Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Fri Jul 08, 2011 8:07 am Post subject: repair of sliding door track |
Has anyone done a satisfactory repair of the sliding door track? Is there any source for the parts? I don't really want to put the whole factory part in, just the rusty track and outer rocker. The rocker part from Bus Depot didn't fit at all!
Al _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
goffoz Samba Member
Posted: Fri Jul 08, 2011 8:27 am Post subject: |
Hi AL
Which track?...I assume the lower one, right
Do you have bad rust, holes?...or is it just pitted?
On my 2wd the door was loud and growlie, so I wire brushed and sanded the heck out of it....the applied a good coat or 2 of marine grade epoxy
I was so impressed with how quiet the slider was after that, that I decided to go further...I stripped down the lower roller and lubed and polished it ..then just as an experiment I put down a strip of 2" wide 6mill HDPE tape(the type used for wrapping connections in underground pipe joint.
Man that door is so quiet and smooth now...it still amazes me
ps:the tape has held up for 2months now, and looks unworn |
Posted: Fri Jul 08, 2011 1:29 pm Post subject: |
The metal is completely rusted/ worn thru in places. I need to make a patch and fasten it in somehow, then put on a new outer rocker. I was hoping someone made a repair part. GERSON??
time to start with T3 parts?
Vanagons:
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Fri Jul 08, 2011 3:30 pm Post subject: |
goffoz wrote: |
... On my 2wd the door was loud and growlie, so I wire brushed and sanded the heck out of it....the applied a good coat or 2 of marine grade epoxy... stripped down the lower roller and lubed and polished it ... put down a strip of 2" wide 6mill HDPE tape... that door is so quiet and smooth now...it still amazes me :shock:
I'd don't mean to hijack this thread but I know I'm not the only one in the forum with an embarrassing loud sliding door... I hate having to open and close it late nights in a campground.
I think your above repair would make a great thread (perhaps a sticky???), complete with pictures, of the complete process.
... sounds like I have a new item for my "Westy To-Do" list _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
goffoz Samba Member
Posted: Fri Jul 08, 2011 7:42 pm Post subject: |
69doublecab wrote: |
Al |
Pick and pull and a battery operated sawsall....or maybe someone nearby has a parts van you can attack , and have it welded in? |
kamzcab86 Samba Moderator
Posted: Fri Jul 08, 2011 7:50 pm Post subject: |
82WestyMan wrote: |
... sounds like I have a new item for my "Westy To-Do" list |
It's on my lengthy to-do list, for sure. This thread http://www.thesamba.com/vw/forum/viewtopic.php?t=381226 doesn't have photos, but it does have a decent description and the OP used UHMW tape (same basic stuff??). _________________ ~Kamz
2016 Golf GTI S
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Sat Jul 09, 2011 10:49 am Post subject: |
I bought passenger and drivers entire rockers for $200/side, cut out for me by a local shop. Lots of junkyards would do the same thing, just show them what you want. Last post of this thread
I will have some more pics in the coming days. Slider track is marginally bad, but, I did not want to do the other repairs without also repairing the slider track. It is/was extremely crusty and sure to be an issue in the near future. _________________ Happiness=Portland, Oregon in the rearview mirror! |
