James 93SLC Samba Member
Joined: January 21, 2009 Posts: 914 Location: NE Ohio
Posted: Wed Jun 08, 2011 1:22 pm Post subject: 91 Carat VR6 Project - The Build |
I'm finally moving forward with swapping a VR6 into my 91 Carat. I'll use this thread to document the process as much as possible. In my research here on the Samba I've found a few posts here and there but no real start to end build. Hopefully I can fill the gap with my experience.
Here is the victim, a 97 Golf GTI that was T-boned, and the transplant patient in the background. I'm glad I get to pull the engine and wiring myself so that I get everything I might need.
The engine. I've started pulling stuff in prep of pulling the engine.
 _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka"
xoo00oox  Samba Member
Joined: February 11, 2010 Posts: 773 Location: East Nassau, NY
Posted: Wed Jun 08, 2011 1:34 pm Post subject: |
| Nice find, I'll be watching this. The AAA VR6 is a great engine even with 250K on them, they don't seem to wear out. |
vwjoel Samba Member
Joined: April 14, 2006 Posts: 128 Location: Seattle WA
Posted: Wed Jun 08, 2011 1:45 pm Post subject: |
This will be good. I have been considering what engine to put in my 87 Doka. From what I've seen the VR6 gives up more ground clearance than the 1.8t. I am interested to see how you overcome this. _________________ 1987 2WD Doka
1984 Westfalia 2.7L Vanaru |
fastwagens Samba Member
Joined: March 01, 2004 Posts: 1031 Location: Michigan (The other west coast)
Posted: Wed Jun 08, 2011 3:51 pm Post subject: |
| vwjoel wrote: | | This will be good. I have been considering what engine to put in my 87 Doka. From what I've seen the VR6 gives up more ground clearance than the 1.8t. I am interested to see how you overcome this. |
I have done this conversion a couple times. And as for clearance the bottom of the oil pan in no lower than the original engine carrier.
I am starting another transplant this summer in the carrier. My doner is a 95 gti with 110k on the clock.
One of the drawbacks for most is how much the engine pokes into the cabin.
I have never found this an issue if it is trimmed out nicely.
If the og poster is interested in any info feel free to pm me.
We may have spoken in the past.
One thing to do is get the adapter plate on order as it can take 8 weeks to arrive. _________________ ON SALE TODAY, CHECK IT OUT.
Slammed Low 'n Lazy limited clothing available at
www.slammedshopusa.blogspot.com
Please visit my webshop at www.fastwagens.blogspot.com/
Powerflex bushings available at
www.T3technique.com |
BenT Syncro Samba Member
Joined: January 07, 2005 Posts: 804 Location: San Francisco
Posted: Thu Jun 09, 2011 2:15 am Post subject: |
Who makes a rear engine carrier? I've got a couple of VR6 engines from B4 Passats. One is being yanked out of a wagon to make way for a TDI conversion. I have Doka with a troublesome ABA conversion which would make a great home for one of these engines. No rear deck clearance issues there.
Does the KEP inline-4 VW adapter plates fit the VR6? just wondering out loud. The downside is I converted the Doka to auto trans. _________________ BenT |
Posted: Thu Jun 09, 2011 3:03 am Post subject: |
| BenT Syncro wrote: | Who makes a rear engine carrier? I've got a couple of VR6 engines from B4 Passats. One is being yanked out of a wagon to make way for a TDI conversion. I have Doka with a troublesome ABA conversion which would make a great home for one of these engines. No rear deck clearance issues there.
Does the KEP inline-4 VW adapter plates fit the VR6? just wondering out loud. The downside is I converted the Doka to auto trans. |
i used the stock vanagon carrier and moved it back a few inches then made some brackets to hold the mounts.
I am not sure if the inline four will work. that might be a question for KEP. _________________ ON SALE TODAY, CHECK IT OUT.
ThorAlex Samba Member
Posted: Thu Jun 09, 2011 5:31 am Post subject: |
The vr6 uses the same bolt pattern as the audi I-5 I think. vw-winkler in germany makes a vr6 specific adapter: http://vw-winkler.de/Bausatz-VR-6-Kennbst-AAA-kpl _________________ Currently vanless
Ex-vans:
1990 Caravelle coach 1.6TD
1986 Transporter Double cab syncro 2.1 112hp |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 1580 Location: Oxfordshire, UK
Posted: Thu Jun 09, 2011 5:48 am Post subject: |
Unfortunately it doesn't use the Audi 5 cylinder pattern. The Audi V6 does though.
The VR6 shares it's bolt pattern only with the V5.
