missing EGR system (1978 Westfalia)
Goto page Previous  1, 2, 3
poptop tom
poptop tom is offline
PostPosted: Fri Apr 15, 2011 7:13 am    Post subject: Reply with quote
Some good additional info that may help.
http://www.ratwell.com/technical/Smog.html
...make good money five dollars a day...
'76 Deluxe Campmobile ((finally on the road))
XXX/Rx/RnR
XXX/Rx/RnR is offline
PostPosted: Fri Apr 15, 2011 7:53 am    Post subject: Reply with quote
Been there. No luck. Need a pic of that rod that has a spring on it and what does it connect to. Looks like vaccum opens the poppet and the spring helps to close it? I'll keep looking. All the pics I've seen, its hidden fron view. Never seen that part before till I viewed SGKents add that had it pictured with the tubing and gaskets. Thanks again...
78'FI, 2.0, a/t, lift spindles, index rear, 930 cv's & axles, 4-2-1 header, Xtera rack, 6gal. Manchester LP tank, Atwood Hydroflame, 1800 watt invertor, Holt ice maker, custom cooktop, sink, & rear rack. 27x8.5x14's on stock rims. Solar panel 2amp/hr. hard line to 2 blue tops for aux. power. Red top for engine. 70 amp. alt.
busdaddy
busdaddy is offline
PostPosted: Fri Apr 15, 2011 8:18 am    Post subject: Reply with quote
Don't forget the Samba gallery Wink
The 78 valve isn't vacuum controlled, it's all mechanical.
Wanted, 68-73 westy OG plaid curtains, singles OK.
SGKent
SGKent is offline
PostPosted: Fri Apr 15, 2011 8:44 am    Post subject: Reply with quote
see BusDaddy's picture for the Plenum.
I would pull your valve and replace it with new gaskets and the valve I sent. I know the valve I sent is good and there is a chance yours is bad and that is why it is capped off. When you pull the screws, just pull the two holding the valve to the plenum - when it comes off you can use a pocket knife or putty knife to pop off the old gaskets. I put each new gasket in a seperate plastic baggie and wrote where each one goes.
Here is a photo of the parts book on how it is assembled. The rectangular flange on the tube goes on top of the valve.
If you can push a piece of flexible wire, old bicycle brake line or a thin wire tie into the plenum tube hole 4 or 5 inches it is open. If it is plugged the wire will stop after about 1/2". I found that the easiest way to unplug them was to soak carb cleaner in the hole for three or four hours, dig out the goop when it softened like toothpaste and do it again and again until I could see it was fully open. I took the plenum off to do this so it is a good time to replace any bad rubber boots. I also sent you a cork gasket - that is for the Cold Start Valve if you remove that off the plenum. You can try to pass smog with it plugged if you are willing to get the fail if they catch it which they may or may not. As you can see, all they have to do to test it is move the lever and they will know if it works and that is how shops normally test an egr on any car.
XXX/Rx/RnR
PostPosted: Fri Apr 15, 2011 12:25 pm    Post subject: Reply with quote
SG, I'm not the one you sent the parts to. I read the post and want to get mine ready for emmissions if they tough in Az. If you have parts, I'm interested in them. P.M. if you do. Thanks for the great pics BD & SG. I need the rod that connects the linkage together and the gaskets and tube. I can see how it works now.
SGKent
SGKent is offline
PostPosted: Fri Apr 15, 2011 7:11 pm    Post subject: Reply with quote
I am too low on gaskets to send anymore out. You will need to resuse the old ones with some high temp silicone. The tube you can probably get from Raul VW76Westy or in classifieds. If I can answer any questions ask. I don't know if AZ requires a functional test or not. California does.
SGKent
SGKent is offline
PostPosted: Sat Apr 16, 2011 8:38 am    Post subject: Reply with quote
When I do have EGR extra gaskets they sell $45 a set shipped. I can have more made if enough people need them. There are 5 EGR gaskets of which one has a metering orifice and 1 cork CSV gasket for a total of 6 gaskets.
furthur78
furthur78 is offline
PostPosted: Wed Jun 01, 2011 6:27 pm    Post subject: Reply with quote
yeah so thanks SG Kent and the rest of ya for the help - under a 100 bucks for the whole EGR assembly, i owe you one - I got a hand by Gary down at Sonoma VW in Glen Ellen, CA and with their fine tuning our bus passed cal smog. he said it wasn't easy though and recommended a catalytic converter for the next go around - i don't know, we'll see - i'm just thrilled to have the bus on the road for the summer - i really thought I was screwed. thanks again all
say hi if you see us around the bay areas <p>
furthur78
PostPosted: Wed Jun 01, 2011 6:31 pm    Post subject: Reply with quote
yeah you were right about that - Gary cleaned the plenum tube and got the EGR valve going... but all the baggy labeling and everything helped me install the whole kit with no problems, appreciate all that - thanks again
SGKent
SGKent is offline
PostPosted: Wed Jun 01, 2011 9:30 pm    Post subject: Reply with quote
really glad it past smog. That should be a relief off your mind - I know it was for me when mine finally did. If you have to buy a convertor next year you can get one direct from EMICO in Canada at a reasonable price that is CARB II certified. Scan and PM me your final smog results and I will interpret them.
