DukeBradbury Samba Member
Joined: September 27, 2009 Posts: 354 Location: Spokane WA
Posted: Sun Aug 07, 2011 9:29 am Post subject: My 1965 13W Deluxe |
Just wanted to start a thread on the progress of my bus. Any comments or suggestions are greatly appreciated, as this is my first attempt at body work.
I know I have posted some of these pics before in other threads, but I really wanted to compile a thread depicting the "voyage" of the restoration.
Here it is right after yarding it out of the field.
At home
After a little cleaning!!!It sure needed it after sitting in a field for 10 years!!
Left rear corner repair. This is my very 1st attempt at body work, and welding sheet metal! After turning off the "autoset" feature on my Millermatic 180 and dialing in the welder manually I was able to get the hang of it.
Mounting hole repair. Does anyone know what these were for?
There were four each side.
Patch repair method. Tried this after my 1st "fill in" attempt that didnt go so well.
Fill in method. Second attempt after getting the hang of welding sheet metal.
This is the end result
Had some rust right above the drivers window. Some creature had made it his home.
Now for the nose....
Here is the before pics.
roachdub58 Samba Member
Joined: April 04, 2006 Posts: 1160 Location: an orchard where Mexicans shake the nuts you eat!
Posted: Sun Aug 07, 2011 9:40 am Post subject: |
Nice work. Keep it up you'll only get better  |
vwjedi Samba Member
Joined: November 29, 2005 Posts: 1404 Location: G-ville, FL - hopefully on a trail.
Posted: Mon Aug 08, 2011 10:45 am Post subject: |
Sweet dude, looks good.  _________________ 1987 Wolfsburg T25
1981 Caddy LX diesel
1967 Raleigh Sprite |
zuggbug  Samba Member
Joined: June 17, 2008 Posts: 1894 Location: Anderson SC
Posted: Mon Aug 08, 2011 11:45 am Post subject: |
good job....way to dive in and start learning and progressing.
NO FEAR!!! _________________ SOUTHERN INTEGRITY AIRCOOLERS
56 Kombi
72 Dormobile
58 15 window |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1029 Location: Vallejo, CA
Posted: Tue Aug 09, 2011 8:54 pm Post subject: |
| Cool bus and nice work. |
Posted: Wed Aug 10, 2011 12:40 pm Post subject: |
Thanks. Im having a lot of fun and learning a ton!!
A little more progress on the from nose.
Did some more work with the stud welder and slide hammer. It looks pretty good. The dent on the right side of the lower nose wont come out any better. It's not too bad and it actually looks worse in the picture. Better than when I started.
Tried pulling out the dents and straightening the lower front nose skin (part behind the bumper). Wasnt happening!
Decided to replace it. Removed only what I thought I needed to.
Posted: Thu Aug 11, 2011 6:05 pm Post subject: |
scottvw Samba Member
Joined: November 17, 2004 Posts: 2293 Location: Highlands Ranch, CO
Posted: Thu Aug 11, 2011 7:02 pm Post subject: |
| Nice work. |
Posted: Mon Sep 12, 2011 1:01 pm Post subject: |
Sorry about the "double posting". I forgot I had started this progress thread. I will keep the additional updates here.
Cargo rocker replacement time.
Located the spot welds:
The rocker removed:
There is some surface rust on the inner rocker as you can see. However, it is very solid and I am going to hit it with the sand blaster.
I was able to straighten out the outer edge of the floor, leaving the lip of course! (see the last couple pics). However, if you check out the first couple pics you will notice that it isn't in the best shape. (rust damage). Not bad. What do you think. Should it be replaced? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 9477 Location: Olympia Wash Rinse & Repeat
Posted: Tue Sep 13, 2011 7:37 pm Post subject: |
Great work!!!
Please do post the images on this website. Seen too many old posts where the photobucket images have disappeared, leaving a post that is hard to follow without images. _________________ In Stereo, Where Available! |
kanniff Samba Member
Joined: October 12, 2009 Posts: 804 Location: West Coast
Posted: Tue Sep 13, 2011 11:05 pm Post subject: |
Awesome job!
Very impressive! |
durfeec Samba Member
Posted: Wed Sep 14, 2011 11:07 am Post subject: |
id only patch what you have to on the cargo floor. keep as much OG metal as possible. especially that outer area where the door attaches. _________________ 1960 Bus Panel/Camper |
wertygrog Samba Member
Joined: January 10, 2010 Posts: 52 Location: Escondido, CA
Posted: Wed Sep 14, 2011 8:11 pm Post subject: |
lookin' great, I wish you lived closer to me!!  |
Cuņado Wear  Samba Member
Joined: December 10, 2006 Posts: 570 Location: The O'side
Posted: Wed Sep 14, 2011 8:29 pm Post subject: |
Good job! _________________
| Bulli Klinik wrote: | | I may be a little late to the party, but what the hell is Cunado Wear? |
63' Vert
63' 15 Window Deluxe |
Posted: Sun Sep 18, 2011 5:07 pm Post subject: |
Had a couple minutes yesterday so I decided to see if I could repair my deluxe rocker spears.
Here is what I started with:
Put the trim in the vice between a couple pieces of 2x4.
This is how it came out of the vice.
Using my body hammer, I straightened out the trim and cut in the edges a bit.
Turned out pretty good. I have a bit more work to do. They will work for my ride!! |
Posted: Wed Nov 02, 2011 7:33 pm Post subject: |
Built this jig to build my narrowed beam
Used 2" SCH 40 pipe
Today I got a chance to put it together. I test fit it in the bus. Very happy with it
RHD Notch Samba Member
Posted: Wed Nov 02, 2011 8:03 pm Post subject: |
Just caught up with your thread...NICE work! Really nice to see you fabbing the whole enchilada...keep the updates coming  _________________
| Lind wrote: | | I am at the point where I hardly want to own anything that isn't original paint. |
60 SWR SC It's a ROUGH one http://www.thesamba.com/vw/forum/viewtopic.php?t=486463
64 RHD Notch OG Paint & Interior
66 Notch OG Paint & Interior
73 Thing 31K miles...OG EveryThing
Remember Whittier Blvd. in the 80's? |
61TXghia Samba Member
Joined: July 17, 2009 Posts: 890 Location: El Paso, TX
Split 66' Samba Member
Joined: October 07, 2010 Posts: 601 Location: Bay Area, California
Posted: Thu Nov 03, 2011 2:30 am Post subject: |
| DukeBradbury wrote: | Had a couple minutes yesterday so I decided to see if I could repair my deluxe rocker spears.
, I didn't know that was possible. Really amazing job on that spear, that gouge looked almost like it was a cut.
All you used was a body hammer to accomplish that? _________________ Currently looking for: 66-67 OG paint Sea Blue L360 Apron - 2/3 Middle Seat Grab Handles for Aero/Steel |
Posted: Thu Nov 03, 2011 7:09 am Post subject: |
Split, to be honest, I didn't know it was possible!! I figured the worst I could do was screw it up.
I still have a little more work I want to do to it to see if I can get it more straight. Probably sand it using a block to take out some waves. Maybe someone that has done it before has some advice?
I started by putting it into a vice between two 2x4's. That took out most of the bend. It wasn't actually "cut", but had a huge gouge. After working from the back with the body hammer and pushing some of it out, I had to grind it down. |
