timatt Samba Member
Posted: Thu Jun 09, 2011 8:10 am Post subject: type IV crankshaft needle bearing |
Can someone tell me what is involved with removal of the transmission input shaft needle bearing from the crankshaft? Is a puller required? I tried to pull it out with my finger with no luck.
Thanks
Tim
'79 Westy |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16925 Location: San Diego, California
Posted: Thu Jun 09, 2011 8:17 am Post subject: |
Something like a slide hammer with a hooked end would work. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Thu Jun 09, 2011 8:25 am Post subject: |
Tool stores sell a specific pilot bearing puller for this. But a sweet trick if the bearing hasn't fallen apart or gotten too hot is to pack the entire area behind the bearing with a heavy grease. Then use a mainshaft/clutch centering tool and insert into bearing. Tap with a hammer and if it is not stuck too tight, it will come out. Not sure if those plastic clutch centering tool will work. |
timatt Samba Member
Posted: Fri Jun 10, 2011 7:52 am Post subject: It Worked |
I've heard about using grease to remove a starter bushing for years but never had the opportunity to try it. I tried it last night for the pilot bearing and it worked. I cut a piece of aluminum rod on the lathe to fit the pilot busing and Bingo; came out after a few bangs with a 5 lb hammer.
Tim
'79 California Westy |
Posted: Fri Jun 10, 2011 7:55 am Post subject: |
YEAH !! Simply amazing that physics stuff! Have a good one, brother. |
jpeters Samba Member
Joined: May 06, 2005 Posts: 1025 Location: Woodsfield, Ohio
Posted: Wed Jun 19, 2013 8:59 am Post subject: |
Buy or rent a pilot bearing removal tool. If you try a chisel you will find out about the quality of steel used to make bearings. |
Posted: Wed Jun 19, 2013 9:06 am Post subject: |
One guy even mentioned putting shavings from a bar of soap behind the bearing instead of using grease and then pounding in the dowel in order to push out the bearing. I actually think that might work. I don't think the grease was working on mine because the grease was too light. _________________ '73 Westy (dual stock carbs, SVDA w/ compufire)
'68 Westy http://www.thesamba.com/vw/forum/viewtopic.php?t=484180
'65 Westy SO-42 http://www.thesamba.com/vw/forum/viewtopic.php?t=435614
'65 Bug
'63 Bug
neverdnf on Instagram |
vwmaniaman Samba Member
Joined: June 07, 2005 Posts: 562 Location: Grand Rivers,KY
Posted: Wed Jun 19, 2013 9:39 am Post subject: |
I put a long screw with 2 washers thru the bearing, put a nut on the outside threaded end and used a crow bar. Out it came. Cheapo instant puller. Put PB Blaster all around it first though and wait 15-20 minutes. _________________ Working on a VW is like fun with a friend!
65 Beetle
75 Westy "Pumpkin Van"
86 Westy "Brown Betty"
87 Cabrio |
Posted: Wed Jun 19, 2013 9:42 am Post subject: |
Forgot to say the screw is small compared to the center hole of the washers. They are a sloppy fit on the screw and edges grab the inside edge of the bearing. _________________ Working on a VW is like fun with a friend!
65 Beetle
87 Cabrio |
Posted: Wed Jun 19, 2013 9:54 am Post subject: |
Look, maybe you guys don't know what a slide hammer is so here:
I'm not saying that you need to go buy a special tool like this but just look at it and you should understand how it works. All you need to do is grab the bearing on the back side with a metal hook and then whack it out of there using a heavy object. You can use a 2 pound hammer head, a hook, and connect them with wire or cable. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