BUSBOSS
BUSBOSS is offline
PostPosted: Wed Jun 01, 2011 11:43 pm    Post subject: Reply with quote
Did you pass with no cat?
1976 Westfalia
1970 Karmann Ghia Convertible
(sold - but not forgotten)
dfolstrom
dfolstrom is offline
PostPosted: Thu Jun 30, 2011 4:16 pm    Post subject: Reply with quote
Great thread I wish I would have researched this much earlier anyway now I am one of those SGKent says "is on our own" I need a replacement EGR valve for my 77 diaphram is shot. If anyone has a lead on one, please let me know. Thanks.
furthur78
PostPosted: Thu Aug 18, 2011 4:34 pm    Post subject: Reply with quote
yes - I had to add a EGR valve to get past the visual inspection, but it was a non-CA model so the cat wasn't required... passing smog without it was tough... he recommended adding one before the next smog test in 2 years... although i hear it is illegal to do that? bizarre.
curtis4085
curtis4085 is offline
PostPosted: Mon Aug 29, 2011 7:28 pm    Post subject: Reply with quote
anybody have luck taking a 78 Egr filter and modifing it to fit a 79 engine? i am at wits end to get the proper 79 egr filter and egr tube/pipe. Not sure if the egr pipe for the 79 is the skiiny one or the regular one? I live in COlorado and just want stock system. What is a guy to do?
vw76westy
vw76westy is offline
PostPosted: Mon Aug 29, 2011 9:21 pm    Post subject: Reply with quote
pics or did not happen
i have seen different shapes for the pipe that connects
the egr filter to the valve
& i have seen filters with the pipe connection in every possible spot
threwout the filter
but the filter & the size of the pipe has always been the same
on the other hand being from CA most of the 79's i find are
CA-79's with a oxygen sensor,etc
& i have never seen fed 79 with a complete & correct egr system
order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1449189
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor,
johnlynch47
johnlynch47 is offline
PostPosted: Sat Apr 28, 2012 11:16 am    Post subject: Reply with quote
Very confused, I did a bunch of work on my 2.0 FI and as I was putting everything back I noticed the EGR was frozen, Do I need to replace or can I just block off the hole? or can I somehow clean the one I have?
"My shovel is sharp, my pick is sharp, and my will is outstanding." - Rod Marinelli
"I've got a good heart, but this heart can get ugly" Rapper DMX
"Bring your face over here so I can smack it" My Mom
1977 Sage Green Westy up in this!
her name is Velma
1994 Chevy Silverado - Mater
2006 Kia Sedona - Pearl
curtis4085
PostPosted: Sat Apr 28, 2012 11:49 am    Post subject: Reply with quote
Are you talking about the EGR valve or filter? The filter if solid you can clean out with carb cleaner, compressed air and lots of shaking and banging on it to Get the chuncks of carbon out.
The Egr valve you can buy em used in classifieds or get a rebuilt one from interstate, they are pricey rebuilt but available in classifieds as well
As for the EgR pipe being different size, I found that the I.D. Is same and both sizes will fit. It's the O.D that's different that threw me off.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
71 Pastel White Panel Van current restoration
73 Westfalia (sold)
73 Westfalia (accident)
73 Kombi (Sold)
75 Panel Van
79 Sage Green Westfalia fully restored
http://www.thesamba.com/vw/forum/viewtopic.php?t=479199&postdays=0&postorder=asc&start=0
johnlynch47
PostPosted: Sat Apr 28, 2012 11:56 am    Post subject: Reply with quote
#28 in the diagram above from Kent. So I need that valve to work properly for the bus to run well? Or can I block it off?
her name is Velma
Westfabulous
Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Westfabulous is offline
PostPosted: Sat Apr 28, 2012 12:04 pm    Post subject: Reply with quote
You can most certainly block it off. I did. Others will tell you not to. You can make your own block off plate, or German Supply sells a kit. I am in favor of blocking it off if your smog laws don't require it, but then again, I couldn't hook mine up if I wanted to, as I stil need a '79 only EGR filter.
"I will gladly pay you Tuesday for a hamburger today."
Page 3 of 3