MG _________________ 1989 Syncro 16 S6 Westy Limey
1991 Syncro Lightweight SWB
1989 S8 Bluestar
1990 Tristar |
Posted: Thu Jun 09, 2011 6:01 am Post subject: |
Oh ok, thanks for the correction Mike _________________ Currently vanless
Ex-vans:
Posted: Thu Jun 09, 2011 9:44 am Post subject: |
| fastwagens wrote: |
I am not sure if the inline four will work. that might be a question for KEP. |
Got any pics of the brackets? _________________ BenT |
Posted: Thu Jun 09, 2011 9:53 am Post subject: |
As Mike wrote, the SA bellhousing you linked to above will work on most Audi 5-cyl, V6, V8, & some 4-cyl (924 Porsche & VW LT's). However, VW used a different bolt pattern. The Audi bubble blocks must have the VW pattern though because they used those for the Eurospec, later Tiico inline-4 Vanagon conversions. The 80's-90's diesel Volvos used LT engines so theoretically should fit the SA bellhousing too. VR6, is a no go for the SA BH. _________________ BenT |
Posted: Thu Jun 09, 2011 11:14 am Post subject: |
| BenT Syncro wrote: | | fastwagens wrote: |
Got any pics of the brackets? |
Here is the best I could find. But you get the idea
[img] http://www.thesamba.com/vw/forum/album_page.php?pic_id=350303 [/img]
I'll have to fix this link when I get off work I proves to hard to do from my iPod. _________________ ON SALE TODAY, CHECK IT OUT.
Posted: Thu Jun 09, 2011 11:30 am Post subject: |
Fastwagen,
The iPod is like Wasserboxer. You need a 4G. It's the VR6 of Samba postings. I've posted your pic link correctly below.
From the looks of things, you used some sort of angle iron. Do you recall any of the dimensions and as to where on the engine you bolted the mounts?
Did you do your own wiring?
Posted: Thu Jun 09, 2011 12:31 pm Post subject: |
| BenT Syncro wrote: | Fastwagen,
In the pic you see some angle iron I used to weld a base on the carrier and some square tube up to the engine. The mount is a trans mount from a standard chevy. I have the part # if interested.
Yes I did the wiring myself. you basically need to add your 12V always on your 12v Keyed on and a ground. The rest of the wiring is making sure the sensors are indicating ie: temp, tach etc. _________________ ON SALE TODAY, CHECK IT OUT.
Posted: Thu Jun 09, 2011 1:21 pm Post subject: |
| fastwagens wrote: |
One thing to do is get the adapter plate on order as it can take 8 weeks to arrive. |
Already have the adapter plate in hand. I bought it used here off Samba (was that you Fastwagens??)
I'm going to experiment to minimize engine poke and sheet metal cutting. Ground clearance is the least of my concerns since I plan to do all pavement driving.
I've seen fastwagens engine mount pictures before. That passenger side design is a problem for me since I want to retail the power steering pump and A/C. I might fab a second carrier bar to run under the engine at the engine/trans mounting (there is a raised section in the oil pan) to pick up the OE mount on that side.
Thanks for the help invite fastwagens. We have msg'd a few times before and I'm sure you'll hear from me again  _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka" |
Posted: Thu Jun 09, 2011 3:12 pm Post subject: |
OK, now the pic makes sense. Guessing fab the bar with angle iron. Then THAT square tube piece. Since the rear bar will be relocated, you can't just bolt it on and figure out how high and how far the front piece needs to be.
Since you've done a couple, maybe you ought to make and sell these brackets to make the lives of future VR6 converters easier. _________________ BenT |
Posted: Sat Jun 11, 2011 6:06 am Post subject: Engine removal update |
Finished up pulling the engine out of the donor. I'll finish pulling wiring this weekend and then work on going over the motor. I'll be pulling the timing chain covers and oilpan to inspect things, and will likely pull the head as well. The bottom ends on these are very stout, so I don't expect any surprises. I may also send the head out to check the valve sealing.
This is looking at the trans end of the motor as viewed from the side. Here you can see the coilpack sitting at the top
and the thermostat housing just below it. These are the parts that extend away from the trans mating surface and
require cutting sheet metal in the van for clearance. Hopefully I can keep that to a minimum with some parts relocation
and engine mounting. The adapter plate will also help reduce the the difference in offset.
Here is a good view that shows the height of the motor.
91 Vanagon Carat
93 Corrado SLC
Posted: Sun Jun 12, 2011 8:14 pm Post subject: Update |
I've got the VR6 in the van and it's a mid-engine now! Well OK it's not running in the van, but it is "technically" in the van.
Need to get my friends hoist over to my house to unload it, then I need to find the other part of my engine stand. Might just make a Harbor Freight run and buy a new one.
Will also finish pulling wires sometime Monday. Need to also work up my parts order for some gaskets and misc.
91 Vanagon Carat
93 Corrado SLC
carterzest Samba Member
Joined: January 22, 2008 Posts: 3192 Location: PDX/RipCity/StumpTown
Posted: Sun Jun 12, 2011 8:20 pm Post subject: Re: Update |
| James 93SLC wrote: | I've got the VR6 in the van and it's a mid-engine now! Well OK it's not running in the van, but it is "technically" in the van.
 | How many miles on your engine? Thanks for starting the thread. Good to have references  _________________ Jeffrey Carter PDX Thread
86 SyncWesty/86 SyncTintop | tencentlife wrote: | | Get lost! It's fun! |
| tencentlife wrote: | | Personally I think discussing conversions is always fine, but YAECT'ers are a special breed of asshat. |
Posted: Sun Jun 12, 2011 8:24 pm Post subject: Re: Update |
| carterzest wrote: | How many miles on your engine? Thanks for starting the thread. Good to have references  |
The VR6 has approx 130K. I'll be checking out the head, timing chain guides and bottom end before putting it in service.
The WBX that's currently in the van just turned over 100K. It runs well but has developed a slight coolant weep on both heads. _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
