firula Samba Member
Joined: March 24, 2010 Posts: 149 Location: Argentina, Prov Bs As
Posted: Mon May 09, 2011 2:23 pm Post subject: |
| widehatch wrote: | | have you tired Klassic Fab? you might be able to get the doglegs shipped from Columbia were they are made. no shipping from north america to south america. |
Thank you for your response! yes, i tried it, but unfortunately they cost much more than the ones in cip1, and i can't afford that much.
Thank you very much. _________________ Restoring "La Macarena"! |
firula Samba Member
Posted: Thu May 19, 2011 11:28 am Post subject: |
Hello! I'm posting few more pictures.
Finally i sprayed some paint in order to prevent corrosion this winter.
Also cut the tail lights holes, and put engine on place! I want to start it those days at least to run time to time. It was 2 years resting since it was rebuilt.
Tail lights holes done.
Engine rebuilt, yes i'm going to change exaust! hehe.
Very crap lights, all plastic, the ad pictures didn't match what the seller told me, all i want is find some original ones, and throw away this pair!
Wrenchman12 Samba Member
Joined: October 26, 2009 Posts: 291 Location: Newmarket, NH
Posted: Thu May 19, 2011 4:49 pm Post subject: |
| Great Job! Can't wait to see it finished!! Keep up the good work. |
PEPPE Samba Member
Joined: August 24, 2003 Posts: 733 Location: Roma Italy
Posted: Fri May 20, 2011 5:35 am Post subject: e |
very impressive work....
engine looks to be one of those brazillian SP/DP hybrid! interesting |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 6294 Location: Casa de Oro, California
Posted: Fri May 20, 2011 7:38 am Post subject: Re: e |
| PEPPE wrote: | very impressive work....
Yes, impressive. Close up of the SP/DP area? |
PEPPE Samba Member
Posted: Fri May 20, 2011 8:48 am Post subject: e |
those ar DP heads installed with a small carb and manifold, very similar to SP ones. there is a small adaptor between flange on head side and manifold.
i've seen those engines also with small diameter 12v generators and cable operated choke carbs. |
BarryL  Samba Member
Posted: Fri May 20, 2011 9:24 am Post subject: Re: e |
| PEPPE wrote: | those ar DP heads installed with a small carb and manifold, very similar to SP ones. there is a small adaptor between flange on head side and manifold.
I can barely see the adaptor. So is the SP manifold shorter? |
PEPPE Samba Member
Posted: Sat May 21, 2011 12:31 am Post subject: w |
| yes, shorter and meets the adaptor at an angle. |
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 4910 Location: Richmond, Verjinya
Posted: Sat May 21, 2011 2:29 pm Post subject: |
Very impressive. Keep it up. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
firula Samba Member
Posted: Thu May 26, 2011 8:45 pm Post subject: |
Sorry people, i didn't saw all these comments. First of all, can you explain me what SP/DP means? remember i'm a newbie with just 26 years old!
Carb is "Caresa", a national brand. When i found this bus it had a german Solex 28 mounted on it. The engine was not running, lot of things missing and play everywhere. Was rebuilt, and my mechanic found this carb and told me about. Here is hard to find some original solex, and this Caresa is the replacement.
| BarryL wrote: | | Yes, impressive. Close up of the SP/DP area? |
Of course, as soon as i figure what SP/DP means  _________________ Restoring "La Macarena"! |
BUGTHUG Samba's Rented Mule
Joined: April 22, 2007 Posts: 755 Location: KANSAS toto's fire hydrant
Posted: Thu May 26, 2011 9:00 pm Post subject: |
I think they are refering to the SP being SINGLE PORT, and DP= double port intake for the carb. _________________ I know you would understand what I'm saying if you could just see my HANDS
Even the middle of the week says W T F
1963 15 window bus
1964 split window bus
1966 VW bug
1969 Dune Buggy
1971 Westfallia camper bus
1972 Kelmark, VW drive line
1948 Chevrolet Hearse |
firula Samba Member
Posted: Thu May 26, 2011 9:05 pm Post subject: |
How i forgot to upload this picture??
She is my sweet helper, Negra, nobody in the world have seen her tooths, even if you pick a piece of beef from his tray when she is liking it.
Every morning runs to meet me, like saying "Hello! Can you please scratch my belly?" That's how i start my day of work in the bus.
She likes to sleep under the kombi, will be the first passenger i'm sure.
kanniff Samba Member
Joined: October 12, 2009 Posts: 804 Location: West Coast
Posted: Fri May 27, 2011 10:44 am Post subject: |
Look out Klassic Fab- This guy's creating competition  |
firula Samba Member
Posted: Fri May 27, 2011 4:37 pm Post subject: |
| BUGTHUG wrote: | | I think they are refering to the SP being SINGLE PORT, and DP= double port intake for the carb. |
Oh i see, can you give me some links to picture examples, i can't figure it out.
Thank you! _________________ Restoring "La Macarena"! |
firula Samba Member
Posted: Fri May 27, 2011 4:43 pm Post subject: |
| kanniff wrote: | Look out Klassic Fab- This guy's creating competition  |
Jeje, thanks! but i'm not that good!  _________________ Restoring "La Macarena"! |
firula Samba Member
Posted: Thu Jun 02, 2011 10:04 am Post subject: |
I got rear floor stamped!
I made it from 18 gauge steel, is looks really strong, i thing more that necessary. Did I it with correct gauge or it should have been done in 20 gauge?
In thesamba archives i found this:
| engineerscott wrote: | | For instance, when you talk about the metal thickness of a stamped sheet metal part like a floor pan, there is some ambiguity. When someone says that a floor pan is "18 gauge" does that mean they stamped the part out of 18 gauge steel OR is the minimum finished stamping no thinner than 18 gauge? There is a difference. In the stamping process, parts of the component will be stretched as the metal is forced into the die. That metal that is stretched will be thinner than the starting thickness. How much thinner? Depended on how deep the die is that the metal is being drawn into. Other manufacturers may spec the finished thickness, in other words they will use whatever gauge metal is required such that the thinnest section of the part is no thinner than their target thickness after stamping. Makes a big difference. For example, you might stamp a part from 18 gauge steel and end up with a component that measures 22 gauge in some places. |
My pans was not pressed but bended, i think there is no minimum gauge thickness anywhere, i suppose that's what it looks very heavy.
Pictures tomorrow! Camera out of batteries. _________________ Restoring "La Macarena"! |
firula Samba Member
Posted: Thu Jun 02, 2011 10:25 am Post subject: |
Work on battery trays:
More pictures tomorrow! _________________ Restoring "La Macarena"! |
firula Samba Member
Posted: Mon Jun 06, 2011 11:45 am Post subject: |
Somebody gave me this peg (left one), i don't know from what vehicle is it, it's almost same size, but little bigger and angle on tracks is little different. I measured about 79º by hand on OG peg, in picture it is like 80º, but i trust in hand method because is possible the cam lens distorts the image.
I'm going to give it a try on lathe and see the results.
firula Samba Member
Posted: Thu Jun 09, 2011 4:41 pm Post subject: |
I wanted to upload some pictures, but i think i'm alone here...  _________________ Restoring "La Macarena"! |
peecee69  Samba Member
Joined: January 27, 2005 Posts: 656 Location: Buffalo, NY
Posted: Thu Jun 09, 2011 6:58 pm Post subject: |
| firula wrote: | I wanted to upload some pictures, but i think i'm alone here...  |
Nope! |
