offline
PostPosted: Thu Feb 17, 2011 12:33 pm    Post subject: Reply with quote
Extremely helpful info on Fuel filler neck replacements:
http://www.thesamba.com/vw/forum/viewtopic.php?p=5141860#5141860
The Filler Neck he's talking about is this from Bus Boys:
Filler Neck Elbow, Upper, 1974 All, 1975 to 1978 FED MODEL
211-201-119 $18.15
http://www.bus-boys.com/bbnew.htm
I purchased it and it was excellent quality.
Comparison of old and new:
'75 Hard Top Westfalia 2.0L F.I.
babysnakes wrote:
Real buses have one windshield
60vwnewengland wrote:
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards!
dwheil
dwheil is offline
PostPosted: Mon May 02, 2011 7:21 pm    Post subject: 8.3 Front Seat Swap Reply with quote
Has anybody been able to get the Front Seat Restoration photos to load ( http://homepage.mac.com/ratwell/78_Westy/PhotoAlbum27.html) or might have a link to a working site. Have a 76 Bay and am getting ready to install the new front covers and do not want to screw up.
Thanks
Hyzerguy
Hyzerguy is offline
PostPosted: Tue May 03, 2011 8:35 pm    Post subject: Reply with quote
From Ratwell's contact page:
November 2010 Update:
Apple has shut down homepage.mac.com support.
The result of this disruption has been that many photos of my website have broken. You can imagine how frustrating this is for members who actually pay for this service.
Please bear with me while I take the time to rehost them...I will ping the VW community when everything is back to normal.
You can see the picture links point to the dead mac location. Hope Ratwell can get his pix back up on his current web site. His instructionals are terrific (when the photos accompany the text).
subwayaz
subwayaz is offline
PostPosted: Sat May 07, 2011 10:41 am    Post subject: Reply with quote
Hey some great info here guys thanks a bunch for your efforts
lonewolfe
lonewolfe is offline
PostPosted: Fri Jul 29, 2011 12:57 am    Post subject: This link is not working any longer. Reply with quote
This is a link to nowhere now. Anyone have the correct link for "1970 Bay Window Paint Codes"?
barefootwestie wrote:
VWCadets. Next time you may want to post in the forum for a quicker response.
The color codes for many years are included in the Archives Section. For a 1970,
http://www.thesamba.com/vw/archives/lit/70colors.php. I do not see a sky blue color listed, so you may want to read your mcode plate.
Moderator - Can you move these last two responses to a thread of its own in the Bay Window Forum?
Thanks
If you hear these words then get out of the way, "Hey Ya'll, Watch this!!!".
PostPosted: Fri Jul 29, 2011 9:15 am    Post subject: Reply with quote
There is a period at the end.
will function.
How to: Post Photos | Search
Everett Barnes - [email protected] | My VWs | My wanted ads
kuleinc
kuleinc is offline
PostPosted: Mon Sep 05, 2011 8:33 pm    Post subject: Reply with quote
Is ratwell still around? Site seems to be no pictures still... Confused
1987 Wolfram Gray 2WD Vanagon GL Westy (1.8T Powered!)
2001 ALH Jetta TDi (Hers)
1998 ALH New Beetle (His)
http://www.thesamba.com/vw/forum/viewtopic.php?t=496946
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
timo78
timo78 is offline
PostPosted: Tue Sep 13, 2011 10:31 pm    Post subject: Reply with quote
Thank you RAtwell: for the time and effort in restoring your fantastic site. It is truly an invaluable asset. Cheers!
Green Bay Bus > 78Grµn Westfalia `Donkey`
You read what others had done and you took the next step. You didn't earn the knowledge for yourselves, so you don't take any responsibility for it. You stood on the shoulders of geniuses to accomplish something as fast as you could, and before you even knew what you had, you patented it, packaged it, and slapped it on a plastic lunchbox. : Ian Malcolm.
Kirk Premium Member
Kirk is offline
PostPosted: Fri Sep 30, 2011 6:45 am    Post subject: Reply with quote
Appears as of 09/19/11 All photo links are restored.
Oppenhiem
Bear
Page 2 of 3
